warming up your truck
Discussion in '2nd Gen. Tacomas (2005-2015)' started by proto, Nov 4, 2010.
  1. Nov 4, 2010 at 3:37 AM
    proto
    proto [OP] Active Member
    11' access cab 4x4
    so my whole life i've lived in a warm climate(fl) so i've never really needed to use heat lol, now i got moved to upstate ny and was wondering with a manual truck how do i warm it up in the morning? i can't sit in the car all morning with my oot on the clutch so warm air can defrost everything i need to to get my uniform on so what do i do?
  2. Nov 4, 2010 at 3:41 AM
    Mark C.
    Mark C. If you want it bad, you usually get it bad!
    Mark
    Connecticut
    2010 MGM SR5 4WD AC
    LED Dome, Reed Switched LEDs in Glove Box and Center Console, Bumper Fogs, Tailgate anti-theft, LEDs over Cig lighter, Back-up camera anytime, Outside Temp add-on, Hidden GPS power, Sockmonkey 3rd Brakelight decal, 4X4 switch illumination, reed switch controlled engine compartment Flood LEDs, Elite Hitch Cover, Plasti-dipped cupholders and door switch control panels, Elite Hitch Cover.
    Put it in neutral, set the E-brake, and let it warm up. Or....you can just jump in and let it warm up under load, which is better for the engine.
  3. Nov 4, 2010 at 3:42 AM
    TacoCat
    TacoCat These pretzels are making me thirsty
    Johnny-5
    Chantilly, VA
    22 JLUR 6MT
    Make sure the e-brake is on and leave it in neutral. I'm a little skiddish leaving mine on a sharp incline with just the e-brake though, I've seen them fail before.
  4. Nov 4, 2010 at 3:43 AM
    TACOMA TRD
    TACOMA TRD Well-Known Member
    Tom
    PA
    2011 MGM SPORT DC 4x4
    Alpine HU, Apline 6.5 3 way Speakers, Access Cover.
    Hit the key, slam it in drive. I have mine in drive before the starter stops spinning and i live in cold climate too. Many discussions on this topic, You can seach this.
  5. Nov 4, 2010 at 3:50 AM
    larryirun
    larryirun Member
    I'm assuming you are stationed at Ft. Drum. I live nearby and rarely let my Tacoma warm up for more then 15 seconds unless the temp dips below zero. I did install an engine block heater and will use it when it gets below 10 degrees (F). Keep an ice scraper and snow brush IN your house to make it easier in the mornings. Last winter was not too bad up here, very little snow after New Years.
  6. Nov 4, 2010 at 4:21 AM
    proto
    11' access cab 4x4
    yeah ft drum. thanks for the info guys it's been about 4 years sine i've drivin' a manual car or truck and in fl i never once used heat. so this whole warming your car up in a fairly new experience for me haha
  7. Nov 4, 2010 at 4:26 AM
    KalamaKid
    KalamaKid Well-Known Member
    Oregon
    same shit as everyone else
    I lived in Washington state for 24 years before i moved to hawaii. Get a Viper remote start system and get it synced with your phone. That way you can start your truck where ever you want. This way you can put on your utilities and then go out to a nice warm pickup. Just wire up the clutchless start and your good to go. SHould be less then $400 with install.
  8. Nov 4, 2010 at 5:10 AM
    Simon's Mom
    Judy or Jude :)
    NEK Island Pond VT
    24 Tundra Trd Sport former 13 TRD OR
    Stock for now
    ah Ft drum it was my last duty station
    what the others said...the ice scraper and snow brush outside of the truck is an awesome tip. I keep one of the extended brushes under my tonneau.
    when the lake effect snow hits ya you'll have an avalache in your front seat when you open the door.
  9. Nov 4, 2010 at 6:06 AM
    proto
    11' access cab 4x4
    yeah i've been thru 2 winters here with 2 different cars both 2wd now after saving up for a year in afghanistan i finally wised up and bought my dream truck so i'm hoping this one holds up in the snow here bette than my other 2 cars.
  10. Nov 4, 2010 at 6:18 AM
    Simon's Mom
    Judy or Jude :)
    NEK Island Pond VT
    Stock for now
    Congrats on the dream truck :woot:
    you know then why the trees are all pointing east...brrrr
    Have fun with your new rig & glad your back in US.
  11. Nov 4, 2010 at 6:23 AM
    pinktaco808
    pinktaco808 Hot Steppa
  12. Nov 4, 2010 at 6:29 AM
    Taco4x4NC
    Taco4x4NC Well-Known Member
    David
    Western North Carolina
    2010 4x4 DC/LB "Pytrite Mica/Katzkin leather
    3m clear bra or Venture, stant locking gas cap, Shield, front windows tinted, weathertechs, ARE "Z" topper. Sockmonkey decal, Billy 5100's x 4 corners, Eibach coils, Toytec 1.5 AAL. Michelin 265/75/16 MS2's, Grillcraft MX series/TOYOTA badging. FJ/SE TRD Anthracite gray wheels. Katzkin leather/heated seats.
    Grew up in Upstate NY, left when I turned 19 and never moved back.
    Fact~ The winters are brutally cold and if the sun shines its part time at best the winters are looooooooooooooooong and depressing.
    Advice- Set the parking brake, I never had one freeze up and fire it up and let it warm up. Have you considered a remote starter? Heated seats?
    Make sure you don't leave it unattended, many vehicles are stolen "warming up" right out of driveways.
    One other piece of advice, find a really good DIY car wash and try and keep as much salt off your truck as you can. They usually open back up when there is a break in freezing temps. Also, NY DOT uses salt more salt on there roads than McDonalds does world wide :eek:, certainly not a fact but sure seemed that way to me as a kid.
    Don't mean to be Danny Downer on the NY winters, I just never looked forward to them as a kid. More sunshine would have helped.:)
    Best of luck,
    Taco4x4nc
  13. Nov 4, 2010 at 6:30 AM
    TacoCat
    Johnny-5
    Chantilly, VA
    22 JLUR 6MT
    Correct me if I'm wrong but...this may be illegal. I don't know if it varies by state but I looked into doing this in Virginia and nobody would do it, citing laws for this.
    That doesn't mean it can't be done though.
