warning sounds???
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Manoah, Jul 17, 2011.
  1. Jul 17, 2011 at 2:25 PM
    Manoah
    Manoah [OP] Active Member
    Manoah
    San Diego
    mini foot
    spacers, wheels, 285 MT's, smittybuilt step bars. coming soon: trd stooper charger.
    do tacos have a roll over sensor or something? on one right hand turn during my commute to work if im going just a little fast, i get a warning sound, with no dash lights, also what feels like the ABS locking up in the front? its happened twice now on that same turn, only there, and only if im going just a little quick.
    i have a 2011 dbl cab sport 4x2, AT, 4.0L with a two inch spacer lift in the front, and 285/75/17's rest is stock.
  2. Jul 17, 2011 at 2:34 PM
    crf69
    crf69 scraping my emblems off my plasti-dip
    Ohio
    06 TRD OR BSP cab'n 1/2
    ummm yeah
  3. Jul 17, 2011 at 2:39 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    You need to get your skid control ecu re-calibrated after your lift
  4. Jul 17, 2011 at 2:41 PM
    OZ-T
    Peter North
    British Columbia
  5. Jul 17, 2011 at 2:42 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Sounds like traction control kicking in. You probably got a tire spinning and the computer nanny kicked in and fixed that for you.
  6. Jul 17, 2011 at 2:57 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Yep...sounds like the vsc is kicking in. If I remember correctly starting around 2009 or 2010 the issue with the vsc started happening alot on the lifted trucks where the yaw sensor needs to be recalibrated, but this is the first time I heard of it going on with just a 2" lift...especally just the front being lifted. I'd say maybe it's just doing it's job and you need to slow down a bit.
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/112351-vsc-lift-interaction-how-common.html
    http://www.tacomaworld.com/forum/technical-chat/60077-problem-when-taking-turns.html
  7. Jul 17, 2011 at 3:32 PM
    Manoah
    Manoah
    San Diego
    mini foot
    HAHA! youre probably right, but its hard, ive also got a 2011 bmw 335i and a 2010 yamaha LE R1, its hard to train my brain to slow down. and honestly, i dont really feel that im going too fast. i'll make a conscious effort to slow down.
  8. Jul 17, 2011 at 3:37 PM
    OZ-T
    Peter North
    British Columbia
    Just get your computer recalibrated , as per my second post
  9. Jul 17, 2011 at 3:37 PM
    Manoah
    Manoah
    San Diego
    mini foot
    is this something i can do myself? or take it back to dealer for recalibration?
  10. Jul 17, 2011 at 3:38 PM
    OZ-T
    Peter North
    British Columbia
    Take it to the dealer
  11. Jul 17, 2011 at 3:39 PM
    Manoah
    Manoah
    San Diego
    mini foot
  12. Jul 17, 2011 at 7:54 PM
    Manoah
    Manoah
    San Diego
    mini foot
    thank you for the quick help, i appreciate the fast responses.
  13. Jul 17, 2011 at 9:24 PM
    kanaka808
    kanaka808 Well-Known Member
    jason
    henderson
    2010 4x4 sport
    did vsc come standard or was it an option?? how do i know if my truck is equipped with vsc??
  14. Jul 17, 2011 at 10:50 PM
    OZ-T
    Peter North
    British Columbia
    Standard on '09 and up
