water drip, small hose on firewall
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SCTacomaCA, Mar 18, 2016.
  1. Mar 18, 2016 at 2:15 PM
    SCTacomaCA
    SCTacomaCA [OP] Active Member
    I just noticed a small water drip behind my right front tire. I traced it back to a small hose coming out of the firewall on the passenger side. The hose in open ended and about 3 inches long. Seems to be a constant drip, just started today. Anyone have an idea what this is? I can snap a quick pic if needed
    thanks
  2. Mar 18, 2016 at 2:16 PM
    GHOST SHIP
    GHOST SHIP hates you.
    GHOST
    It's the drain hose for your AC condenser. Nothing to worry about.
  3. Mar 18, 2016 at 2:17 PM
    Blkvoodoo
    Blkvoodoo a Hooka smoking caterpillar has given me the call
    Kevin
    Near Clayton NC
    08 PreRunner SR5 DCSB
    condensate from the AC, if you're running defrost your also running AC,
  4. Mar 18, 2016 at 2:18 PM
    SCTacomaCA
    Thanks fellas
  5. Mar 18, 2016 at 2:18 PM
    GHOST SHIP
    GHOST
    There is a mod to extend it below your frame rail. Just a small coupler, hose clamps and a small peice of hose and you're golden.
  6. Mar 18, 2016 at 2:18 PM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    2016 4Runner TRD Pro
    It's the A/C condenser overboard hose (I don't know the technical name). Its where water condensation drains away from the vehicle.
    Edit: I see I'm late to the party haha.
  7. Mar 18, 2016 at 2:18 PM
    Skrain
    Skrain Time is an illusion. Lunchtime doubly so.
    Monticello, Ky
    2009 F.J. Cruiser
    Westin 9 LED Driving Lights.
    Yeah, if it ain't dripping, you'll soon have water sloshing around on your passenger side floorboard!
  8. Mar 18, 2016 at 2:28 PM
    jbrnigan
    jbrnigan Well-Known Member
    Midwest
    2015 TRD Sport, 4X4, 4.0L, Auto - Access Cab
    Used split vinyl tubing to redirect condensate to the outside of the frame
  9. Mar 18, 2016 at 2:38 PM
    McTeague
    McTeague Well-Known Member
    Alan
    2012 MGM Tacoma DCSB TRD Off Road
    Stock
    That is your clean water source should an apocalypse occur, remember its location.
  10. Mar 18, 2016 at 2:45 PM
    SCTacomaCA
    It's strange that I've owned the truck for 8 years and never seen it dripping before
  11. Mar 18, 2016 at 3:09 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    It drips every day.
    You only noticing it today doesn't mean it isn't normal.
  12. Mar 18, 2016 at 5:05 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Not very observant are you? :)
    dtaco10 and 12TRDTacoma like this.
  13. Jun 16, 2021 at 1:16 AM
    Jesusbruh
    Jesusbruh New Member
    Jesus
    2020 magnetic grey TRD off-road Tacoma
    New to the Tacoma scene and noticed this same thing dripping under my truck, I’m glad I’ve joined such a helpful community!
  14. Jun 16, 2021 at 1:56 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    Welcome aboard!
    Lots of help here if you need it and maybe you can also help others.
  15. Jun 16, 2021 at 2:19 AM
    hoffengineering
    hoffengineering Well-Known Member
    Taylor
    Orange County, California
    2015 DCLB 4X4
    Definitely recommend the extension "mod" mentioned above--super easy and prevents the A/C condensation from dripping onto your frame.
    dtaco10 likes this.
  16. Jun 16, 2021 at 4:44 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    I'd be more worried about all the road washup and crap during a rain storm than I would be about freshwater condensate dripping on the frame.
    blu92in99, spitdog and 6 gearT444E like this.
  17. Jun 16, 2021 at 5:24 PM
    hoffengineering
    Taylor
    2015 DCLB 4X4
    It's less about how clean the water is and really more about often it happens. If you drive your truck everyday and use your A/C everyday, you're going to have water dripping there everyday. Over time, that's going to rust.
    It's not uncommon to see a nasty rusty mess on the frame right under the spot where the A/C drains.
  18. Jun 16, 2021 at 7:43 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    Well I run my AC nearly everyday, even in the winter. It is a 2012 nearly 10 years old and there is no rust. I do however wash it every 3 months or so and spray under it with freshwater.
    How many years do you think it takes?
  19. Jun 18, 2021 at 12:41 AM
    hoffengineering
    Taylor
    2015 DCLB 4X4
    Sounds like you've gotten pretty lucky in that case. It can happen relatively quickly. If you aren't having that issue, then no biggie. But it's easy, inexpensive, and that can help mitigate a potential issue.
    Some examples in the 3rd gen forum: https://www.tacomaworld.com/threads/rust-on-frame-with-a-c-drain-mod-fix.444138/
    Some first gen, same issue: https://www.tacomaworld.com/threads/frame-rust-from-ac-condensation.390399/
    And some more second gens: https://www.tacomaworld.com/threads/frame-rust-from-ac-drip-hose.678278/
  20. Aug 17, 2023 at 5:21 PM
    Steelhead Bum
    Steelhead Bum Well-Known Member
    Mitchell
    Eastern WA
    13 DCLB Sport 4x4, 92 AC MT 4x4
    Posting here because my search game is not yielding the results I want.
    I think my drain hose may be plugged.
    This is new, ac drain always functioned as intended up until about 2 weeks ago. Frame rail and hose are now both bone dry with ac on max.
    Preferred method to check for a clog? Was thinking about running a cloths hanger or something similar but I’m hesitant because of 1.) potentially damaging the condenser and 2.) if it is clogged pushing all of the shit inside of the box.
    Hoping to disconnect the outlet hose from the box and run something through it to the outside of the truck.
    No water build up in cabin filter, glove box or floorboard with daily ac use over said time frame. Outside temps have been upper 90’s-110. Relative humidity single digits to mid teens.
    Thoughts?
