water pump tool
Discussion in '1st Gen. Tacomas (1995-2004)' started by Bartaco, May 11, 2011.
  1. May 11, 2011 at 5:47 AM
    Bartaco
    Bartaco [OP] Well-Known Member
    Bill
    Connecticut
    Red extra cab 6 cyl with chip,gibson flowma
    Bilstein 5100 series ,uniball uca's,3" lift kit ,extra leaf, Gibson exhaust.limited slip rear, six lug,lock out hubs,K&N air cleaner sysytem
    Is there any special tools needed when installing a fan/clutch on 3.4- 6 cyl?I heard about a tool used for holding rthe water pump pulley. has anyone used it??
  2. May 11, 2011 at 8:00 AM
    BFA
    BFA Nuttier than squirrel shit.
    Brian
    Phoenix, AZ
    2003 3.4 4x4 5spd
    i jammed a wrench in one of the pulleys to keep it steady to wrench the bolts off the fan clutch.. could probably get away with doing that in reverse
  3. May 11, 2011 at 8:58 PM
    Bartaco
    Bill
    Connecticut
    i probably should have just asked you HUh? thought you might be getting sick of me :eek: thanks, I read somewhere that theres a tool you need. I've never done it so I wanted to be prepared for the job.Do I need to preload the spring on that clutch? talk to Billy
  4. May 11, 2011 at 9:12 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    x2, that's how I got it off when doing the T-belt.
  5. May 11, 2011 at 11:24 PM
    Bartaco
    Bill
    Connecticut
    I just lost 2 subscriptions is it somthing I said or did????:confused::confused::confused::confused::confused:
  6. May 12, 2011 at 6:08 AM
    BFA
    Brian
    Phoenix, AZ
    2003 3.4 4x4 5spd
    you need a tool to pull the crank pulley off but a wrench will do you fine :)
  7. May 12, 2011 at 11:49 AM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    It wasn't me :laugh:
    don't worry about it :thumbsup:
  8. May 12, 2011 at 3:08 PM
    wolfgang123
    wolfgang123 Well-Known Member
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    its happens....i got 2 negative reps because in a gas milage thread i said i was getting 30mpg on the highway. People got jealous so gave me negative reps.
