Water spots, stains, scratched glass, etc.
Discussion in 'Detailing' started by XXXX, Aug 28, 2012.
  1. Aug 28, 2012 at 12:29 PM
    XXXX
    XXXX [OP] Well-Known Member
    sKiP
    05 Prius
    To remove water spots use this (I have used it commercially for many years on hundreds of thousands of dollars worth of glass with zero issues)
    http://www.crlaurence.com/crlapps/s...380&History=39324:4308:4323:4333&ModelID=4380
    or (I have never used this product)
    http://www.crlaurence.com/crlapps/s...20728&History=19748:19776:20626&ModelID=20728
    When your done cleaning the water spots use a sealer or you WILL get stains again!
    This sealer can last years http://www.crlaurence.com/crlapps/s...384&History=39324:4308:4323:4333&ModelID=4384
    Never do the following to glass:
    1) Wax your windshield. Wax is not for glass and will fill the voids, chips, and clevises and haze over time. It's for paint NOT glass.
    2) Use steel wool of any kind. It creates hundreds of thousands of miniscule scratches that will make staining worse in the long run. They are not viable to the eye. Steel should never touch glass regardless of how hard you think glass and steel are. http://www.tacomaworld.com/forum/de...-way-clean-glass-our-members.html#post2034997
    If you don't want to believe me or my almost 2 decades working with glass see here (from Oldcastle Glass the largest fabricator of glass in North America written in conjunction with G.A.N.A. Glass Association of North America) http://www.winecellarinnovations.com/glasscleaning.pdf
    When cleaning acid etched, sand blasted, or frosted glass Mr Clean Magic Eraser is great. Sparkle listed above is also good. When your done cleaning it use a sealer so it stops absorbing oils, dirt, and chemicals.
  2. Aug 28, 2012 at 12:29 PM
    XXXX
    sKiP
    05 Prius
    reserved for scratch removal.
  3. Aug 28, 2012 at 2:08 PM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    what about crack removal?
    my stupid guy wont pass me truck this year and insp exp. on friday:mad:
  4. Aug 28, 2012 at 5:40 PM
    XXXX
    sKiP
    05 Prius
    Mines been up since 5/12....I have a year extension but won't stick it on my fractured windshield.
  5. Sep 4, 2012 at 6:50 PM
    pmosin
    pmosin Well-Known Member
    SoCal
    07 Access Cab 4x4 TRD 6spd
    ARE Camper shell
    I'd love to hear about scratch removal. My windshield wiper blade on the drivers side popped out of its holder and the metal "hook" on the wiper arm caused some very light scratching on windshield in one part of the arc, and it's kinda driving me nuts. Mostly because it's in my line-of-sight. It's almost like a haze, I'm not sure that I can feel it with my fingernail.
  6. Sep 5, 2012 at 4:59 AM
    XXXX
    sKiP
    05 Prius
    We use cerium oxide and a professional polisher at work, but this is good for home use.
    http://www.youtube.com/watch?v=Zk4XPcKq42c&feature=related
    If you can fit your finger nail in it, it's time for a new windshield. Please note you will be removing the surface of the glass until you get the the depth of the scratch. This may cause the glass to become blurry if the polishing is not tapered out correctly.
    Here is another members take on scratch removal with cerium oxide...http://www.tacomaworld.com/forum/de...hes-glass-using-cerium-oxide.html#post8470517
  7. Sep 5, 2012 at 5:18 AM
    Namyo
    Namyo -
    :cool: I could use this on the ex cab window.
  8. Sep 13, 2012 at 9:18 PM
    jrobcet
    jrobcet Well-Known Member
    Jeff
    Northern Idaho
    08 Off Road
    Pioneer AVH-P4300 DVD head unit, color matched grill, Grillcraft grill mesh, 2 Hella 500ff behind the grill
    Thank you Skip! You are the man!! :bowdown:
    CRL Sparkle took ALL the water spots off my windows! I had resigned myself to living with dirty windows, but they look like new again! :kona:
  9. Sep 14, 2012 at 4:51 AM
    XXXX
    sKiP
    05 Prius
    No problem. Now remember to seal them up or it will only happen again.
  10. Sep 14, 2012 at 9:35 AM
    jrobcet
    Jeff
    Northern Idaho
    08 Off Road
    I bought the sealer along with the cleaner. Windows are squeaky clean and sealed up. :D
  11. Sep 14, 2012 at 9:36 AM
    XXXX
    sKiP
    05 Prius
  12. Oct 22, 2012 at 4:39 AM
    95SLE
    95SLE Starting to get cold outside
    Tom
    Maryland
    09 RWD Access Cab
    Custom XM Install, Window Tint, Intermittant Wiper Install, AVS Bug Deflector, Bed Mat, TRS FX-R retrofits, CIBIE fog and spot lamps, PIAA 510 lamps, Acess LE cover, Weathertech Digital floorr mats, LED interior lighting, Pioneer AVH-2300BT HU, Boston Acoustics speakers, JL Audio Amp, shorty antenna, leather wrap steering wheel cover, Viper security system.
    Jeff:
    Were you able to purchase on line?
    Nevermind. I was able to purchase on line this morning.
    Should have both products by the time I have to clean all the windows in the house.
  13. Oct 22, 2012 at 6:10 AM
    XXXX
    sKiP
    05 Prius
    Let me know how you like them. What did you go with?
  14. Oct 22, 2012 at 6:13 AM
    Burgman
    Burgman I KEEEEEL YOU
    Stephen
    Ric VA
    08 PreRunner TRD sport Silver
    K&N intake, Boston Acoustic SL 60 6.5 components up front, Rockford Power T16 6.5 in rear, Pioneer P4100 HU, Soon to be Pioneer Prs 4200f
    So are you saying that if i clean and then seal my windows with the above mentioned products, i will not have waterspots the next time i wash?
  15. Oct 22, 2012 at 6:24 AM
    95SLE
    Tom
    Maryland
    09 RWD Access Cab
    I bought the two recommended products and should have them by the end of the week.
    I will do a follow up.
  16. Oct 22, 2012 at 7:01 AM
    danteisme
    danteisme Well-Known Member
    South Western PA
    06 DCSB Sport, 96 Integra GSR
    posting so i can reference this when i get off work!
  17. Oct 22, 2012 at 7:29 AM
    XXXX
    sKiP
    05 Prius
    No. Water spots are created by impurities in the water so unless your using distilled water and don't let it sit your going to have spots.
    What I am saying is if you use these products such spots will not stain the glass and the glass will be much easier to clean.
    Glass surfaces are full of ridges/bumps/scratches and over time acid rain and the sun eat away at it making the finish even more blemished just like paint. The cleaner is like a good clay bar and the sealer is just like a good paint sealer.
  18. Oct 22, 2012 at 7:42 AM
    themuffinman619
    themuffinman619 Play stupid games, win stupid prizes
    themuffinman
    Your moms house
    Saved for later. X2 on the magic eraser. That thing works awesome for stains of any sort.
  19. Oct 22, 2012 at 8:07 AM
    Burgman
    Stephen
    Ric VA
    10-4
    what about interior windows that have window tint?
  20. Oct 22, 2012 at 8:09 AM
    95SLE
    Tom
    Maryland
    09 RWD Access Cab
    Boyd:
    Can this solution also be applied to the inside of my home windows or do I just use the cleaner and skip the sealant on the insude?
