Waterproof Fuse and Relay Boxes - RFRM (10 relay) & RTMR (5 Relay) no Blue Sea/ SPOD
Discussion in 'Buy / Sell / Trade' started by skygear, Jul 15, 2014.
Thread Status:
Not open for further replies.
  1. Jan 4, 2015 at 12:26 PM
    #921
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Yep probably the best route.
    TWSkygear.com/ExpeditionBussBox
    Myskygear.net
  2. Jan 4, 2015 at 4:26 PM
    #922
    skygear
    skygear [OP]                    
    Some of the names are super cheap. others are quite costly. Interesting.
  3. Jan 4, 2015 at 5:05 PM
    #923
    Sandman614
    Tim
    '06 SR5 Off Road
    Skygear.xxx is something like $99 a month. Lol just scrolling down the godaddy list.
  4. Jan 4, 2015 at 5:26 PM
    #924
    skygear
    skygear [OP]                    
    .guru ..... interesting
  5. Jan 4, 2015 at 6:22 PM
    #925
    Sandman614
    Tim
    '06 SR5 Off Road
    SkygearDesigns.com or net
    SkygearCustoms.com or net
    Don't want people going to skygear.com when they want to go to your site.
  6. Jan 5, 2015 at 1:57 PM
    #926
    skygear
    skygear [OP]                    
    in other news, I ordered more to keep in stock for same day turnaround on some orders.
    another 1k of loom and wire in transit too.
  7. Jan 5, 2015 at 4:57 PM
    #927
    ckeene9
    ckeene9 Well-Known Member
    Chesterfield, VA
    '12 DCSB Supercharged 4x4 TRD Sport
    See Build Thread
    Is there a prefabbed plate available for your big box and use with intercooler reservoir?
    Thinking I might redo all the electrical in the truck over the winter.
  8. Jan 5, 2015 at 5:32 PM
    #928
    skygear
    skygear [OP]                    
    on the 8th of this month. I'll have hands on with an SC'd 2nd gen taco. I will make plates for it then. Unless you want to come to me and we can fab one on the spot for you. Plan was to make a template then send the dimensions to Yotamac so he can laser cut the design for the masses.
    Most likely it will be a small basic plate. No extra mounting real-estate for breakers. But thats is just a guesstimate. I will take all the measurements and fab one that day.
  9. Jan 5, 2015 at 6:52 PM
    #929
    ckeene9
    Chesterfield, VA
    See Build Thread
    Sweet! Don't need any extras!
  10. Jan 5, 2015 at 7:18 PM
    #930
    skygear
    skygear [OP]                    
    There will be a huge order of backs in 5 colors coming from OTRATTW in the next couple days. Switch Backs. Will finally get these done for everyone.
    Still working on the Deutsch connection.
  11. Jan 5, 2015 at 7:31 PM
    #931
    Techoma
    Techoma This is the Wild, Wild, West!
    Alta Mesa, AZ
    Extreme Expo 05 PreRunner
    Dirty fives on Level 8s, 4.88 gears and Harrod Locker on rear. Cab Chop x2, MBRP Cat Back Dual Exhaust w Flowmaster 44 for punch, cut off at rear axle, Throttle Body spacer, Camburg UCA and Coil-Overs, Matrix Spindle lift up front ProComp extended travel on rear w\ Dakar leafs +, Panasonic HU w Front x2 and rear x1 camera, kicker 500 powering 2 JL Audio 10" subs, JL component speakers in front doors and JL audio coaxials in rear doors powered by alpine 600 amp. Cobra all in one CB, Easy Lift hood, and Easy Down Tailgate, Pop N Lock, Dual RGB Halo Projectors, Blacked out tails with HI intensity LED's, Scanguage II, AVID Custom sliders and Hybrid rear bumper, Pelfreybilt Hybrid front, Glock Steering Column Holster, 2 Hella's behind Satoshi on Avid light Bar, Decepticon Badges, 2x 24" LED ropes and 2X 4" HI LEDs to fire up Satoshi w Super Bright green Halo's. Under Hood lighting as well as RGB rock lights. PrinSu Cab/Shell Rack with FreeSpirit hard shell RTT, 28", 2x 20", and 50" LED Bars all controlled by SwitchPros and Weathertechs front and rear.
    Skygear,
    Where is home. I know you were well north in VA, but where? I'm contemplating stuff....
  12. Jan 5, 2015 at 8:00 PM
    #932
    skygear
    skygear [OP]                    
    Replied.
  13. Jan 6, 2015 at 1:17 AM
    #933
    skygear
    skygear [OP]                    
    Forgot to post up, I figured out the illumination wires for our vehicles. Light green with stripes. One is Positive, other is negative. Tap into an existing switch or blank switch from the OEM harness. DO not jumper the negatives on the switches if you want it to illuminate properly.
  14. Jan 6, 2015 at 9:22 AM
    #934
    Base Camp
    Base Camp Instagram: @willismtc
    Willis
    Roanoke, VA
    '14 Base Model 4x4
    Can't thank you enough for the help on the install. I will throw up some pics in the next few days. Work is keeping me busy lately... Hope to make it Thurs.
  15. Jan 6, 2015 at 11:59 AM
    #935
    BrttClne22
    BrttClne22 Well-Known Member
    Britt
    Asheville, NC
    2015 Barcelona Red DCLB 4x4 V6
    Would you suggest a relay on the positive illumination wire if running to multiple switches?
    What do you mean by don't jumper the negative? Just don't use the illumination wire as a negative for the switch?
  16. Jan 6, 2015 at 12:21 PM
    #936
    skygear
    skygear [OP]                    
    depending on the switch you use, the instructions for it will have pin 7 and 8 as jumpered/ connected since they are negatives.
    no relay
  17. Jan 6, 2015 at 10:26 PM
    #937
    tacodane
    tacodane The Slow But Getting Somewhere Build
    Dane
    2013 Tacoma Prerunner SR5
    Led Interior Lights AFE CAI Stage II, Aero Turbine 2525 Muffler Snugtop Cab-Hi shell TRS Retrofitted Headlights
    But for the 7 and 8 pins are negative, why can't we tie them all together?
    All I know is once I mount my panel and get my switch plate I'm messaging you to make sure I do everything right.lol
  18. Jan 6, 2015 at 10:34 PM
    #938
    skygear
    skygear [OP]                    
    on the toyota tacoma, they dim negative. later today I will get some photos up.
  19. Jan 6, 2015 at 10:45 PM
    #939
    bry838
    bry838 Well-Known Member
    oregon
    '00 tacoma 2.7 4x4 reg cab 5speed x's 2. '01 T4R 3.4 5 speed
    Thank you skygear yes that does clear it up for me. Well put!
  20. Jan 6, 2015 at 10:53 PM
    #940
    skygear
    skygear [OP]                    
    no problem. If i can help, i do. Dumbest question is the one never asked
Thread Status:
