Warrior Products - 2016 Toyota Tacoma Racks
Discussion in '3rd Gen. Tacomas (2016-2023)' started by WarriorProducts, Dec 2, 2015.
  1. Jun 9, 2017 at 8:39 AM
    #61
    WarriorProducts
    WarriorProducts [OP] Well-Known Member
    WarriorProducts
    2011 Toyota Tacoma / Blue
    Total Chaos Suspension, Fox Shocks, 3" lift, 33" Nitto Trail Grapplers, Warrior Front Bumper, Rear Bumper, Side Steps, Bed Rack, Roof Rack, Side Plates, Entry Guards, Spare Tire Carrier, Lower Tailgate Cover, Wurton LED's
    Alright, you guys asked for images - we give you images! We apologize if this is considered spam, but it was too hard to narrow it down.
    [​IMG] [​IMG] [​IMG]
    Wallbright likes this.
  2. Jun 9, 2017 at 8:41 AM
    #62
    WarriorProducts
    WarriorProducts
  3. Jun 9, 2017 at 8:43 AM
    #63
    WarriorProducts
    WarriorProducts
  4. Jun 9, 2017 at 8:11 PM
    #64
    L3TT3RS
    L3TT3RS Well-Known Member
    Taylor
    Longview, Texas
    2019 Tundra-> Fox/Total Chaos/Coachbuilder
    How about some pics with the tailgate down and some of how the taco mounts etc?
  5. Jun 9, 2017 at 8:22 PM
    #65
    Wallbright
    Wallbright Well-Known Member
    2017 MGM DCSB SR5
    What's the best way to seal around the roof rack where it connects to the truck? Just throw some silicone on all the edges I guess?
  6. Jun 11, 2017 at 10:01 PM
    #66
    Wallbright
    2017 MGM DCSB SR5
    Installed it today. Ended up just siliconing all down the holes and around them to be safe.
    Some tips for any buying this rack, make sure you dry fit your truck before you silicone around the holes haha. I posted before, but my holes in my truck were misalgined and had issues so the dealership had to cut out a piece of metal that was covering part of the holes and then re-tap the screw hole since it wasn't done correctly the first time. Also, found out WD-40 gets silicone off your truck if you get it on the paint.
    I installed mine set back a little so that the shark fin is completely unobstructed. The directions wanted it forward more but that clearance left me a little hesitant.
    WarriorProducts[OP] and steveox like this.
  7. Jun 12, 2017 at 2:18 PM
    #67
    WarriorProducts
    WarriorProducts
    Here are some pics of the mounts for the bed rack. Keep in mind that the tie bar can be mounted either front, or back on the rack and is optional. We tend to load our bed rack up, so we prefer to use it. Plus, it stiffens the bed!
    daohaus and L3TT3RS[QUOTED] like this.
  8. Jun 14, 2017 at 9:22 PM
    #68
    Wallbright
    2017 MGM DCSB SR5
    If anyone is wondering about the shark fin antenna here is the spacing with it on the way I have it. Plenty of room.
    WarriorProducts[OP] likes this.
  9. Jun 14, 2017 at 9:39 PM
    #69
    daohaus
    daohaus Well-Known Member
    Duan
    33.960892 -117.575824
    18 TRD Off Road Premium 4runner
    Rotiform SIX OR Toyo Open Country RT
    What bed rack are you using
  10. Jun 14, 2017 at 11:13 PM
    #70
    steveox
    steveox Well-Known Member
    steve
    2021 TRD Off-road DCLB.
    RCI
    daohaus[QUOTED] likes this.
  11. Aug 17, 2017 at 12:10 AM
    #71
    jasontylers
    jasontylers Well-Known Member
    JT
    2016 Tacoma TRD Off Road
    None.
    Will the bed rack work under a softopper with a tepui tent mounted on it? Looks like it has room on the bed rails. If so I'll order one today.
  12. Aug 31, 2017 at 9:03 AM
    #72
    WarriorProducts
    WarriorProducts
    It will not work under the softopper. The Warrior Bed Rack does use the entire length of the bed rails on the short bed Tacoma. There is about 12" of bed rail remaining on the long bed models.
  13. Mar 16, 2018 at 11:41 AM
    #73
    jeremy5000
    jeremy5000 Well-Known Member
    Philadelphia
    Now that they've been out quite a while, anyone have anything good or bad to say about the Warrior bed rack?
  14. Mar 20, 2018 at 5:39 AM
    #74
    schmack13
    schmack13 Active Member
    Adam
    2016 Quicksand Tacoma Off Road
    Warrior Bed Rack Tepui Tent
    Mine has been rock solid. I didn't install the cross member because I didn't want to lose any more bed space. I've had no issues.
    jeremy5000[QUOTED] likes this.
  15. Mar 20, 2018 at 6:41 AM
    #75
    Gnarman
    Gnarman Well-Known Member
    Southwest
    2016 dbcb trd off road quicksand lb
    ARB Shell, BP51, 255/85/16 ST MAXX, SCS Ray 10 Matte Bronze, Caliraised led 32 inch/side shooter/amber pods, floor mats, start x remote start, auxbeam 8 gang switch panel, diode dynamics hid lows, Australian Shepherd
    @WarriorProducts awesome products but you guys need a new website badly. It's not mobile optimized and doesn't have a call to action when you cclic on the specific vehicles. I can put you in touch with someone who can help if you are interested. Love the products but I work in the space and have to help!
  16. Mar 20, 2018 at 9:51 AM
    #76
    wjrichardson
    wjrichardson Well-Known Member
    WI
    2017 TRD/OR/AC
    Have had mine nearly two years now. The only bad thing I will say about it is that you lose almost all of your bed rail space due to the design of the side panels. You'll have a little room on the front or the back depending on long bed or short bed. If you plan to use the bed rails for other accessories this isn't the rack for you. Otherwise, it's been solid. All the hardware is holding up well. Assembly/disassembly is pretty straightforward. I did use the cross member, put it in the back position. Because this just uses the bed rails for attachment I feel a lot better having it in there due to mounting a rooftop tent on mine.
  17. Mar 20, 2018 at 10:32 AM
    #77
    batong_23
    batong_23 vincedprince
    SoCal
    2017 white toyota tacoma trd sport
    where can i get them?
  18. Mar 21, 2018 at 7:37 AM
    #78
    WarriorProducts
    WarriorProducts
    Thanks... and yes we definitely do need a new website. We are in the process of designing a new website from scratch, which will, of course, be mobile friendly and include many more features to allow users to find parts and information more easily. It's been long overdue, but it's finally happening! We hope to have it complete and launched in June or July so keep an eye out.
    jeremy5000 and Wallbright like this.
  19. Mar 21, 2018 at 7:39 AM
    #79
    Wallbright
    2017 MGM DCSB SR5
    :dancingbacon: :broccoli: :dancingbacon: :broccoli: :dancingbacon: :broccoli:
  20. Mar 21, 2018 at 7:39 AM
    #80
    WarriorProducts
    WarriorProducts
    Where are you located? I can get you a list of dealers in your area. If you are having trouble finding the parts you are looking for, give us a call and we can get you taken care of. 888.220.6861
