water fording w/o breathers
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NAYo2002, Sep 7, 2010.
  1. Dec 16, 2010 at 8:16 PM
    gjbonner
    gjbonner Well-Known Member
    Guy
    Northern Idaho
    07 Tacoma Off Road TRD
    Rhino Lined exterior,Fab Tech 6", 1.25" SpiderTrax spacers, Wheels painted Rustoleum Hammered Black, All Pro front plate bumper, Warn 9.5 ti winch, BHLM, Cig lighter constant on, Door beep toggle switch, Locker mod, Lock/unlock beeper Mod, Rear tailights smoked, 750w inverter with the outlets and on/off switch wired to rear of the console, Blacked out badges, blacked out rear bumper.
    Did water come through your weather stripping on the doors like the silverado? I've been thinking about beefing mine up some how...maybe adding some silicone or something to make the seal tighter. I already routed every breather on the truck into the cab and sealed all the rubber entry points to the cab.
  2. Dec 17, 2010 at 3:36 AM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    you are about 1" away from hydro locking that motor
    water not mud guy^^^^^^^^^^^^^
  3. Dec 17, 2010 at 9:45 AM
    AKTACO420
    AKTACO420 Well-Known Member
    RETODD
    Anchorage AK
    2009 tacoma
    bucket seats grille craft mesh grille and lights behind grille
    That's why is said its the deepest I would take a stock tacoma. And I had zero water in my cab but only. Because I kept moving and not sitting for an 1
  4. Dec 17, 2010 at 10:01 AM
    BigRedToy
    BigRedToy ¯\_(ツ)_/¯
    Colorado
    07 Regular Cab SR5 4x4
    I went through water up to the door sills with the stock breather. No water contamination.
    I also wanted to add, if you don't have a drill or you don't want to drill a hole, you can zip tie the breather to the fender brace. The brace is located behind the removable pocket. Just make sure to remove the pocket carefully, I broke some of the tabs and used a screw to hold it place.
  5. Dec 17, 2010 at 10:31 AM
    AKTACO420
    RETODD
    Anchorage AK
    2009 tacoma
    I'm not worried any thing I break I can fix
  6. Dec 17, 2010 at 1:28 PM
    AKTACO420
    RETODD
    Anchorage AK
    2009 tacoma
    Isn't the only way for water to get into the engine is through the air intake ?
  7. Dec 20, 2010 at 9:25 AM
    maxa
    maxa Member
    Max
    Seattle
    17 DCLB OR
    Holy doodle AK, you're cutting it really close there, glad you made it through ok! The air intake sits right on top of the passenger side wheel well and it looks like at the beginning the water was right there. I'd probably check the air filter to see if it got wet...
    Where I live I get flooded out once every year. I learned a few things about crossing water: take it slooowly, know the car (location of intake, breathers), be careful when breaking afterwards and don't hit the salmon ;-)
