Water/Moisture Inside Headlights
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TXtycoon, Apr 11, 2013.
  1. Apr 11, 2013 at 2:59 PM
    TXtycoon
    TXtycoon [OP] Well-Known Member
    Kyle
    Houston
    2010 DCSB TRDOR
    Hey guys... So I ordered these headlights off eBay which I really like-- the only catch is when it rains or I wash my truck they start to fog up on the inside of the lens.
    I know plenty of you have done the BLHM which requires you to open up the headlights, I am looking to open these up and then hopefully reseal them so they wont leak anymore when they get wet.
    I've been looking through various threads about this topic but haven't quite found what I'm looking for... Some topics which I'm concered about:
    -Using an oven to open them up?
    Setting the oven to 300 degrees then turning it off, placing headlights in for 10min, then remove and quickly pull apart?
    -How to remove the old glue?
    -What to use to reseal them?
    I've heard about different products out there that might work, but could use some help making my choice from someone with more experience.
    Or, if any of you know of a thread which covers what I'm talking about :pray:
  2. Apr 11, 2013 at 3:02 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    reuse the old glue and if u want also add window weld/ rubber butyl ribbon from kragen/napa.
    to seal the outside (after they have cooled) use GE silicone II
    I have NEVER had a leak
    dont forget................set the lights in oven (off) on a piece of cardboard...not directly on the steel grate
  3. Apr 11, 2013 at 3:04 PM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
  4. Apr 11, 2013 at 3:05 PM
    majorhavok
    majorhavok Rabid Conservative
    Mike in Cali..
    Peoples Republic of Caulifournia
    '13 TRD Sport DoubleCab 4x4
    Ultragauge, ImMrYo mirror, Tailgate lock, Snugtop Rebel Shell.
    A problem I've seen on here a few times and a coworker who has it only on the right side on his ebay headlights.
    Like Justus said, just redo the thing and hopefully it will seal up better. You may want to see if you can drop a silica pack in there or something too. lol.. might help.
  5. Apr 11, 2013 at 3:08 PM
    TXtycoon
    Kyle
    Houston
    2010 DCSB TRDOR
  6. Apr 21, 2013 at 7:08 PM
    boto
    boto Active Member
    Philip
    Quebec/Canada
    07 taco dbl.cab.long bed TRD
    fog anytime bhlm royal purple oil kn&n oil/air filter secondary filter removed ultimate lift kit toytech 3 inch coilovers ans add a leaf relentless fab diy bumper
    simply drill a 1/32 hole in the bottom of your lens, all humidity will go out, i did this to one of my fog about 2 years ago and still perfect :D
  7. Apr 24, 2013 at 3:32 PM
    TXtycoon
    Kyle
    Houston
    2010 DCSB TRDOR
    Yea I decided not to open them up and just put a bead of silicone all the way around the headlight where the two pieces joined and it works perfectly! No leaks so far :D
  8. Apr 24, 2013 at 4:03 PM
    tundrataco
    tundrataco Well-Known Member
    eastern townships, quebec
    front bilsteins 2.5" lift, rear aal 2.5" lift, flowmaster 40 series muffler, kenwood headunit, ultraguage, allpro bolton sliders
    i had to do the same on both of mine, had places that they missed with the silicone... other than that the quality/look is great!
  9. Apr 24, 2013 at 4:35 PM
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    I did this on my 1999 Acura Integra and it too worked great. Unfortunately I'm gonna have to do it to the passenger side Taco factory headlamp as well. Thanks for the reminder.
    :D
    I married my tacoma likes this.
  10. Apr 24, 2013 at 4:41 PM
    penguins_cc
    penguins_cc Well-Known Member
    Will
    Bellevue, WA
    Timberland Mica Limo!
    Perkins Performance Sliders, Warn 9000, Brute Force Fab front & rear bumper, OME/Dakar lift, full ATO skids and hi-lift mount, satoshi, Wet Okoles, illuminated 4x4 switch, Diff Breather.
    I had to fix this on my wife's RX330. I never opened those up - instead I removed the fixture and used a heat gun to get the temperature warm. That pretty much removed any moisture in the lens. Then sealed everything up nicely from the outside with silicone, never had a problem since.
    Her lens started collecting water after the dealership fixed a fender bender.
  11. Apr 24, 2013 at 4:43 PM
    beaver_scott
    beaver_scott Well-Known Member
    scott
    renton, wa
    2015 inferno trd pro
    vent shades, tinted windows, clear bra, pop n lock tail gate lock, anytime fog light mod.
    the previous posters had the reseal spot on and I see you got the lights sealed anyway, so I have a different question. I bought the bhlm headlights off of ebay as well but I did an hid retrofit straight out of the box. How is the light pattern with non stock headlights?
  12. Apr 24, 2013 at 10:17 PM
    Rylee
    Rylee Well-Known Member
    Rylee
    Mission Viejo
    07 dcsb long travel
    Engage front kit, 35" hankook mt, Glassworks, Deavers.
    if they seem sealed, but theyre still getting some water in but mostly condonsation
    get the silica gel pacs they have in shoe boxes. wrap a clothes hanger around 3-4 packs and slide it through the bulb hole. put a hair dryer on and slowly heat the lense where the condensation appears. wala it will be gone in a few minutes.
  13. Apr 25, 2013 at 3:39 PM
    TXtycoon
    Kyle
    Houston
    2010 DCSB TRDOR
    IMO the light pattern from aftermarket headlights is significantly worse than OEM. Every headlight I've ordered through eBay I've had to adjust the vertical and sometimes the horizontal angle. I basically bought the headlights for the looks and not the performance-- I paid like $95 for the pair shipped so I guess I got what I paid for quality wise. Black headlight housings will not produce as bright of a beam compared to chrome ones. However, if you’ve done a projector retrofit it might not apply to you because you are no longer using a reflector setup. I’m still too apprehensive to do a retrofit :confused:
    edit: I looked at your retros and they look sick BTW :thumbsup:
  14. Apr 25, 2013 at 4:47 PM
    tombiosis
    tombiosis Well-Known Member
    T
    Ottawa Canada
    2016 TRD offroad access
    2016 Tacoma Access Cab, Super White, TRD Off Road package,//OEM Running Boards//TriFold2.0 Tonneau Cover//FJ Cruiser TRD SE Black TrailTeams replca wheels!
    I wonder if that would work...I have had major grief with my passenger side bhlm(did myself)...I believe the passenger side is more prone to fogging issues because of the intake fins in the fender well...I have sealed the shit out of that light and it still fogs up...with LOTS of water droplets inside...I am getting ready to drill a hole, but maybe I will try the silica packs first...I'm sick of taking the lights in and out...:mad:
  15. Apr 26, 2013 at 6:03 AM
    beaver_scott
    scott
    renton, wa
    Thanks. The retro fit is actually really easy to do with the moromoto mini projectors. Everything is bolt on installation/ no cutting. The hardest part is taking the lights apart to do the installation. The light output is awesome!
  16. May 5, 2013 at 4:19 PM
    TXtycoon
    Kyle
    Houston
    2010 DCSB TRDOR
    Interesting... All that "heavy modification" is why I've been holding back on doing a retrofit. I actually have a set of beater lights laying around that I could experiment with if it's as easy as you say it is. If I could do a retrofit first time and come out with results similar to yours I would be a happy guy :D
  17. Jun 1, 2013 at 7:43 PM
    primer
    primer Well-Known Member
    T
    OK
    06 SS Mica AC 4x4 TRD Off-Road
    (Mostly) debadged, Homelink mirror, Elevated rear diff breather, LED illuminated 4x4 switch, Color matched grill surround, Bed cover, Ivan Stewart wheels, Bridgestone 265/75 Dueler AT Revo 2 tires
    Happy with my BHLM, but my passenger side is fogging. I got ebay lights.
    Really don't want to pull them apart again. I might just silicone the outside.
    When I compared them - the ebay lights seem to have a different back - it seems to me they aren't sealed in back the way the OEM lights are. Some of the small plastic rubber pieces are basically open. Not sure if that matters... Even if it does - it wouldn't explain why only one of my fogs.
    I'm curious about those who recommend drilling a hole in the LENS. To me that means the front of the light. It seems like water would enter that way when you are driving in the rain.
    Can anyone clarify?
    Thanks
  18. Jun 7, 2013 at 1:39 PM
    TXtycoon
    Kyle
    Houston
    2010 DCSB TRDOR
    Update: the silicone I beaded around the headlights no longer keeps the moisture out of the inside. I am looking for someone on TW from Houston who can help me out or else I will take it to a local shop and pay like $100 to have them open them up and reseal... what a royal pain
    Personally, I wouldn't recommend drilling into any headlight. I still have hope that silicone or some other sealant will do the trick, I just can't figure out where the water is getting in at! :confused:
  19. Jun 7, 2013 at 1:56 PM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    U pay for shipping to and fro, and ill do it free.
    Gimme 3 days to finish if nothing pops up in life, and allow shipping time.
    It gives me something to do, but pointless if u don't have a backup set.
    Throw in 6 for silicone, and 8 for window weld and ill be better off.
    Ur call............not convienient I know, but its an offer
  20. Jun 7, 2013 at 1:57 PM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    Always ship in 2 boxes and insure them regardless
