Washer nozzles
Discussion in '1st Gen. Tacomas (1995-2004)' started by ARB1977, Jun 3, 2015.
  1. Jun 3, 2015 at 4:10 AM
    ARB1977
    ARB1977 [OP] It’s a beaut Clark
    North Texas
    15 DCSB Prerunner 4.0L Blue Ribbon Metallic
    Black TRD Fj Cruiser wheels, TRD catback exhaust.
  2. Jun 3, 2015 at 6:10 AM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Pop the hood and see if the stock nozzles have the elbow. If they do then you're golden.
  3. Jun 3, 2015 at 12:29 PM
    ARB1977
    North Texas
    Thanks
  4. Jun 3, 2015 at 3:34 PM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    no, you need the ones that go straight down or out to the side not out the back.
    the reason is there is a hood support in back of it so the hose will be smashed into it and not fit.
    this is what you need: http://www.ebay.com/itm/2pcs-Toyota...zle-/161265136675?hash=item258c26b423&vxp=mtr
    and just as a foot note, I tried those fan spray nozzles and they don't work worth a crap unless your stopped, at speed on the road it just dribbles all over in spots. I bought these to go back to the two streams and suggest you do as well.
  5. Jun 3, 2015 at 5:02 PM
    NightProwler
    NightProwler Well-Known Member
    Harlan
    Maricopa, Az
    '01 Prerunner, '16 trd4x4, '03 cbr954rr, '03 rc51
    I discussed the AutoZone ones a while back in here. One of mine clogged up, but soon after it cleared itself and actually sprays pretty good! At speed it tends to shoot up higher but I just spray it at like below 40mph and it works great. A pretty decent fan type spray. I gave up looking for other ones and left these in. Here in az the bug juice gets baked on almost instantly anyways so I rarely use the sprayer as it just smears.. And with a roof led bar I'm scrubbing it with a squeegee every night anyways.. however I will add that the AutoZone ones do kinda spray outside of the windshield depending on your speed. Thus why I use it only at lower speeds. If you don't wanna worry about that then the stream type might be best..
  6. Jun 4, 2015 at 3:32 PM
    ARB1977
    North Texas
    Thanks. I was looking for a fan spray...I'll just keep what I have.
