Water in trailer wire harness
Discussion in '3rd Gen. Tacomas (2016-2023)' started by xxtavixx, May 18, 2018.
  1. May 18, 2018 at 12:09 PM
    xxtavixx
    xxtavixx [OP] Well-Known Member
    Jacksonville fl
    2018 6MT
    ARB rear locker OVtune Mobtown sliders Core-shifter short throw Trd bro-phony grill Caliraised bumper light bar Caliraised ditch lights Rigid ignite back up lights FN Five Star 16x8 Et0 255/85/16 cooper st maxx MesoJDM fuse box cover MesoJDM led interior lights Bilstein 6112 fronts Bilstein 5100 rears Headstrong 3 aal Toytec 3* shims Mesjodm dome and map lights Diode dynamix ss3 pro yellow Mobtown aluminum front skid 2lo mod SOS front recovery point
    I had to tap into the reverse light lead, and decided I would use the one for the trailer harness under the truck, so behind the bumper. I was shocked to discover it was full of water. not a few drops, but a lot of water. My truck is not seen rain or puddles for at least three weeks, which concerns me. This seems like this will be a major point of corrosion, and I can’t come up with a great way to seal it due to the shape of the connection. If you look at it it it has a gray housing that basically forms a cup, with no way for the water to get out.
    I thought about drilling a very tiny hole but I’m not sure I want to commit to this yet. I may check it in a few days and blow it out with the compressor and wrap it up with a good electrical tape, go a little overboard with it
    Has anyone else made this observation and come up with a better solution?
  2. May 18, 2018 at 4:53 PM
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    Any chance the water is hitting the plastic connector that snaps into the trailer socket....(rear)
    That's where H2o has been coming into the tag lites.
    Maybe silicone would seal that area..?
  3. May 18, 2018 at 5:10 PM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    Can you get a good photo of it, would help the rest of us... thanks.
  4. May 18, 2018 at 5:10 PM
    xxtavixx
    Jacksonville fl
    2018 6MT
    Its definitely sitting in the grey plastic cap, not sure hows it gets there just yet.
  5. May 18, 2018 at 5:11 PM
    OnHartung'sRoad
    Sounds like you need to do a trailer harness breather mod...
    mtip likes this.
  6. May 18, 2018 at 5:48 PM
    Captqc
    Captqc Well-Known Member
    Tigard, OR
    2017 Tacoma 4x4 TRD AC Off Road
    WD-40
  7. May 18, 2018 at 6:16 PM
    xxtavixx
    Jacksonville fl
    2018 6MT
    I was actually thinking I would use some spray on electrical tape, and then put some dielectric grease in there
    over60 likes this.
  8. May 18, 2018 at 6:36 PM
    RIDERED67
    RIDERED67 Well-Known Member
    2017 TRD OFFROAD QUICKSAND, DCLB, TECH
    Its comments like this that keeps me loving Tacomaworld
  9. May 18, 2018 at 6:49 PM
    xxtavixx
    Jacksonville fl
    2018 6MT
    To be fair, its probably the simplist solution. A small drain hole would work, especially if drilled at an angle to prevent road spash
  10. May 19, 2018 at 6:27 PM
    over60
    Muskoka, Ontario
    PLus 1 on the dielectric grease after you find how its getting in there.....!!
