Water in cab
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dgr540, May 17, 2010.
  1. May 17, 2010 at 6:09 AM
    dgr540
    dgr540 [OP] I've got the FUNK
    Friendswood, TX
    2013 Wrangler Unlimited
    XDs Trail grappler 35x12.5x18 Winch 8K lbs Front bumper 4in Lift
    I am going to be taking my truck to the dealership today. I got in my truck Saturday, and in my passenger floor there is a huge puddle. I wouldn't have noticed this before but since I got my weather techs is staid standing. Now I have had water in my radio screen before, but by the time I got to the dealership that time it dried up with the Texas heat. So two times now this has happened. It may have happen before, but never notice because of carpet mats. Any insights on the matter?
  2. May 17, 2010 at 6:54 AM
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
  3. May 17, 2010 at 7:36 AM
    dgr540
    Friendswood, TX
    I'll tell them to check that. Would the cabin filter or ac plugged be related to the water in the radio though?
  4. May 17, 2010 at 9:11 AM
    05Moose
    Jim
    There's only three ways you're going to get water in the radio.
    First is a leaking windshield. However, even that seems remote. It would have to drip down onto the dash and run in via the faceplate. In which case, you'd likely see evidence of that.
    The second possibility is a leak in the heater core which would have to spray coolant everywhere. Not likely at all.
    The most likely reason why you'd have water in the radio is due to condensation. And this could be directly related to a plugged drain in the cab. If you live in a humid area, and the condensation buildup can't drain out, then you're really increasing the humidity inside the cab (look at people with windows fogging up all the time). Shoot, if I bring my cold tools from the garage into my house in the wintertime where it's warmer, they instantly get wet with condensation on them.
  5. May 17, 2010 at 9:12 AM
    Collins
    Collins Well-Known Member
    North Carolina
    09' Tacoma, 2.7L, 5spd, 4x4
    I recall another post a few weeks ago about someone having a leak coming from the overhead console/map light thing...
    but i don't think that is far enough forward to leak onto/into the sound system...more likely
    the windshield molding as stated.
    I think it was a roof rack thread?..because it had content about
    those 2 rubber molding strips on the roof.
    PC
  6. May 17, 2010 at 9:17 AM
    wlmuncy
    wlmuncy Well-Known Member
    William
    Knoxville, TN
    2007 Double Cab Manual 4*4
    Mine was leaking there. I haven't had a hard rain since to get pictures to push on Toyota to fix. The water that dripped did so right at the cup holder.
  7. May 17, 2010 at 11:56 AM
    DaveInVT
    DaveInVT Member
    Vermont
    08 DC Black SR5 4X4
    Another spot to look at are the body seams below the rear window. In my 08 I would find the drivers side floor mat wet after a heavy rain. The drivers side seam was leaking just under the rear window and the water was flowing under the rear seats, floormats and into the driverside pan. Everything was dry on the rear floor. Have the dealer check that seam if they cannot locate any other leak.
  8. May 20, 2010 at 8:52 AM
    dgr540
    Friendswood, TX
    Well they said they ran an extensive water test...... and found nothing. I was upset and asked if he told them some possibilities (from TW peeps responses) and he said yes. I then said explain why I had an inch of standing water on my floor mat and the last time a puddle in my radio screen, and he could not answer just told me to bring it up here right away. I told him I would have but it was the weekend. He said they are open Saturday mornings, but that wouldn't be a good time because they only have a 1/3 of their workforce..... Pissed/Confused. Done with my rant.
  9. May 20, 2010 at 9:03 AM
    05Moose
    Jim
    You then have two choices (since they didn't ever find mine either through that "extensive" water test). You can test some things out yourself to try and find it, or you can wait until it happens again (which could be years) and then look for it at that time. If you choose to wait and you find a puddle on the floor again, lean up under the passenger dash and look/feel around for the water. If it's coming in through the cabin air intake, you'll find water dripping behind the fan unit. There's an area up in there where it'll come through.
    If you want to test out the cabin air intake for leakage, do the following:
    1. Park somewhere near a hose where your truck is at the same incline/angle as where you were when it leaked.
    2. Remove the glove box door completely (remove the damper, lower it all the way and then lift up at the hinges to pop it off completely).
    3. Open the cabin air filter door and remove any filters.
    4. Insert a paper towel into the air filter slot to catch any water drips (as evidence that it occurred).
    5. Grab a hose and run it on the windshield between the center and passenger side for a while checking the paper towel periodically for leaks. If the paper towel gets wet, then it's the channel in the cowl not working well enough and you'll need to put a cover over the air intake under the cowl cover.
    6. If no leaks, remove the cowl cover and run water into the cowl area (not into the cabin air intake obviously) and see if it's draining properly.
    Beyond those steps, I'm at a loss.
  10. May 20, 2010 at 9:15 AM
    dgr540
    Friendswood, TX
    I will try to test that tonight.
