Warm Air Intake - suggestions
Discussion in 'Performance and Tuning' started by Annolino122, Jun 20, 2014.
  1. Jun 20, 2014 at 11:33 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Get an aftermarket tuner. Like the MAF Cal w/timing from URD. Or something else of your liking. Adjust the Closed Loop and Open Loop fueling maps. Adjust the timing a tad. You will get both, power and economy, much more efficiently than with an aftermarket intake.
  2. Jun 20, 2014 at 11:35 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Increase your tire pressure about 5 psi.
  3. Jun 20, 2014 at 11:35 AM
    Annolino122
    Annolino122 [OP] Well-Known Member
    Evansville
    2014 Tacoma TRD off road
    More efficiently yeah, but 99% cases vehicles with high HP & Torque have crappy MPG. Unless it has a turbo (like most diesels) or superchargers
    Had a Subaru, with full tune and power I was getting 14mpg. Changed the turbo rpm spoil time and reduced power and got up to 22mpg
    Extremely depends on your daily drive. My daily speed barely reaches 40mph, most of the time 30mph, so more power kills me
    My dad's truck (1500 ram hemi 400hp) gets 9mpg where I live, he gets 15mpg where he lives. So for my town power kills mileage
  4. Jun 20, 2014 at 11:37 AM
    Annolino122
    Evansville
    Might be what i do till I get the intake and headers at the same time
  5. Jun 20, 2014 at 11:38 AM
    Annolino122
    Evansville
    Closed and open loops? I've never tuned for those haha how's that work? And do you have a tuner?
  6. Jun 20, 2014 at 11:41 AM
    GEORGE STRAIT
    GEORGE STRAIT (Not the real George Strait)
    Da Magic City, AL
    Smart Fortwo '10 Hybrid
    My honest advice/opinion is that the marginal difference between stock w/drop in and a full aftermarket intake is extremely negligible. I've had both.. A intake is like 250-300 bucks more and might give you 1-2 hp more than a drop in.. All things constant
  7. Jun 20, 2014 at 11:43 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I have a standalone. ProEFI Pro128. My truck isn't built for mileage efficiency. :laugh:
    www.urdusa.com
    www.dezod.com
    Capable tuners on both websites. Yours will have to be wire-in, since your year model doesn't have plugs available for the harness.
    The OEM tune is very rich. A LOT of fuel is wasted because of this. Refine the tune, and just add a degree of timing here and there, and it will be much more fuel efficient.
  8. Jun 20, 2014 at 11:49 AM
    Annolino122
    Evansville
    These tuners are like $1000 though?
  9. Jun 20, 2014 at 11:50 AM
    Annolino122
    Evansville
    Even with the plan of getting headers also? Cause I've heard the WAI, headers, and exhaust combo is a "cheap" nice thing to do
  10. Jun 20, 2014 at 11:59 AM
    chadderkdawg
    chadderkdawg Don't ask questions you don't want the answer to..
    Des Moines, Iowa
    09 FX4 F150
    There is some serious butt dyno and bro-science going on in here... Thank god for Torspd who is the only one here making any real statements of fact.
    OP, bottom line is that unless you plan on spending thousands of dollars tuning your engine after your intake and headers, you aren't going to see jack shit of a difference. Anyone who has actually ran the numbers on their vehicle before and after any kind of intake or filter change has netted only a decrease in mileage. These trucks aren't the same as your Subi was, just something you are going to have to get used to.
  11. Jun 20, 2014 at 12:33 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Not trying to sound rude, but clearly you hadn't looked at the links, at the time of your posting.
    Far from $1k, at the lower starting price point.
    URD MAF Cal
    http://urdusa.com/Electronics-Perfo...ow-Fuel-&-Timing-Calibrator/product_info.html
    Page of all URD tuning solutions
    http://urdusa.com/Electronics-Perfo....html?osCsid=1751d0688e4b05825a2f67f85a5cf322
    AEM FI/C from Dezod
    http://www.dezod.com/pd-aem-fuel-ignition-controlleruniversal.cfm
    Universal-ish page
    http://www.dezod.com/cat_piggy-back_systems.cfm
    Basically for ~$40 more, you could be adjusting your fueling and timing, than an intake. :eek:
    http://urdusa.com/Intakes-Cold-Air-...2si-ProDryS-2012+-Tacoma-V6/product_info.html
    Unless you intentionally didn't, so that I would post those links for you.....hmmmmm.....sneaky you. :spy:
  12. Jun 20, 2014 at 1:04 PM
    Vassily28
    Vassily28 Well-Known Member
    Quebec, Quebec, Canada
    11 TRD SPORT 4x4 Quadcab LB
    TRD supercharger with 2.85" URD stealth pulley and OEM FPR mod. URD fuel pump upgrade, URD TB plate adapter 70mm, FJ/4 runner 70 mm Throttle body, URD exhaust cam gears URD performance thermostat TRD CAI 1st gen. with custom cover (coupe), ProDry S + Filter skin, Doug thorley long tube headers, URD spec U exhaust Icon LT 2.5 front coilover, Timbren front bumpstops, Total Choas UCA, Deaver custom leafpack 3 inch. lift, Icon 2.5 VS series rear resishocks, Timbren rear bumpstops, ARB front bumper with WARN 8500 lbs winch,Hella 500 blackmagic, AVID rear bumper, Allpro front IFS skid + Trans. skid + Transfercase skid. Total chaos LCA skid, SS braided brake line, URD O2 sims, URD MAF controller, Wetokole front seatcovers, Innovate MTX-L, MTX-D AFR and boost gage.
    ^^ :rofl:
    For a better mpg, why not stay stock and just control rpm with right foot. Maybe a trhottle controller like APEXI with eco mode.
  13. Jun 20, 2014 at 1:04 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    And from this member NtacomaR
  14. Jun 20, 2014 at 4:41 PM
    Shauncho
    Shauncho Embrace your inner Bro-ness
    Shaun
    Parts Unknown...
    none
  15. Jun 20, 2014 at 4:51 PM
    #35
    Annolino122
    Evansville
    It was more me quickly googling tacoma chips haha was busy at work so I didn't have time to look. But yeah that's totally different
    So you're saying one of these (depending on how much I wanna spend) is day and night for power and mileage?
  16. Jun 20, 2014 at 4:52 PM
    #36
    Annolino122
    Evansville
    I don't wanna accept that though! Haha :(
  17. Jun 20, 2014 at 4:56 PM
    #37
    Shauncho
    Shaun
    Parts Unknown...
    none
    Kinda all depends on your definitions of "day and night"...that gives the impression you're hoping for huge gains. All of the options will only provide minimal gains.
  18. Jun 20, 2014 at 5:01 PM
    #38
    Annolino122
    Evansville
    Yeah that probably wasn't the best descriptive word haha but be able to feel a difference and see a difference in mileage
  19. Jun 20, 2014 at 5:15 PM
    #39
    WhatThePho?
    WhatThePho? Greg Graffin 2016
    Andre
    HCMC, VN
    2006 STi
    The things required to pull bitches
    K&n without the heat shield = hot air intake.
    Due to the heat the engine will retard its timing with that and runnin 87 or lower it will increase your mpg because you will have a lack of power. And without power you'll gain mpg
  20. Jun 24, 2014 at 12:16 PM
    #40
    wdb
    wdb intolerance intolerant
    Dave
    the perimeter
    plain jane
    Hella 4000 eurobeams, Amp Bed Step, IamMrYo mirror riser, Wet Okoles, HomerTaco satoshi, retrofit intermittent wipers & backup camera
    Agree with all of it except the need for a K&N. Why not just pull the stock flexible coupling off the fender snorkus and let it suck air in from under the hood. Presto, free WAI.
