Water Meth Injection
Discussion in 'Performance and Tuning' started by 98ChargedTacoma, Feb 25, 2020.
  1. Feb 25, 2020 at 8:16 AM
    98ChargedTacoma
    98ChargedTacoma [OP] New Member
    Mitch
    Wyoming
    98 Tacoma, Factory Installed Supercharger
    Thanks for the add, little back story on my 98 Tacoma TRD SR5 Factory Install Supercharger.
    Was my grandpa's since 20k miles, and recently I was finally able to wrangle it off of him. 106k Miles.
    Timing Belt was done at 80k, plugs, water pump, all the basic tuneup functions. I just tore the super charger off yesterday and sent it in for a complete rebuild, while doing so would like to go to a bit smaller pulley and meth injection. I haven't read much positive about the 7th Injector kit, and pretty familiar with Meth Injection. My question is has anybody run this, and can give me a baseline for the progressive kit. I am thinking I need to get an AFR for sure and get it installed before installing this as well. Hints, tips, etc would be helpful.
    Tons of forums, but this one seemed to look like the best from the outside, thanks for the add!
  2. Feb 25, 2020 at 8:31 AM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
  3. Feb 25, 2020 at 10:51 AM
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
    hx35 turbo, AEM F/IC, Transgo, custom converter, CalTracs, Elocker, 2-4" drop, 4x4 conversion (2023) on a new purple powdercoated fram, 255/55r18 street, 255/60r16 M&H Racemasters, 7.6 at 91
    You need an AFR gauge with the smaller pulley. You'll need it to correctly size your nozzle. 50/50 water meth should add enough fuel to keep your AFRs down and detonation in check. But again, you'll need a AFR gauge. I can recommend the AEM Uego. I run a Coolingmist progressive kit (with failsafe but I don't bother with that anymore), but it's not necessary. A cheap Shurflo pump on a hobbs switch at 4psi or would be sufficient.
    If you'll seach, you'll find more info on meth injection than you can handle.
  4. Feb 25, 2020 at 11:16 AM
    1997tacomav6
    Denver
  5. Feb 25, 2020 at 5:18 PM
    98ChargedTacoma
    Mitch
    Wyoming
  6. Feb 25, 2020 at 5:40 PM
    1997tacomav6
    Denver
    Start off with installing a new fuel pump so you know your getting 100 percent full pressure at WOT
  7. Feb 25, 2020 at 5:43 PM
    1997tacomav6
    Denver
    5speed or auto
  8. Feb 25, 2020 at 6:05 PM
    98ChargedTacoma
    Mitch
    Wyoming
    What fuel pump do you recommend, OEM?
  9. Mar 22, 2020 at 9:37 AM
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    rarely helps other than WOT
    if all other parametres are met
    AFR has to be spot on everywhere
    off idle
    mid range
    WOT
  10. Mar 23, 2020 at 6:16 PM
    Jon64l
    Jon64l Well-Known Member
    Jon
    2000 4runner, 1996 Tacoma
    If you haven't gone down the Meth Avenue yet, consider the Aem Fic 6.
    I run it on my truck in a few different boosted modes, SC, Twin charged and just Turbo.
    Its really nice to be able to adjust Part throttle fuel ratio, so much torque can be gained here, it's not just about wide open throttle performance.
    Not to mention you can pull timing where you need to in low Rpm's, add fuel anywhere and scale new larger injectors (I'm running 440cc, just entered the new valve and started right up).
    Good luck which ever way you choose!
