Warming up your 3rd gen for winter driving
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TacomaIan, Nov 15, 2017.
  1. Nov 16, 2017 at 5:25 AM
    shackley
    shackley Well-Known Member
    Albuquerque, New Mexico
    2018 TRD Pro MT Super White
    RCI rock sliders, Goodyear Ultraterrains 265/70/R16, BAK X2 tonneau
    It seems to warm up faster than the 4.0L 2013 I had, but it hasn't got down below about 35 degrees F in Albuquerque yet with my 2017.
    over60 likes this.
  2. Nov 16, 2017 at 5:29 AM
    kystnTRD
    kystnTRD Ramblin Man
    NW Pennsylvania
    2016 TRD Sport 6MT
    I don't know if it has anything to do with it but my manual tranny Tacoma warms up very slowly. Like others have said. I usually just get in it and go. Heats up fast that way. Only time i let it warm up at idle is when it dips into the single digits
    tonered likes this.
  3. Nov 16, 2017 at 5:30 AM
    shackley
    Hey, did you design that gif or whatever it is of the truck? Cool.
  4. Nov 16, 2017 at 5:30 AM
    Jcyr
    Jcyr Midnightthetaco
    Jack
    North east
    3RZ 04 4x4 black ext cab
    2.5" lift king/total chaos Skids sliders rear tire swing
    A block heater for your home will fix this issue right away
    akTacoBlanco likes this.
  5. Nov 16, 2017 at 6:02 AM
    a400ryan
    a400ryan Well-Known Member
    Garson Manitoba Canada
    2015 SR5 DCLB
    I’ve also heard about the elec element in the core but no back up info
    I’m not a fan of the auto climate control only able to use floor heat. You change the direction and it goes off auto
    over60 likes this.
  6. Nov 16, 2017 at 6:06 AM
    RichVT
    RichVT Well-Known Member
    Rich
    Northern Vermont
    2016 Tacoma TRD Off Road 4X4 AC Grey
    I can't find any info on what conditions/settings cause the electric heating element to come on.
  7. Nov 16, 2017 at 6:13 AM
    omgwtfbbq!
    omgwtfbbq! Well-known Idiot
    Ohio
    2013 X-Runner
    If your oil isn't in the heads within seconds of starting the truck your valvetrain wouldn't last past 50k miles. Oil flows everywhere very quickly, modern engines have check valves to prevent backflow when the engine is off, so the galleries all have oil in them already. Modern vehicles can be started, put in to drive, and immediately driven with no undue damage to anything, this is doubly true of anything that utilizes stop/start.
    Paul631, Jaque8, over60 and 2 others like this.
  8. Nov 16, 2017 at 7:34 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I usually fire the truck up then scrape the windows or clean snow off, heated seats help greatly.
    Taco Fan likes this.
  9. Nov 16, 2017 at 8:26 AM
    pjensen641
    pjensen641 Well-Known Member
    Boone, IA
    '17 MGM ACLB Sport Manual
    The 3.5 heats up extremely fast when you start to drive. It begins to blow warm air soon after the needle rises of the cold peg (3-4 minute of driving). I don't let mine idle for more than a minute unless I need to scrape (usually garaged so no need to scrape).
    If Its below 20 I normally plug in. That gets the engine up to 70°F before starting. The block heaters on these are really nice to install. Its a cartridge style, no need to break in to the cooling jacket. Helps with fuel economy too.
    over60 likes this.
  10. Nov 16, 2017 at 8:30 AM
    rlx02
    rlx02 ¯\_(ツ)_/¯
    Western WA
    2017 Inferno DCSB TRD OR 4x4
    Right, letting the engine warm up is an outdated automotive adage, like changing your oil at 3000 miles. The only reason to "warm up" now is to blow warm air inside as OP stated.
    jsey21 and Jaque8 like this.
  11. Nov 16, 2017 at 8:43 AM
    TacomaIan
    TacomaIan [OP] Well-Known Member
    Ian
    Alberta Canada
    2016 Canadian Limted
    Wasn't idling for 10 minutes, maybe 2 minutes then started driving. 10 minutes run time before getting much heat.
  12. Nov 16, 2017 at 8:45 AM
    TacomaIan
    Ian
    Alberta Canada
    Is there an electric heater?
  13. Nov 16, 2017 at 9:56 AM
    Shootermg5
    Shootermg5 Active Member
    Canada
    2017 TRD Sport 6MT Barcelona Red
    The auto climate will change depending on the need. If the truck senses frost on the windshield, it'll kick in the windshield blowers then turn off once gone.
    I believe even when the auto climate button isn't on, say you prefer front vents, the climate control will still regulate blower speed based on selected temperature.
    I'm still learning how this truck thinks and reacts in cold weather.
  14. Nov 16, 2017 at 9:58 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
  15. Nov 16, 2017 at 10:06 AM
    #35
    Herniator
    Herniator Well-Known Member
    Edmonton
    2016 Toyota Tacoma TRD Sport
    chrome valve stems covers
    The you shut off the Truck. Turn your seat heaters on. Turn on defrost and set the fan too high. The electric heater is supposed to come on when temp is at high and I also believe the defrost has to be on. Other then that just start the Truck and make sure the windows are clear before driving away.
    tonered likes this.
  16. Nov 16, 2017 at 10:11 AM
    #36
    vicali
    vicali Touch my camera through the fence
    mike
    Kam,BC
    2017 TRD Sport 1D6
    Scanguage shows it warms up pretty quickly. I usually start it up, clear off the windows, and get back in and drive away.
    By the time I'm on the street it's already cwt 50C, normal running is around 70-90C.
  17. Nov 16, 2017 at 10:13 AM
    #37
    QuickBurn
    QuickBurn Well-Known Member
    I idle mine for 30 seconds to a minute and off I go. by the time I hit the round about 3 minutes from the house I have warm air even on the coldest of days.
    dnlskier likes this.
  18. Nov 16, 2017 at 10:21 AM
    #38
    PCTaco
    PCTaco 36 hour Build
    Adam
    New Columbia, PA
    '18 Access Cab TRD Offroad RIP '13
    Working on it
    I'm glad at least a few people have mentioned that letting an injected engine idle to operating temps is terrible for it. It will run rich causing incomplete burn in the cylinder, and as gas is a solvent it causes increased wear due to dilution of the oil.
    Running rich is also bad for the catalytic converter.
    coma toy likes this.
  19. Nov 16, 2017 at 10:38 AM
    #39
    OdiN1701
    OdiN1701 Well-Known Member
    Colorado
    2017 Quicksand TRD OR DC SB
    I warm it up sometimes. Sometimes you have to just to get all the snow and ice off.
    over60 likes this.
  20. Nov 16, 2017 at 10:48 AM
    #40
    dnlskier
    dnlskier Well-Known Member
    17' TRD SPORT MT
    This what I do, fire it up, then get back out to scrape the ice and remove all the snow. I'm usually dressed for cold weather, never noticed if the truck takes longer vs any other car I've owned...
    shakerhood likes this.
