Water...ohhh water. Need some help here
Discussion in '1st Gen. Tacomas (1995-2004)' started by dennisc, Apr 30, 2014.
  1. Apr 30, 2014 at 9:33 AM
    dennisc
    dennisc [OP] Well-Known Member
    a few
    So Pensacola had about 22 inches of rain in 12 hours and making it home from work the roads were mostly flooded. I made it home but the truck was running sluggish. This morning it gave me a misfire code. p0300 and p0302. I pulled the cap off of number 2 cylinder and there was some water under it....so what do I do? I have a 2002 toyota tacoma 3.4L V-6.
  2. Apr 30, 2014 at 11:07 AM
    oldblue1968chevy
    oldblue1968chevy Well-Known Member
    Spokane WA/Viola TN
    2000 Toyota Tacoma V6 TRD
    Stock
    The cap...you mean sparkplug? Is the oil milky?
  3. Apr 30, 2014 at 11:21 AM
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
    I think he means the coil pack... ?
    I'd say before you start replacing things, unplug all the connections, let them dry (maybe hit them with some WD-40 to speed it up?), plug them back in, and see how it runs.
  4. Apr 30, 2014 at 11:24 AM
    Coast2Coast
    Coast2Coast Well-Known Member
    Northern Alberta
    2009 TRDOR
    Black Sand Pearl factory paint - flattened "au natural" by tree branches.
  5. Apr 30, 2014 at 11:25 AM
    dennisc
    a few
    To clear things up..there is a little water sitting atop the spark plug. By cap I mean the plug wire. I sprayed some wd-40 to see if it will help dry it up quicker. I wish I had something to blow the water out but I do not.
  6. Apr 30, 2014 at 11:51 AM
    dennisc
    a few
    Thats a good idea...luckily my neighbor had a compressor and blew all the water out. She runs like normal now. Any problems I should watch out for later on though?
  7. Apr 30, 2014 at 11:52 AM
    dispatch55126
    dispatch55126 Well-Known Member
    MN
    2004 Xtracab SR5
    Complete OME kit w/ 881's and dakars. All-Pro Sliders, CB, HAM Radio and various other minor stuff.
    Had this happen on other vehicles. Water floods the spark plug shorting out the COP.
    Blow it out with anything you have available, canned air, air compressor or hair dryer. Once completely dry, put some dielectric grease in the COP boot and reinstall.
    22" is alot of rain and driving through puddles throwing that water in the engine compartment doesn't help. The COP boots are suppose to seal out water but they dry out, shrink and crack with time. Don't replace any COP's just yet. See if the dielectric grease works first.
  8. Apr 30, 2014 at 11:59 AM
    Coast2Coast
    Northern Alberta
    2009 TRDOR
    You should check out the rest of the plugs too. If you can't find compressed air or anything at all to get rid of the water, just pull the spark plug and turn the engine over with the starter motor to blow the water out. Same thing you'd do if you sucked water in the intake.
  9. Apr 30, 2014 at 12:07 PM
    dispatch55126
    MN
    2004 Xtracab SR5
    Don't pull the plugs and risk hydrolocking the engine. If you absolutely have no way to blow out the air, fold paper tower or shop towels and push them down around the the spark plugs to soak up the water.
    Edit: I should add that C2C is correct that you should pull the rest of the COPs and make sure everything is dry.
  10. Apr 30, 2014 at 2:00 PM
    dennisc
    a few
    Thanks guys!
  11. Apr 30, 2014 at 2:03 PM
    Coast2Coast
    Northern Alberta
    2009 TRDOR
    You won't hydrolock the engine with the spark plug out. LEAVE IT OUT being key. Also pull all the spark plug caps off you do not want to fire up.
    Better yet forget everything I said, take it to your mechanic and let him worry about it.
