washing truck with hard water
Discussion in 'Detailing' started by simcoetacoma, Jun 2, 2011.
  1. Jun 2, 2011 at 8:55 AM
    simcoetacoma
    simcoetacoma [OP] Member
    Water in my municipality is very hard. Because of the hard water, after washing my truck at home, the truck sometimes looks worse than before it was washed because of all the hard water stains that are left on the truck once it dries. Does anyone have advice of how to deal with this issue? I prefer to wash my truck by hand at home. Using water from a water softener to wash my truck is out of the question. Any insight would be greatly appreciated! Thank-you.
  2. Jun 2, 2011 at 9:35 AM
    tacoteacher
    tacoteacher Well-Known Member
    socal
    05 SR5 access cab 4wd
    Stock for now
    Welcome to TW brother! Check out the detailing thread for more info. I also have extremely hard water. The hotter it is when I wash the truck, the worse the problem, so I only wash in the morning or evening during hot weather. After washing, I do a quick (not that thorough) dry. I then spray the truck with a 10% vinegar solution, and dry thoroughly. This works, as the vinegar will dissolve solids in the water that cause it to be "hard". The potential drawback is that the vinegar may remove your wax. At 10% this is probably not going to happen very quickly. If it does, you may have to rewax. If water continues to bead on your finish, then your wax is probably still doing it's job. If the vinegar scares you, try distilled water first. Hope this helps.:)
  3. Jun 2, 2011 at 3:15 PM
    daggertats
    daggertats Well-Known Member
    arden nc
    2010 tacoma 4x4 reg cab
    undercover tonneau ,bug deflector, removal of all tacoma emblems added a set of component speakers behind the rear seat egr in channel window visors
    i use wax as you dry on my truck.......i spray it on wet then wipe the truck dry with an absorber. no spots what so ever :D
  4. Jun 2, 2011 at 3:20 PM
    Seabass
    Seabass Chrome won't get you home
    Adam
    AZ
    '06 Sport 4x4
    Let's be honest... you really only care about your own rig.
    Just dry really fast in the shade. I use a premoistened clean chamois to re-wet the water spots and it does a great job. Just keep your waxing up and they should wipe off easily.
  5. Jun 2, 2011 at 3:26 PM
    berry79
    berry79 Well-Known Member
    Homestead, FL
    08 DBL Cab LB
    I also have a hard water. What i do is, dry the truck as normal. Then I quickly follow up with a good quick detailer spray and microfiber cloth and all spots are gone.
  6. Jun 2, 2011 at 5:06 PM
    Bumponapickle
    Bumponapickle Well-Known Member
    Ontario, Canada
    09 TRD + Leather DCLB
    Old Man Emu 3 inch lift + AAL, Satoshi and Pioneer Avic Z130BT
    why is using water from water softener out of the question?? The obvious would be that u dont have a water softener, but is there another reason??
    sounds like Grand River water!! Am I right on that one???
  7. Jun 2, 2011 at 6:14 PM
    vanlancf
    vanlancf New Member
    Chad
    Dallas
    Hard water is dissolved calcium and magnesium and it will stick to everything it comes into contact with. I have to wonder why a softener is out of the question also it would be the best/easiest solution.
    The only solutions other than the softener is to use the spot free rinse at the DIY car wash (make sure they use soft water). I've also been told then Mr Clean product that hooks to your hose is a tiny water softener.
    Just like your dishes and tub/shower soap needs hard water in order to spot.
  8. Jun 7, 2011 at 2:09 AM
    Rellik01
    Rellik01 Well-Known Member
    Craig
    Windermere, Florida
    2012 TRD Sport 4x4 White
    Bull Guard powder coated white, chrome aftermarket tail lights,Led interior lights, Factory roof rack, Bug deflector, Factory tow package, Garmin GPS, Viper 5901 alarm with auto start, Weather tech window wind deflectors, , 3" Tube steps powder coated white, CB Radio, Radio Scanner.
  9. Jun 7, 2011 at 3:50 AM
    Quad D
    Quad D Well-Known Member
    Quad
    Colorado, from CA, lived in TX, ID, and MT also.
    Tacoma stock, dbl cab, 4x4, short bed, SR5
    Doesn't the "Mr. Clean" car wash kit attach to the hose, quick dry "spotlessly", and remedy hard water? I haven't had the problem myself. I know where I'll be moving to soon has hard warter issues though, so this is of interest to me. I know I've had friends in the past use it.
    http://www.amazon.com/Mr-Clean-AutoDry-System-Starter/dp/B0006M56CE
    http://purpleslice.com/
    I've been using PURPLE SLICE forever on my bike and it works great. A little labor intensive for a whole truck, but I'll probably still use it at times for my tacoma. At least in trouble spots, or where I clean constantly. Just spray on a micro fiber cloth and wipe, no streaks and takes off anything.
  10. Jun 7, 2011 at 12:37 PM
    pinktaco808
    pinktaco808 Hot Steppa
    waterless??
  11. Jun 7, 2011 at 8:48 PM
    Quad D
    Quad
    purple slice is waterless, just spray and wipe
  12. Jun 7, 2011 at 8:49 PM
    Marioso
    Marioso Risueno
    San diego Ca
    2007 Toyota Fj Cruiser
    just touch up ur truck with a window clear after. or some liquid wax.
  13. Jun 7, 2011 at 8:50 PM
    Marioso
    Marioso Risueno
    San diego Ca
    or, soak a rag, rinse it, wipe the area that was been spotted and with a dry rag wipe off the water left from the rinsed rag. it shouldnt be much
  14. Jun 10, 2011 at 7:09 PM
    jjw1
    jjw1 Well-Known Member
    Jesse
    Citrus County Florida
    2011 Super White DCSB TRD OR PreRunner
    Weather Tech Floor Liners, Truxedo Bed Cover, OEM Silver Step Bars, Debadged, Colormatched Satoshi, Wet Okoles, OEM Roof Rack, Bed Mat, Locking Gas Cap, and removed Mud Flaps
    Rubbing Alcohol works wonders but it also strips the paint of any wax so you will have to wax when you're done
