Warming up the truck still necessary?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Blak Shinobi, Nov 2, 2022.
  1. Nov 4, 2022 at 12:54 PM
    #141
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    :rofl:Yeah, I guess I missed that one.
    You never know what is and isn’t serious in a thread like this one.
    Since we’re on the subject, I guess I’ll answer.
    If it is really cold (20 degrees F or lower). I usually drive it easy until the temperature gauge starts to climb. I used to let my previous vehicles warm up, but I’m getting older. My patience is shorter, and time is more value.
    Sprig and Junkhead like this.
  2. Nov 4, 2022 at 12:54 PM
    #142
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
  3. Nov 4, 2022 at 1:27 PM
    #143
    Gen3TacomaOBX
    Gen3TacomaOBX Well-Known Member
    S
    2018 Tacoma DCSB SR 4x4
    Bilstein 6112 front / 5100 rear (extended) shocks, Headstrong AAL, Firestone airbags, 4.88 gears, OME Carrier bearing drop kit, Aluminum 1/4" skids (engine to transfer). Custom sliders (1.75" HREW tube w/ 3/16" base plates). Custom front bumper and high clearance rear bumper (1/4" steel plate, 1.75" tube.) Apex 5500 winch w/synthetic line (36lbs) and required accessories for an underpowered winch (snatch blocks and extra line.) Tekonsha P3 brake controller, remote start, any-time-backup camera w/ front facing camera, Leer 100R shell (w/e-track single slot tie-down mounts for removable Yakima EasyTop.) Cat shields by CaliRaised. Husky liners, window tint, heated seat (passenger only.) Relentless bed rail brackets with QuickFists (shovel/axe/fire extinguisher.) Hondo Garage Un-holey vent mount. Anytime rear with front facing camera. Billet front seat risers. Viair 88p. 265/75r16 Goodyear Ultra-terrain tires.
  4. Nov 4, 2022 at 1:56 PM
    #144
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    Don't quote me, as I think I heard on this Forum, that we have an electric heater to heat up the cab sooner.
    Regardless, you certainly don't need long to warm up a vehicle in warm weather. You could drive away slowly and the temp. will climb quickly. In the winter, you could do the same, but you can hear the engine struggling a little more. Personally I wouldn't hop on a Highway right away without a bit of a warm up from driving it.
    Junkhead likes this.
  5. Nov 4, 2022 at 1:56 PM
    #145
    saint277
    saint277 Vigilo Confido
    boom, quoted;)
    Tocamo[QUOTED] likes this.
  6. Nov 4, 2022 at 1:57 PM
    #146
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    Bada boom! I too just got quoted... :D
  7. Nov 4, 2022 at 2:05 PM
    #147
    oneikr
    oneikr Well-Known Member
    2024 GMC Sierra 1500 Denali
    100% agree. My Tacoma starts at about 1200-1300 RPM's and will come down after 20-30 seconds. The Porsche starts at 1300 RPM and settles in at 700 after 30 seconds and the BMW is about the same. I agree with letting it "change pitch" before driving.
  8. Nov 4, 2022 at 2:06 PM
    #148
    TacoTime55
    TacoTime55 TT58
    Ed
    Delaware
    2021 Midnight Black TRD Sport AT/DCSB
    TRD Lift,OTT Tune, LED HLs,TRDSkid, TalonCAT
    @Gear Jamin Jamie
    Hilarious!
    "making duck lips"
  9. Nov 4, 2022 at 2:09 PM
    #149
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    If you select defrost button, it uses elements to heat up the air and defrost your windshield.
  10. Nov 4, 2022 at 2:28 PM
    #150
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    best to send it... like this...
  11. Nov 4, 2022 at 2:32 PM
    #151
    saint277
    Carbureted engines needed to warmed up for perforce reasons, very easy to stall one if too much load is given before the engine is warmed up. Also modern diesels need the be warm up from very cold starts, again for performance reasons. Don't think this holds up.
  12. Nov 4, 2022 at 2:41 PM
    #152
    Gear Jamin Jamie
    Gear Jamin Jamie Well-Known Member
    Jamie
    Lacey, WA
    2022 Access Cab Sport MT Super White
    Gun safe, predator steps, rear bumper step
    Yup right there! I get to see that every day...
    wilcam47[QUOTED] likes this.
  13. Nov 4, 2022 at 3:14 PM
    #153
    Otterstuff
    Otterstuff Well-Known Member
    2022 White SR5 Access Cab 4WD V-6
    Tube steps, Vision Turbine wheels, bug deflector, seat covers, and tonneau cover
    Depends on if you need warm air to defrost your windshield. Winters used to be so cold your breath would freeze on the inside before your defroster was warm enough to remove it.
  14. Nov 4, 2022 at 3:17 PM
    #154
    wfo479
    wfo479 Well-Known Member
    NE Ohio
    2020 TRD Pro
    I give it a few mins to warm up.
    Im old and ive been doing it forever. Doesnt hurt anything, just habit
  15. Nov 4, 2022 at 5:06 PM
    #155
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    Gonna have to disagree with this one. The fact that removing the oil filter drains out a bunch of oil proves that the oil filter is keeping oil up in the motor. That’s the whole point of the ADBV. And for whatever does drain out (in the bearings for instance), the mechanical oil pump sure does get it pumping quickly….but even if oil runs out of the bearings, it takes practically no time to pump more oil there if the passageways are filled with oil which they should be due to the ADBV.
  16. Nov 4, 2022 at 5:12 PM
    #156
    ExGunner
    ExGunner Well-Known Member
    Paul
    2017 Tacoma TRD Sport Blue
    You dont have to warm it up nearly as much as previously. The Tacoma uses Port injection when cold and that with i think retarding the timing a bit helps get the engine to temp faster. I still installed a remote starter and have my defroster set to max fan and temp to start defrosting the windshield before i get outside. The engine doesn't need warming up as much but in winter i still need to de-ice and clean the truck off often and letting things warm up helps that process along better regardless of what the engine needs.
  17. Nov 4, 2022 at 5:26 PM
    #157
    Mr.Hustler
    Mr.Hustler Well-Known Member
    2018 Magnetic Grey Metallic TRD Off Road 4x4 [AT]
    It's a secret
    I pee on the engine block to pre-warm it up before I press the starter button to normal-warm up...then while at idle, I depress the brake, shift from Park > Drive > Neutral > Reverse > Drive > Park > Neutral > Rev motor to 6.2k RPM redline and hold for 45 secs > while holding RPM at redline I drop it in Drive...
  18. Nov 4, 2022 at 5:58 PM
    #158
    Blak Shinobi
    Blak Shinobi [OP] Well-Known Member
    taco
    2020 MGM Sport DCSB 4x4
    n/a
    is your urine yellow, orange or clear? if its orange you have to do this process all over again until your urines is clear :anonymous:
    Mr.Hustler[QUOTED] likes this.
  19. Nov 4, 2022 at 6:03 PM
    #159
    Mr.Hustler
    It's a secret
    Its a tinge of green from all the Monster I drink...actually...its kinda fluorescent...yeah...like Peaks 50/50 coolant...
  20. Nov 4, 2022 at 6:07 PM
    #160
    Blak Shinobi
    taco
    n/a
    yep your not doing anything right , you also have to wear a tinfoil hat:hattip:
