Water Leaking into Cab
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tyler Andrews, Dec 7, 2017.
  1. Dec 7, 2017 at 6:41 PM
    Tyler Andrews
    Tyler Andrews [OP] Well-Known Member
    Tyler
    Portland
    2018 Super White Sport 4x4
    Living in Portland we see a fair share of rainfall, now that winter is here it has been raining pretty regularly. This being said lately I have had rainwater leaking into my cab and it is starting to smell really bad due to mildew. The water seems to be under the carpet on the passenger side along the door-sill and running along the cab to the rear of the truck. Water isn't leaking from the windows or any on the driver's side so I know it is confined to just the passenger side. Anyone else experience this issue and/or have solutions? Thanks in advance!
    2003 tacoma sr5 ext. cab
  2. Dec 7, 2017 at 11:48 PM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    2002Tacoma4x4 likes this.
  3. Dec 8, 2017 at 10:13 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Make sure you rule out a door seal leaking, too. The way you describe it, sounds like it could be coming from the front of the door, and running down the kick panel or something...Dry the front/rear door sills off so they are good and dry inside/out, then hose it off real good.
    If you rule out door seals leaking, the TSB mentioned in the link above is probably your next best bet.
  4. Dec 8, 2017 at 11:45 AM
    onakat
    onakat Well-Known Member
    Canada
    2000 indestructaco!
    if it's not coming from firewall, door seals, windows or clogged AC drain, it might be coming from a leaky windshield.
    I had a leak on driver's side that turned out to be coming from the upper corner of windshield, driver's side. It would drip along the A pillar (behind the plastic piece with the handle), then the sidewall, then behind kickpanel and down onto the floor. This leak was hard to find because it was hidden behind plastic interior pieces of the cab, out of view
    anyway, if it can help you:
    https://www.tacomaworld.com/threads...-before-water-pooling-passenger-floor.502204/
    it also incudes links to a bunch of threads about leak issues
    Buggy1 likes this.
  5. Dec 10, 2017 at 11:04 AM
    Corvus Umbrenox
    Corvus Umbrenox Member
    I had the same issue. Its usually just the ac drain, Id check that first
  6. Sep 17, 2019 at 5:23 PM
    redrumredrum
    redrumredrum New Member
    Thanks for this discussion. I am wondering how long the 2 different fixes lasted that people did.
  7. Sep 17, 2019 at 5:45 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Two fixes for this have been seen on the forum. Under the windshield the cowling hides a body cavity beneath which has a seam which can leak. I covered the seam with Gorilla tape and fixed my leak. There is also a drain tube in this space which gets clogged and overflows. Open the passanger door and shine a flashlight behind the fender panel to follow the drain. Also mine clogs up where the back of the front fender panel meets the door post, A shop vac and air gun opened it up allowing water to drain there.
  8. Sep 18, 2019 at 9:55 AM
    Tyler Andrews
    Tyler
    Portland
    Yeah the writeups on here detail it pretty clearly. I never got around to completing this as I pawned the truck off as a trade-in on a 3rd gen during summer when the leak couldn't be detected :) Good luck!
