Water Leak
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tyler2tacoma, Apr 26, 2020.
  1. Apr 26, 2020 at 10:41 AM
    Tyler2tacoma
    Tyler2tacoma [OP] Member
    Tyler
    2012 Tacoma Pre Runner
    I have a 2012 tacoma pre runner and i went through the car wash today and when i got to the vacuums, i noticed water was dripping from under my
    glovebox, any idea on what that could be ?
  2. Apr 26, 2020 at 11:03 AM
    gunpup
    gunpup Well-Known Member
    Nate
    2015 DCSB Trd OR / 2001 DCSB SR5
  3. Apr 26, 2020 at 11:05 AM
    bordinco90
    bordinco90 Well-Known Member
    SW Louisiana
    2008 Desert Sand Mica Tacoma Prerunner DCSB
    18 inch Black rims with 265/65/18 AT tires. Bilstein 5100 shocks. Black Halo Headlights and Black LED taillights. Window Tint. Black Aftermarket Grille.
    I had this happen after a heavy rain storm. Turns out I had a clogged A/C drain tube. After getting the tube cleaned out (I took mine to a mechanic), I put some RTV sealant on the bottom portion of my windshield just in case.
    Tyler2tacoma[OP] likes this.
  4. Apr 26, 2020 at 11:07 AM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    Does liquid smell of coolant? Is coolant level low? Does car wash have undercarriage spray?
  5. Apr 26, 2020 at 11:09 AM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    turn on heat and dry it out
  6. Apr 26, 2020 at 3:00 PM
    Tyler2tacoma
    Tyler
    it doesn’t smell like coolant just water and i have found that it is dripping out of my blower motor but it’s not dripping anymore. I just went and poured water on my windshield and it leaked through again so could it be a leak in my windshield ?
  7. Apr 26, 2020 at 3:09 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Have you ever had the windshield replaced?
    BizzyB726 likes this.
  8. Apr 26, 2020 at 3:13 PM
    BizzyB726
    BizzyB726 Well-Known Member
    Brandon
    New Jersey
    2012 Black Tx Baja
    Was gunna say the same thing. I had mine replaced and the first wash I went through, it leaked for the first time ever.
  9. Apr 26, 2020 at 3:17 PM
    Tyler2tacoma
    Tyler
    no i have not had it replaced and i am going to try and replace my cabin air filter but if it was my ac hose or air filter why wouldn’t it leak all the time ? not just when i went through the car wash
  10. Apr 26, 2020 at 3:18 PM
    TnShooter
    Deogee
    STOCK
    Mine was actually the channel that was blocked.
    Ny those blooming things that fall off oak trees.
    These things.
    That was BEFORE I had the windshield replaced.
    I’m still waiting for it to start leaking after have the windshield replaced 2x now.
    I hope it never does, but it 50/50 it seems.
    whatstcp[QUOTED] likes this.
  11. Apr 26, 2020 at 3:19 PM
    BizzyB726
    Brandon
    New Jersey
    2012 Black Tx Baja
    Mine doesn't even leak every time I go through the wash. Random washes and not yet after a hard rain. It's been over a year since i replaced it.
  12. Apr 26, 2020 at 3:19 PM
    TnShooter
    Deogee
    STOCK
    Just pull the cowl off under the windshield.
    You’ll probably figure it out pretty quick.
    whatstcp likes this.
  13. Apr 26, 2020 at 3:22 PM
    Tyler2tacoma
    Tyler
    i’m not very mechanic savvy lol but i’m sure i can youtube it. I will try that and the air filter thank you all!
  14. Apr 26, 2020 at 3:23 PM
    TnShooter
    Deogee
    STOCK
    I am guessing that it has to do with the amount of water the channel can drain at once.
    If the water amount exceeds the rate at which the channel can drain. It leaks.
    And possibly the angle the truck is parked at.
    BizzyB726[QUOTED] and whatstcp like this.
  15. Apr 26, 2020 at 3:24 PM
    TnShooter
    Deogee
    STOCK
    Replacing the Air Filter will not help.
    It isn’t causing the issue. Replacing it with a new one, will have the new one result in getting wet too.
    I’d “fix” the problem first, then replace the filter.
  16. Apr 26, 2020 at 3:27 PM
    TnShooter
    Deogee
    STOCK
    Yeap. Seems the “design” could have had a bit more thought put into it.
    But I just live with it. Lol
  17. Apr 26, 2020 at 3:28 PM
    BizzyB726
    Brandon
    New Jersey
    2012 Black Tx Baja
    It's not bad having all weather flooring. I don't mind the once in a while drip or two.
