Warming up the truck still necessary?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Blak Shinobi, Nov 2, 2022.
  1. Nov 8, 2022 at 5:18 PM
    #221
    saint277
    saint277 Vigilo Confido
    Huh, somehow my posts survived..... Anyway, as long as it take for my hand to reach the gear shift from the ignition is how long I warm up for. In bad weather I were gloves and scrap the windows, then take off. Water temp on my scan gauge doesn't even take 2 mins to reach 100+ degrees F.
  2. Nov 8, 2022 at 7:10 PM
    #222
    Blak Shinobi
    Blak Shinobi [OP] Well-Known Member
    taco
    2020 MGM Sport DCSB 4x4
    n/a
    mine got deleted all i said was dont feed the trolls , i did learn something from posting this thread , i just let the truck warm up for 30seconds seems good enough
    Gearheadesw likes this.
  3. Nov 9, 2022 at 2:25 AM
    #223
    TacoTime55
    TacoTime55 TT59
    Ed
    Delaware
    2021 Midnight Black TRD Sport AT/DCSB
    TRD Lift,OTT Tune, LED HLs,TRDSkid, TalonCAT
    The older cars needed warming up...and by "older" I mean the ones before Electronic Fuel Ignitions (EFI)/Carburated/With some kind of choke.
    10 minutes sounds about right to get the cabin nice and toasty and the engine idling at around 800 RPMs; down from around 1200-1500.
    But the question is for 3rd Gen Tacomas.
    I've learned that once my console display (I mean the one in front of the steering wheel & the touch screen) I can feel confident in putting her in "D".
    I don't press the gas pedal immediately...I let her slowly ease through the driveway in gear and then once I'm off the curb/driveway, I go on my merry way!
  4. Nov 9, 2022 at 4:07 AM
    #224
    stevesnj
    stevesnj Well-Known Member
    South Jersey/Philly Area
    1996 Land Cruiser 80 Series
    it's fuel injected and. also have to in my Land Cruiser. That takes forever to warm up.
    TacoTime55[QUOTED] likes this.
  5. Dec 5, 2024 at 6:16 AM
    #225
    TacomaCZman
    TacomaCZman Well-Known Member
    San Antonio, Texas
    2022 Tacoma SR5 Pre-Runner 3.5L 4x2
    It's true that old dogs can learn new thangs!
  6. Dec 5, 2024 at 6:35 AM
    #226
    TacoTime55
    TacoTime55 TT59
    Ed
    Delaware
    I'm trying to recall my reply from 2 years ago!
    Thread revival!
    I'm 58.5 years old and and still the youngest at the J.O.B.
    TacomaCZman[QUOTED] and Chew like this.
  7. Dec 6, 2024 at 9:54 AM
    #227
    Tacogent
    Tacogent Well-Known Member
    Nonw Stock
    I heard both sides of the story many times and I realize that this is new generation materials and the like, but ....
    I'm the old fashion, warm-it-up type.
    In-laws say no warm it up, but I was trained in the Type 1 VW bug school of thought.
    John Muir of "How to keep your VW alive ......." is my source.
    When and if you re-build an auto engine, your appreciation for how it functions increases incredibly. AND ALL OF THOSE PARTS ARE LUBRICATED BY OIL ! You change your thinking and want oil on everything. How it all fits together and gets its OIL is really cool. When you pick up a 20 lb crank and bolt on the rods - you're amazed that oil is what helps keeps it from flinging by your head.
    That's a lot steel moving around at a very rapid pace.
    Let alone do the engine parts get lubed, but all the metal/steel gets to its 'operating size' and 'position' its designed to do/be for operation.
    I want my parts lubricated and up to the proper size, as much as possible, before it has to bear my loads. I want to be warmed up and lubricated before I got to do a job. Hmmmmm ....
    He maintains:
    1) Says that WIU is the best thing you can do for your engine.
    2) 90% of engine wear occurs in the first 15 min of operation in the AM.
    3) 1/2 to 3 min - colder the longer WIU.
    4) Start off slowly and increase gradually.
    5) when not in use, oil drains from the cylinders and operating parts.
    6) WIU lets the oil splash up in to the cylinder walls and on the other oil-able parts.
    7) WIU lets the splashed oil bear the weight and movement of the engine parts, not metal on metal.
    8) says that it increases engine life by 1/3.
    I've rebuilt 3 VW engines and was amazed that something like oil allows all the cam, lifters, crank and rod throws, pistons sliding in the cylinders sliding to actually WORK. All those tight parts moving n harmony! That's a lot metal moving around
    SO, you choose - start cold or warmed up. Why do athletes need to warm up before an event? Why do cars have thermostats?
  8. Dec 6, 2024 at 10:35 AM
    #228
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    So the engine will get to operating temp quickly and stay there. It's not getting to operating temp quickly idling in the driveway. All you're doing is wasting gas and soaking the converter with unburned fuel
    A point of consideration.. The sooner the engine gets to temp the sooner the fuel will atomize and turn to vapor as it enters the cylinders. If you have a cold cylinder the fuel will want to resist vaporizing and stay "liquid". Liquid fuel will stick to the cylinder wall resulting in increased wear as the piston rings scrape up and down.
    The days of carburetors are long gone, modern fuel injected engines don't like running around luke-warm. That's why the computer will code if it sees the engine not running hot enough.
    P0128 - "coolant thermostat below regulating temp "
    Chris(NJ) and Phlogiston like this.
  9. Dec 6, 2024 at 10:40 AM
    #229
    wfo479
    wfo479 Well-Known Member
    NE Ohio
    2020 TRD Pro
    I wouldnt listen to that asshat
    DMel and hemlockz like this.
  10. Dec 6, 2024 at 11:37 AM
    #230
    Gen3TacomaOBX
    Gen3TacomaOBX Well-Known Member
    S
    2018 Tacoma DCSB SR 4x4
    Bilstein 6112 front / 5100 rear (extended) shocks, Headstrong AAL, Firestone airbags, 4.88 gears, OME Carrier bearing drop kit, Aluminum 1/4" skids (engine to transfer). Custom sliders (1.75" HREW tube w/ 3/16" base plates). Custom front bumper and high clearance rear bumper (1/4" steel plate, 1.75" tube.) Apex 5500 winch w/synthetic line (36lbs) and required accessories for an underpowered winch (snatch blocks and extra line.) Tekonsha P3 brake controller, remote start, any-time-backup camera w/ front facing camera, Leer 100R shell (w/e-track single slot tie-down mounts for removable Yakima EasyTop.) Cat shields by CaliRaised. Husky liners, window tint, heated seat (passenger only.) Relentless bed rail brackets with QuickFists (shovel/axe/fire extinguisher.) Hondo Garage Un-holey vent mount. Anytime rear with front facing camera. Billet front seat risers. Viair 88p. 265/75r16 Goodyear Ultra-terrain tires.
    Oh.. it's Friday. It's easy to imagine someone mechanically challenged would interpret the "no warm up" advice as permission to bounce off the rev limiter seconds after startup.
    Phlogiston likes this.
  11. Dec 6, 2024 at 12:29 PM
    #231
    2021SR5V64WD
    2021SR5V64WD Well-Known Member
    2021 SR5 V6 4WD ACCESS CAB
    Well he knows about 10,000 times more about cars in general than I do.
    I tend to listen to those who are smarter than I am.
  12. Dec 6, 2024 at 2:18 PM
    #232
    MindlessCorpse
    MindlessCorpse Well-Known Member
    2020 Tacoma TRD sport
  13. Dec 6, 2024 at 2:23 PM
    #233
    e_engstro
    e_engstro Well-Known Member
    Eric
    Arizona
    2019 Tacoma TRD Off-Road 4x2
    I'm no mechanic but I can't imagine warming up the vehicle is going to hurt anything. Ultimately you want to oil to move better throughout the engine and that obviously isn't going to happen when the oil is cold as it will move slower throughout.
  14. Dec 6, 2024 at 3:11 PM
    #234
    Phlogiston
    Phlogiston There are no victims, only volunteers.
    A@!#$@$%#$%
    The wild west
    2016 SR5 DCSB
    You people overthink way too much shit.
    Your heads are full of chaotic synapses.
    Chew and Sprig like this.
  15. Dec 6, 2024 at 6:05 PM
    #235
    Sprig
    Sprig Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    Well said but this thread is way beyond chaotic synapses. It was started over 2 years ago and has over 220 posts. It was a simple and dumb question , one or two responses would have completely answered it. To make things worse the op is a jerk and asshole. I only say this because one of our mods wrote a long dissertation about what a jerk he is when the op was banned. Not a 30 day ban but the dude is permanently banned. He’s not even around to see the posts.
    I’m not going further down the rabbit hole in this discussion. I was #10 post in this thread. I’ll stick with that answer. I’ll end by saying if the owner’s manual doesn’t say you need to warm up your car then you probably don’t need to warm it up.
    Phlogiston[QUOTED] likes this.
  16. Dec 6, 2024 at 6:08 PM
    #236
    Outsider_IX
    Outsider_IX Active Member
    2020 Magnetic Gray Off Road
    I let mine warm up for a few mins, because being cold sucks. And I live in a very cold weather state.
  17. Dec 6, 2024 at 7:05 PM
    #237
    Tacosauro
    Tacosauro Well-Known Member
    23 SR5 V6 & 24 TRD OR
    roof rack
    I like to wait 10-15 mins in winter.
    In summer usually 5 mins.
    Its just as athletes do warm up before actual exercise, especially in cold. Can't say it will hurt or not hurt to drive off right away, but this is the correct way in my opinion.
  18. Dec 6, 2024 at 7:07 PM
    #238
    RayInAalaska
    RayInAalaska Well-Known Member
    Alaska's interior (near Fairbanks)
    2023 Tacoma TRD Off Road, sort of green color
    It is your truck and your money, and this is what I do with my vehicles: during the summer the ambient temperature could be from 50 to 70 degrees, so when I start the engine (cold start), the ECU kicks it into high idle, then in a couple of minutes the RPM comes down to mid-idle, and a minute or two later it drops to normal idle speed; that's when I drive it. If the temperature is around 30 degrees, I let both the engine and the cab warm up before I drive the truck. It also gives me time to scrape the ice from the windshield and windows. If it is -20 or even -30 degrees, I let it warm up even longer before I drive.
    If it is colder than -30, I don't drive unless there is an emergency :)
    If the temperature is -10 degrees and colder and I arrive to the supermarket to buy groceries, I keep the engine running with the remote starter to keep the cab warm enough for the produce (tomato, avocado, lettuce, flowers for my wife-for example-and so on from freezing. Also, if I am taking photos of the Auroras, my truck's engine is idling while I take some photos a few feet away from the truck, then I get in the cab to warm up, then out to take more photos, and so on. It could take from 1 to 4 hours of idling. By the way, if you drive a diesel truck in the winter, you already know what I am talking about.
    Yes, the EPA and others will tell you that it makes no sense to warm the engine of a modern automobile, right? Even some (not all) automobile manufacturers will tell you warm it up for just a few seconds, and the reason for this is that letting the engine idling burns fuel. It does not look good for the truck in the CAFE standards. That's another reason for using 0W-20 and thinner oils these days; better fuel mileage.
  19. Dec 7, 2024 at 8:00 AM
    #239
    Ronk44
    Ronk44 Well-Known Member
    Rockerville, SD
    2017 MGM Sport
    Leveled with Bilstein 5100 shocks, Falken Rubitrek AT 265/75 tires, Redline hood struts, R4T tailgate lock, Matt Gecko LED strips in bed and under hood, WeatherTech hood guard, OEM bed mat, Husky floor mats, Carhart seat covers, Grille replacement with Toyota letters, Sony AX6000 head unit, OTT lite/mild tune, and an occasional splash of fuel additive.
    30 seconds or so after start, and I’m in drive or reverse and moving. If really cold, I remote start with heater on, but not needed most of the time.
  20. Dec 7, 2024 at 8:12 AM
    #240
    Vinman02
    Vinman02 Well-Known Member
    Vince
    2019 Tacoma TRD
    Levelling kit
    I had a neighbour kid back in the day that had a Datsun 240Z.
    Many extreme cold Canadian Winter mornings he would be asking me to boost his car. We always struggled to get it going and I would offer to give it a shot of ether. He would flat out refuse due to the damage it would cause.
    When we would finally get it started without the ether he would immediately rev it to about 4,000 RPM within a second or two of firing.
    ridefreak likes this.
