Water dripping from the firewall to the passenger side manifold
Discussion in '1st Gen. Tacomas (1995-2004)' started by BBBsti LTD, Sep 12, 2009.
  1. Sep 12, 2009 at 9:35 AM
    BBBsti LTD
    BBBsti LTD [OP] Well-Known Member
    Ashburn, VA
    2010 TRD Off Road 4WD
    I have noticed that after I drive my truck with the AC on, once the vehicle is parked, I hear water dripping into a really hot surface (psssss, pssss, .........)
    I opened the hood and saw that in the firewall on the passenger side there is a small drain tube and there is water coming out of it and landing in the exhaust pipe, just past the manifold.
    I bought this truck used, I wonder if I am missing a piece of hose the it is connected to the small tube to avoid this. I will try to post a picture soon.
    Thanks guys
  2. Sep 12, 2009 at 11:05 AM
    dairyking
    dairyking New Member
    I just bought mine 5 days ago and I noticed the exact same thing. If i find any answers i'll let you know. its probably just a condensation issue.
  3. Sep 12, 2009 at 11:21 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Its the AC condensation dripping onto the exhaust. No biggie. You can attach a tube to it, and run it away from the exhaust if you want.
  4. Sep 12, 2009 at 11:51 AM
    BBBsti LTD
    Ashburn, VA
    That is what I thought, but I was wondering if a piece of hose was missing, I guess I will attach a piece of hose to re-route the water.
  5. Sep 12, 2009 at 11:51 AM
    BBBsti LTD
    Ashburn, VA
    Cool thanks!!!
  6. Sep 13, 2009 at 1:28 PM
    xsvtoyz
    xsvtoyz Well-Known Member
    AL
    Oklahoma
    03 Pre-Runner Inprogress
    HID (ACA)/ Web cams/ Header/Full Custom exhaust/ K&N FIPK II/SuperCharger
    yep its normal for the condensation but seems like a routing issue. use a larger hose over the top not a smaller one inside the existing tube. its 0 pressure so you don't want to clog it or you will have it on the floorboard inside.
  7. Sep 18, 2009 at 5:12 PM
    BBBsti LTD
    Ashburn, VA
    All the Tacomas have this water landing on the manifold? They all make this Pssss Pssss ...........??
  8. Sep 18, 2009 at 8:05 PM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Kings with JBA UCA's, Dakars and 34" BFG KM3, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    you could just turn it so it lands on your frame. Thats what I had to do when installing my headers.
