Water leaking into truck after car wash
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SpeedwayTaco160, Feb 26, 2015.
  1. Feb 26, 2015 at 4:25 PM
    SpeedwayTaco160
    SpeedwayTaco160 [OP] Well-Known Member
    Killeen TX
    10 Sport SWB DCSB
    Ok. I have been to a car wash before in my truck, but this time was different.
    I noticed there was some water dripping below my glove box on the passenger side. I did remove the antenna before I went through because I didn't want it to get bent up. Not sure if that is my problem but this is the first time that this has happened.
    Anyone else having this problem?
  2. Feb 26, 2015 at 8:42 PM
    Gabezz
    Gabezz Well-Known Member
    Gabe
    Los Angeles, CA (Montebello)
    '12 Tacoma TRD Off-Road DCSB
    Volant CAI w/Ram Air Scoop, Volant Throttle Body Spacer, Flowmaster SS Dual Exhaust, JBA Cat4ward Headers, Body Armor Side Steps, ProComp 3in Suspension w/Pro Runner UCA's and shocks, Various KC Hilites LEDs.
    Well you discovered your truck ain't submersible. I can't offer much help to answer this, but I can relate. I ran my truck into a car wash. And later I was cleaning the driver floor kick panel and noticed drops of water, I removed the entire kick panel and there was more moisture. On the metal floor, even around the electrical wiring too. Not a lot of water, but noticeable. Not sure what else I could do, definitely dissapointed in the weather stripping job on my truck though. :confused:
  3. Feb 26, 2015 at 8:48 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Check in the cowl compartment (the area under wiper arm pivots) for displaced seal, clogged drain, etc.
    Toyota (and most other automakers) have a high-pressure wash built into the end of the assembly line to check for leaks.
  4. Feb 27, 2015 at 2:53 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
  5. Feb 27, 2015 at 2:17 PM
    SpeedwayTaco160
    Killeen TX
    10 Sport SWB DCSB
    ^ thank you!
