Warming up the truck still necessary?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Blak Shinobi, Nov 2, 2022.
  1. Feb 13, 2025 at 10:49 AM
    #261
    Williston
    Williston Well-Known Member
    New England
    2014 Tacoma 040 SR5 4x4 DC SB V6 AT5 Tow Pkg Entune+ Mostly stock with a few OEM mods.
    Stock (99.999%) OEM Bed Floor Mat, Front Bed Rail Cargo Net and hooks, Auto-Dim mirror w/Compass and outside Temperature display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. (winter) OEM All-Weather floor mats (summer).
    I start the truck and wait for the for the fan clutch to stop its roaring noise, and for the air-injection pump to stop its loud whining and then reverse itself and shut down. About 30 seconds total and rolling... :proposetoast:
  2. Feb 13, 2025 at 11:50 AM
    #262
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    You're basically repeating what I've been saying since the thread started in 2022. Not sure if you're agreeing with me or explaining to me..
    Vitamins likes this.
  3. Feb 13, 2025 at 1:16 PM
    #263
    Phlogiston
    Phlogiston There are no victims, only volunteers.
    A@!#$@$%#$%
    The wild west
    2016 SR5 DCSB
    I just don't shut my truck off..EVER.
    Wherever i park it, i just let it run and lock the doors. This allows for the engine to be at an optimal temperature anytime i want to drive someplace.
    BRFab, 44-16 Taco, RTX Taco and 6 others like this.
  4. Feb 13, 2025 at 3:09 PM
    #264
    Williston
    New England
    :101010:
    Phlogiston[QUOTED] likes this.
  5. Feb 13, 2025 at 9:58 PM
    #265
    MindlessCorpse
    MindlessCorpse Well-Known Member
    2020 Tacoma TRD sport
  6. Feb 14, 2025 at 5:18 AM
    #266
    MaverickT883
    MaverickT883 Paintless
    Maverick
    Ontario, Canada
    2021 Tacoma TRD Off-road Access Cab
    Check build thread!
    Below 0 I remote start it from the app while I get my coat and work boots on and my stuff ready to go. Gives it a few min to get everything flowing, especially when it's cold.
    TacoManOne likes this.
  7. Feb 14, 2025 at 5:36 AM
    #267
    1994SR54x4
    1994SR54x4 Well-Known Member
    I start my truck when I get into the cab and then it takes 15 to 20 seconds to get strapped in, plug phone in, pick my nose, etc. before I head out. My neighbor has a 2014 Nissan truck that he doesn't wait one second before heading out and it's running fine so maybe no warmup is OK?
  8. Feb 14, 2025 at 8:00 AM
    #268
    Horseshoez
    Horseshoez Well-Known Member
    Dale
    Maryland
    These aren't air cooled engines with a choke bore which require warming up, there is absolutely zero reason to let the engine run longer than it takes to get your seatbelt on and the mirrors checked, regardless of how cold it is outside.
    Phlogiston, Williston and ToyoTaco25 like this.
  9. Feb 14, 2025 at 8:21 AM
    #269
    canuck guy
    canuck guy Well-Known Member
    Alberta
    23TRDOR
    I can think of some reasons without even trying. -30. If you haven't experienced it don't knock warming up until at least defroster keeps breath from fogging up inside of windshield and windows. Also snow on windshield and vehicle, heavy frost on vehicle and windshield.
    Vitamins and BC Hunter like this.
  10. Feb 14, 2025 at 8:27 AM
    #270
    ToyoTaco25
    ToyoTaco25 Well-Known Member
    North Carolina
    09 Super-White DCSB 6-Speed
    ProComp 4" D-Bag, I mean Drop Bracket Lift, AMP Research Powersteps, 285/70-R17’s, Magnaflow, AFE CAI, Dipped Badges
    Necessary?
    Is it necessary for me to drink my own urine? No, but it’s sterile and I like the taste…
  11. Feb 14, 2025 at 9:30 AM
    #271
    Horseshoez
    Dale
    Maryland
    Those have nothing to do with the engine.
    Speedfreak and Phlogiston like this.
  12. Feb 14, 2025 at 9:42 AM
    #272
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    Not directly, no, but try turning the steering wheel when the power steering fluid is -30°. And if you think the transmission is clunky and slow normally drive without letting the fluid warm up a bit and really see how bad it is. The engine warms up all of that.
  13. Feb 14, 2025 at 9:57 AM
    #273
    Horseshoez
    Dale
    Maryland
    True, but by driving the vehicle instead of letting it idle, both will warm up in a fraction of the time; that and I fail to see how the engine can warm up the transmission for those of us who do not have Tacoma's which use the radiator for transmission cooling.
  14. Feb 14, 2025 at 10:04 AM
    #274
    crazysccrmd
    Alaska
    Aprilia Tuareg 660
    The heating is conducted through the engine block/transmission mating surfaces in addition to being generated by the fluid friction just being pumped around and air warmed in the engine bay by engine heat. In cold climates we use block heaters and oil pan heaters and if you check the transmission temp after a couple hours of being plugged in it is warmed just via heat transfer through the metal.
  15. Feb 14, 2025 at 10:08 AM
    #275
    SH10151
    SH10151 Farang
    SF Bay Area
    2022 SR AC UP 4x4
    Back when we were still getting the neutered M3 in the US, you would get a dummy light telling you not to go balls out in the car until the engine had warmed up sufficiently.
    I like how the active shutters choke modern cars to heat them up faster when it’s cold.
  16. Feb 14, 2025 at 10:15 AM
    #276
    canuck guy
    Alberta
    23TRDOR
    Wrong !!
    Has everything to do with the engine !!
    The heater and defroster will only work well by blowing warm air when the engine is at operating temp.
    A cold engine blows cold air from the heater and defroster.
    BC Hunter likes this.
  17. Feb 14, 2025 at 10:17 AM
    #277
    Horseshoez
    Dale
    Maryland
    Sorry, a manual transmission will bleed heat faster than any minute amount of heat which may happen to reach it from the engine bay.
  18. Feb 14, 2025 at 10:17 AM
    #278
    Horseshoez
    Dale
    Maryland
    Once again, this has nothing to do with the engine.
    Phlogiston likes this.
  19. Feb 14, 2025 at 10:31 AM
    #279
    SH10151
    SH10151 Farang
    SF Bay Area
    2022 SR AC UP 4x4
    Unless you have some fancy car with an auxiliary heater, your engine coolant is feeding your heater. And if the coolant is cold, your heater is cold.
  20. Feb 14, 2025 at 10:53 AM
    #280
    crazysccrmd
    Alaska
    Aprilia Tuareg 660
    Not true. Been there and done that with instrumented testing, not just anecdotal experience or hearsay.
