Warn M8000 mounted in a Relentless Fab plate bumper
Discussion in 'Relentless Fabrication' started by bigfella13, Feb 4, 2015.
  1. Feb 4, 2015 at 1:23 PM
    bigfella13
    bigfella13 [OP] Well-Known Member
    Nick
    Colorado
    4 banger 4x4
    Lift, armor and such. Money pit, check out the build thread...
    Has anyone else mounted one in a Relentless plate bumper? I was wondering about options for mounting the solenoid box. Looks like the only option might be in the engine compartment. For those of you who have a relentless bumper already, would therebe enough room to mount the box on top of the bumper like on ARB bumpers?
  2. Feb 4, 2015 at 1:34 PM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    solenoid pack would definitely need to go under the hood somewhere. No room in the bumper, and it's too slim to mount it on top as well.
  3. Feb 4, 2015 at 1:42 PM
    bigfella13
    Nick
    Colorado
    4 banger 4x4
    That's what I thought. Probably going to try to mount it somewhere behind the bumper/grill area and the radiator. I'll post a pic once I figure something out and get it mounted. Thanks for the quick response!
  4. Apr 27, 2015 at 11:03 AM
    bigfella13
    Nick
    Colorado
    4 banger 4x4
    So I received my bumper and was able to find a pretty easy install for the solenoid. I used the bracket that comes with the winch to mount the control box directly to the winch itself. The only difference being that I mounted the front most bolt of the solenoid box into the rearmost hole on the mounting bracket. I only ended up using one bolt to secure it instead of two as intended but it's pretty solid, not worried about it rattling around. The box isn't exposed to the elements with the exception of the little bit of rain that might come through the grill. It was super easy, I didn't have to buy any extra cables or brackets, and I was able to mount to the bumper before install and slide it right in. I did remove the crossmember that goes behind the grill. With A little trimming I could probably get the crossbar back in there, but it doesn't really seem to matter and I've seen a lot of other guys run set ups without it . Here are couple of pics I'll try to get some better ones once the rain stops here.image.jpgimage.jpg image.jpg
    yote and jsway9 like this.
  5. Feb 5, 2021 at 6:55 AM
    yote
    yote Washington State University
    Mark
    Tacoma, WA
    2002 Ext Cab TRD Off-Road
    If anyone was wondering this might’ve worked with the OP’s truck but I’ve got a 1st Gen and it does NOT fit! You’ll need to order a relocation kit for the solenoid pack and likely mount near the passenger wheel well/firewall
  6. Feb 5, 2021 at 7:57 AM
    RelentlessFab
    Eric
    Sparks, NV
    Relocation of the control pack will be necessary for every winch brand/model when mounting into a 1st gen Tacoma front bumper. Smaller truck, smaller bumper compared to the 05+ Mid-size Tacoma's.
    yote[QUOTED] likes this.
  7. Feb 11, 2021 at 9:17 AM
    yote
    Mark
    Tacoma, WA
    Heres the mounting location I used for under the hood. I flattened the WARN mounting bracket and then drilled holes in the corner(s) of the mount near the existing holes so it would match the existing 14mm bolt nearest the open space. There's plenty of room below the top of the fender to bend and route those big solenoid cables too.
    RelentlessFab likes this.
