Water pump question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by someperson39, Oct 1, 2014.
  1. Oct 1, 2014 at 11:50 AM
    someperson39
    someperson39 [OP] Active Member
    Been a long time lurker, but this is my first actual new thread.
    Got a quick question.
    I took my 06 DCSB 4wd V6 with just under 95k miles into the dealership. They are replacing the timing chain/cover/gasket, which is covered by my aftermarket warranty when I purchased the truck used about 3 years ago.(thank god)
    They suggested that since they are already going to be in there, I should replace the water pump and belt as a preventative measure.(even though it doesnt show signs of leaking/wear) The labor will be covered under warranty for the timing chain, so I will just have to pay $300 for the water pump/belt.
    So the question is....Just pay the $300 for the parts and take the free labor? Orrr leave it alone and replace the water pump myself later down the road if/when it poops out?
  2. Oct 1, 2014 at 12:54 PM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    There is no service interval for a water pump. They can last a very long time and die young. You never know. If you are skilled in this task, then you can replace it when the time comes.
  3. Oct 1, 2014 at 12:55 PM
    Spaghettiohead
    Spaghettiohead Member
    Andrew
    Alaska
    '14 DC Off-Road
    Yes. If you don't, it will start leaking next week. Always.
  4. Oct 1, 2014 at 1:16 PM
    Canufixit
    Canufixit Well-Known Member
    People ask me "CANUFIXIT"!
    New England
    2020 Red SR 4x4 Taco
    "Access" Tonneau cover. Bed Mat. Hitch, Timbren SES
    Post some more info - yr/cab style, v6? mileage, etc. that makes a decision easier. Also, I do q quick check on a replacement WP for both aftermarket and OEM. then make a decision... Nice for the dealer to offer the free labor though!
  5. Oct 1, 2014 at 1:22 PM
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
  6. Oct 1, 2014 at 2:20 PM
    someperson39
    Thanks for the suggestions guys.
    Was thinking of buying one and having them install it but its already in the shop and no time to wait for shipping. So, I checked the local Oreillys/autozone and they dont have the oem Aisin brand. Only masterpro, import direct, or duralast. (not sure of the quality for these brands)
    Even so, $90-110 for the pump + $40 for the belt= ~$150 (plus my own labor). Although Id like to think I'm pretty handy with a wrench, messing with the pump and belt is slightly intimidating.
    I think I may just have the dealer do it for the extra $150 to have the warranty and piece of mind. I just hate the thought of replacing something that could have lasted much longer or forever.
  7. Oct 1, 2014 at 4:55 PM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    Change the water pump! It is easy to get at now with them removing the stuff from in front.
    Change the belt too... be done with it and not out in the boonies or coming home from work when it breaks!
    Neither of my second gen water pumps 'failed'... BUT, a drip was seen coming from my 2010 at a recent service (60,000 miles), so I had it and the belt replaced.
    My first gen had the scheduled timing belt change at 90,000 miles and they saw a drip from the water pump, so it was changed... no extra labor, just the part.
  8. Oct 1, 2014 at 7:39 PM
    smd3
    smd3 Well-Known Member
    Pump and belt should be nowhere near 300, even dealer prices. (If the labor is covered under the warranty work)
    It's not that hard to change on these trucks, and it's run off the serpentine belt that runs everything else.
  9. Oct 1, 2014 at 9:18 PM
    Crom
    Nick
    San Diego, CA
    Millions
    The serpentine belt is super easy, about 30 minutes if you never done it before. Remove skid plate, work from below, use screwdriver to hold tensioner open. New bando belt was $20. Pictures on Tacoma world made it possible for me.
  10. Oct 1, 2014 at 9:24 PM
    Lord Helmet
    Lord Helmet Prepare To Attack
    Nick
    '24 X3 M40i
    Just remember that's a 8 years old truck with 95k miles on it. That's about the right time to replace the water pump. The engine heat cycles that rubber gasket thousand of times already. Since you have access to that part already, I say replace. Just not at that dealers price though.
  11. Oct 1, 2014 at 9:50 PM
    Amo-cat3
    Amo-cat3 Wizard Sleeve Master
    Maui, Hawaii
    07 TRD Blown dubcab
    TRD Supercharged 4.0 w/ 2.5" Quick change Pulley, UCON EMS, URD 7th injector, AFE Stage II intake, DT Longtubes, MBRP 2.5" dual exhaust w/ Vibrant Ultra resonator, URD Y-pipe w/ vibrant v-bands (Cat free), Walboro 255 fuel pump, SS Oil catch can, Aeroforce gauges, Icon CDC 2.5 coilover set at 3", 1.5" Wleelers Progressive aal, Light racing uca, 17x8.5 Fuel Anza 4.5" backspace/-6 mm offset, Kelly Safari a/t 265/70/17, scanguage 2, AMP electric steps, bed extender, Low-pro tonneau cover, 20% tinted windows/headlights/taillights, tacoma seat covers, Image dynamic sound system w/ Pinoneer avh3200 head, assrtd stickers................
    x2
  12. Oct 1, 2014 at 9:55 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    No way would I pay 300 for a water pump and belt. 150 dollars all day long for an Aisin and less than 100 dollars for aftermarket. They are not giving you free labor, they are just hiding the labor charge in the price for the pump.
  13. Oct 2, 2014 at 7:19 AM
    UltraE05
    UltraE05 Well-Known Member
    2010 Tacoma Crew Cab
    Price of the coolant is also added into that price. Your getting that much covered for free, you might as well give them alittle business. Sad part is its not like the tech benefits from it at all....
  14. Oct 2, 2014 at 7:31 AM
    Fordless
    Fordless Well-Known Member
    Jack
    Central Alabama
    2015 Tundra DC SR5+
    I agree, go ahead and cough it up...Piece of mind is worth a lot more than 300 bucks
  15. Oct 2, 2014 at 7:56 AM
    Canufixit
    New England
    Why is the Tech not getting paid?? IT's a warranty job - I do believe they get paid for these types of repairs. As for the water pump - Why would someone expect to get paid twice when the water pump is changed anyway ?? What am I Missing here ?? :notsure:
  16. Oct 2, 2014 at 9:44 AM
    UltraE05
    The tech took the time to upsell a water pump and belt. He doesn't see a cut of that profit since hes already paid to do the repair. No added time gets billed or added to his time card, that's if hes flat rate tho. Point is hes not gaining anything from recommending you a water pump and belt, hes saving you money since he could of said nothing and just swapped the old parts over. Hoping when the water pump fails or the belt needs replacing he can do the job again.
    Warranty also pays half the book time, its sad.
    Think you can do a power steering rack in an awd sienna in 1.1? No way
  17. Oct 2, 2014 at 10:14 AM
    Amo-cat3
    Maui, Hawaii
    07 TRD Blown dubcab
    I don't think it's necesarily an upsell, it's just a recomendation that is followed by most mechanic/techs that since they are in that far and have taken other factors such as mileage (95,000) that this is a legit recomendation. I don't think the tech is looking forward to see his truck again so he can do the waterpump. Yes the part is going to cast more, but it's already apart and at the dealer - let them do the new water pump and not worry about it anymore.
  18. Oct 2, 2014 at 11:42 AM
    TrapComa
    TrapComa Well-Known Member
    Mason
    Cedar Park, TX
    07 Indigo Ink LT PreRunner
    Wannabe prerunner, wannabe overlander
  19. Oct 2, 2014 at 12:46 PM
    someperson39
    Thanks for the input. I went ahead and gave them the ok to replace the pump and belt. Might as well just get it done now and not have to worry about it. I should get her back within a few days
  20. Oct 2, 2014 at 7:52 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    They will have to dump the coolant to do the warranty work anyway. They shouldn't charge for that.
