Warming up the truck still necessary?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Blak Shinobi, Nov 2, 2022.
  1. Nov 3, 2022 at 5:23 PM
    #81
    Little Lion
    Little Lion Well-Known Member
    2018 Barcelonian Sport MT
    worth the risk honestly :bananadead:
    wilcam47 likes this.
  2. Nov 3, 2022 at 6:36 PM
    #82
    Horseshoez
    Horseshoez Well-Known Member
    Dale
    Maryland
    But considering the fuel you burned during the warm up, worse fuel economy.
  3. Nov 3, 2022 at 6:47 PM
    #83
    psychic_legume
    psychic_legume Well-Known Member
    2002 White Tacoma TRD
    I usually let it warm long enough to move the needle, only bc my commute is 10 min of 3.5k powering up a pass. Same coming back down. I'll put the t-case in N and leave the transmission in gear, helps the shifts feel smoother.
    fatfurious2 likes this.
  4. Nov 3, 2022 at 6:55 PM
    #84
    specter208
    specter208 Well-Known Member
    California
    2017 TRD SPORT ACLB w/ 6MT TRUCK WHITE
    TOYOTA OEM: Cast Aluminum Running Boards Mud Guards Bed Mat All-Weather Floor Liner NIssan Frontier Sliding Bed Extender
    I notice too. I have 4.0 Tundra and the needle gets to operating temp super fast.
    Junkhead[QUOTED] likes this.
  5. Nov 3, 2022 at 7:03 PM
    #85
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Why do you guys drive slowly while it's warming up? Are you worried about mechanical damage?
    wilcam47 and Junkhead like this.
  6. Nov 3, 2022 at 7:09 PM
    #86
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    Yea no.. its a couple minutes, not going to affect economy that much
  7. Nov 3, 2022 at 7:19 PM
    #87
    Sprig
    Sprig Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    If warmups did anything or were necessary the owners manual would tell you to do so. There is nothing in my owners regarding warmups. Maybe in yours, I don’t know.
  8. Nov 3, 2022 at 7:25 PM
    #88
    TheSt|G
    TheSt|G Well-Known Member
    ‘05 M3, '19 TRD OR, ‘21 Type R
    CSL Bits
    "Warm-ups" often have the opposite of the intended consequence. You want all components warming up at the same speed together, but idling in the driveway just warms the engine and not the trans or diff(s). Hell, my old '85 911 specifically says in the owner's manual to not do any sort of warm-up as it is potentially damaging to the car.
  9. Nov 3, 2022 at 8:54 PM
    #89
    Blak Shinobi
    Blak Shinobi [OP] Well-Known Member
    taco
    2020 MGM Sport DCSB 4x4
    n/a
    did you have to use 91 gas for your 911 porsche? also i wonder if states not to rev it while it warms up, your comment is kind of vague
  10. Nov 3, 2022 at 9:00 PM
    #90
    TheSt|G
    CSL Bits
    Technically 92 is the min, so 93.
  11. Nov 3, 2022 at 9:05 PM
    #91
    Blak Shinobi
    taco
    n/a
    :playball:
    thats because its a high compression engine , the tacoma is a low compression
  12. Nov 3, 2022 at 9:21 PM
    #92
    TheSt|G
    CSL Bits
    ‘85 911 is 9.5 to 1
    2GR-FKS in the Tacoma is 11.8 to 1
    So no, that would be incorrect.
  13. Nov 3, 2022 at 9:29 PM
    #93
    Blak Shinobi
    taco
    n/a
    :bananadead:
    dangg googled has failed me, but i do like your comparison from apples to oranges
  14. Nov 3, 2022 at 10:28 PM
    #94
    libagui
    libagui Well-Known Member
    Dominican Republic
    05 tacoma prerunner
    Bilsteins 5100 set at .085 Rear custom 1" add a leaf 265/70 R17 tires. Custom made aluminum tonneau cover with bike rack. 4x4 conversion with 4Runner transfer case.
  15. Nov 3, 2022 at 10:38 PM
    #95
    erok81
    erok81 Well-Known Member
    Imposter
    Fast forward a Scotty video!? Blasphemy.
    2021SR5V64WD[QUOTED] likes this.
  16. Nov 3, 2022 at 11:10 PM
    #96
    MaverickT883
    MaverickT883 Paintless
    Maverick
    Ontario, Canada
    2021 Tacoma TRD Off-road Access Cab
    Check build thread!
    If it’s below 0, I usually remote start it and let it warm up while I brush it off, grab the stuff I need, my jacket etc. gives it a while to get the gooop that fuel and ATF is in the negatives. In the summer? Start it, 10 seconds to plug my phone in, drive conservatively for 1-3 min, and she’s good.
  17. Nov 3, 2022 at 11:37 PM
    #97
    davidstacoma
    davidstacoma Friendly Curmudgeon
    David
    NC
    2019 Tacoma SR Access cab - Utility
    *OEM Mods: Intermittent wipers, Fogs, Keyless Entry, Lomax
    Internet search tends to indicate a 30 second warmup (15-30 usually cited) is all that’s needed to allow oil to flow well for vehicles that are fuel injected. The same is not true for carbureted engines which need a longer warmup.
  18. Nov 4, 2022 at 5:23 AM
    #98
    Horseshoez
    Dale
    Maryland
    No sorry, any warm up longer than the time it takes to click on your seat belt and click off the parking brake will negatively impact fuel economy.
  19. Nov 4, 2022 at 5:30 AM
    #99
    fatfurious2
    David
    Ashburn, VA
    It doesn't for me, so..
    wheres your proof
  20. Nov 4, 2022 at 5:31 AM
    #100
    Horseshoez
    Dale
    Maryland
    Simple science. Where's yours?
