Wanting to regear in the future and might as well put a locker in.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 08BlackenedTaco, Apr 14, 2012.
  1. Apr 17, 2012 at 10:07 AM
    #41
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    If you "gas it in a turn" on wet pavement there's no system in the world that can compensate for your stupidity....locker, LSD, ATRAC...nothing
  2. Apr 17, 2012 at 12:17 PM
    #42
    ian408
    ian408 Well-Known Member
    Ian
    Santa Clara, CA
    09 Tacoma
    Z power of Quattro does pretty well in the wet...oh wait...wrong brand.
    I'm fine with the way the Auburn works in the wet. And to be truthful, I've had more "oh shit" moments with VSC than the posi rear end. Which is to say the VSC kicks in a lot and the rear end has been just fine (except when it won't lock and I want it to lock--but that's the price for LSD).
  3. Apr 17, 2012 at 12:30 PM
    #43
    TheMrGExperience
    TheMrGExperience Because Tacos are too mainstream...and Im poor.
    Garrett
    Slidell, LA
    01 GMC Sierra z85 4x4 4.8L RCLB
    Debadged, 4x6 to 6x9 rear speaker conversion
    i have an auto locker and i dont have any problems with it. Just have to let off the gas around turns. Every now and then i have to pop it in reverse for a second to release the built up torque is all. I love it.
  4. Apr 17, 2012 at 1:05 PM
    #44
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    NWF crawlbox, 5.29s, rear Detriot, front Harrop, 37" SXIIs, 17x9" KMC Grenade Crawl beadlocks, Dirt King 3.5" LT kit with King shocks, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, custom 1 piece driveshaft with .135 wall tubeing, GSF front rock crawling bumper, GSF rear bumper, Relentless Fab ifs skid, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, Spec clutch, LCE heavy flywheel, URD short shifter, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, Grillcraft, FXR TRS, T1 eyelids, custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers
    yeah i dont really see your point, unless every uphill turn you just like to floor it for no apparent reason! I think you are thinking way too hard about this. 90% of the time, the way your vehicle handles on the road depends on how u drive it. The other 10% are dependent on the type of vehicle, weather elements, road condition, other drivers, things out of your control, etc. . . . .
    If you are basing your "theory of wet turns and locker" on your decision to get one or not, i think you should consider doing a little more research on specifically what different kinds of lockers, LSDs, ATRAC systems, etc. do for the on road and off road handling of your truck. And just to remind you (unless you've changed your mind) you are looking for something that will work well off road while maintaining on road driveability.
  5. Apr 18, 2012 at 7:04 AM
    #45
    08BlackenedTaco
    08BlackenedTaco [OP] Well-Known Member
    High Point, NC
    Prerunner Murdered....
    14" magnaflow maxflow muffler, intake mod, black headlight mod. VHT Nightshades tail lights, painted stock rims.
    I was just under the impression that with any pressure applied it would be locked and easy to slip on wet pavement. but it sounds like with normal driving habits it should be just fine?
  6. Apr 18, 2012 at 7:09 AM
    #46
    ItalynStylion
    Steven
    DFW, Tx.
    That's the idea with the no-slip. It's got some springs in there to help manage the locking. Not only that, locked or unlocked, you're only going to spin if you've got significant power applied and are turning sharply.
  7. Apr 25, 2012 at 12:49 PM
    #47
    ItalynStylion
    Steven
    DFW, Tx.
    Here's a question I recall coming up but couldn't recall if an answer ever materialized....
    No-Slip unit in the rear and in the FRONT...would that be a problem? Here's what I'm getting at. The rear diff ALWAYS has power going to it so it would affect daily driving as power is applied to it. However, during daily driving when 4WD is NOT engaged there is no torque applied to the No-Slip unit and the diff isn't even engaged to the transfer case. So my thought is that you could have one of these No-Slip lockers in the front and not affect daily driving at all.
    What say ye? Can we get a locker guru in here?
  8. Apr 25, 2012 at 3:44 PM
    #48
    ItalynStylion
    Steven
    DFW, Tx.
    Bump to the front page....really curious about this. Seems to be a good idea.
  9. Apr 25, 2012 at 4:28 PM
    #49
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    True. A front locker of any type (even welded spider gears) has no ill effect when in 2wd. The ADD disconnects the passenger side axle and the t-case stops applying power to the front driveline in 2wd. I have an arb and a manual shift t-case so my ADD is always engaged, even in 2wd, and I haven't had any issues at all. The problem with your theory is that nobody makes a no slip for the front end. ARB on the other hand, makes a fine locker that is always there when you need it and drives normal when you don't.
  10. Apr 25, 2012 at 9:00 PM
    #50
    ItalynStylion
    Steven
    DFW, Tx.
    I'll be honest, I don't know anything about the sizing for diffs. As I understand it, the No-Slip (and other diffs) come in different sizes and or variations. Do you not think there is one that will work?
    Or I suppose the more proper question would be; what specifications do I need to look for to get something that's compatible up front?
  11. Apr 25, 2012 at 9:36 PM
    #51
    ItalynStylion
    Steven
    DFW, Tx.
    What about the front?
    And the number "8.4" what does that represent? A gear ratio or an overall size of the components or something? Really I'm clueless here.
  12. Apr 25, 2012 at 9:49 PM
    #52
    badger
    badger Well-Known Member
    07 SR5
    Lockers are built for specific applications. If it is not spec'd for your diff, then it won't work. There are many reasons why. The "8.4" designation is mostly a model number. It is the non Elocker differential. Both the locker version and the non locker versions use 8" ring gears. There is no 8.4" ring in these trucks, but the "8.4" is a stronger design.
    The reason you shouldn't put any fulltime locker in the front is that you lose the ability to use 4wd on ice or other low traction road surfaces. A locked front in such circumstances is very dangerous. Locked fronts should only be considered in dedicated offroad vehicles. I would not use anything but an ARB in any 4x4 front diff.
  13. Apr 25, 2012 at 9:54 PM
    #53
    ItalynStylion
    Steven
    DFW, Tx.
    Yeah I can see how it would be dangerous on ice. And thanks for the explanation.
    Would an OEM LSD from the rear of one of the earlier Sport models work up front?
  14. Apr 25, 2012 at 9:58 PM
    #54
    badger
    07 SR5
    No
  15. Apr 26, 2012 at 12:08 AM
    #55
    Cortland
    Cortland Well-Known Member
    Cortland
    California
    Clifford aka Big Red
    Camburg 4" Spindles, 5100's All Around, All-Pro 1.5" Leaf Pack, All-Pro U-Bolt Flip Kit, Avid Sliders, AFE Pro Dry Filter, Wicked Flow 18" Muffler
    So 4.10 gears from a 4cyl Tacoma should work with both a TRD Sport and TRD Off Road?
  16. Apr 26, 2012 at 8:20 PM
    #56
    ItalynStylion
    Steven
    DFW, Tx.
    I asked the question but didn't see an answer thrown out. What size is the FRONT differential on the 2nd Gen Tacoma Sport?
  17. Apr 26, 2012 at 8:23 PM
    #57
    TrdSurgie
    TrdSurgie revised
    Oahu
    Go to ecgs for that info. All 4x4 fronts are the same for 2nd gen
  18. Apr 26, 2012 at 8:24 PM
    #58
    TrdSurgie
    TrdSurgie revised
    Oahu
    Yes.
  19. Apr 27, 2012 at 6:08 AM
    #59
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    8”
  20. Apr 27, 2012 at 6:11 AM
    #60
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    Yes but only if tha 4 cyl has an elocker and tha Sport or Offroad has an elocker, or vice versa
