Waterpump replacement-my amateur experience
Discussion in '2nd Gen. Tacomas (2005-2015)' started by thinkingman, Oct 3, 2011.
  1. Oct 3, 2011 at 2:27 PM
    thinkingman
    thinkingman [OP] Well-Known Member
    redmond WA
    2006 dbl cab 4wd 6sp
    Foglights are for fog, not oncoming traffic!
    My 2006 was oozing smelly pink juice so I ordered h2o pump and serpentine belt, tophose, thermostat, 2gal Zerex for Asian cars at Napa.
    Total $160.
    I looked at many posts re method to replace, incl shop manual.
    I took it all in and kind of made it my own.
    First, remove skid shield and the cover connecting the radiator to the fan shroud.
    Crack the drain over a bucket.
    Next top hose and bottom hose.
    It is suggested in the manual the shroud comes out next....this is not true....you have to un-bolt the fan and take both out together...there is not clearance for the shroud without removing the fan.
    Then the pulleys, left, right, and tensioner(tensioner is LH thread).
    The two coolant lines to the oil filter base.
    then the 14 bolts for the pump, plus 3 for the inlet.
    remove the pump (reposition your catch bucket first!)
    clean the surfaces and 14mm bolts you removed...they had sealant on the threads.
    I did not apply Permatex to the gasket...it looked clean and tight and didn't see the need.
    I did not drain the heater core.
    the fillup took 2 gal of coolant incl overflow reservoir.
    worked great.
    2.5hrs for an amateur with handtools, doing it for the first time.
    Saved over $300.
    Thanks to those who offered knowledge.
  2. Oct 3, 2011 at 5:26 PM
    mhuff29
    mhuff29 TÅpƐwo®m
    Arvada, CO
    05 Tacoma Double Cab SR5
    Air Filter (K&N) Wheels & Tires
    Wow!! My hat off for ya, I would probably double your time frame if it was me, but like you said you saved $300.
  3. Oct 3, 2011 at 5:32 PM
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    good job on the swap out. Some one else will probably chime in here... but you should have gone to the stealer to buy the antifreeze. Not sure if mixing the two brands is a good idea or not.... :notsure:
  4. Oct 3, 2011 at 6:18 PM
    907taco
    907taco Alaskan Assassin
    Bobby
    Alaska
    2010 BlackSandPearl 4x4
    ultimate lift kit ( toytec ) ome dakar leaf pack , w/ extended length billies, LR uca's, Pro comp 7089s, KM2's 285 70 17, neoprene seat covers, weather techs, CBI sliders w/kickout, URD ss, cab mount chop, VHT night shade tint>tails,3rd B-light. Debadged. Grillecraft grille, rear diff breather mod. CBI Moab front bumper, warn M8000 winch, HID kragens 7", Hella's micro fogs. retrofit headlights HIDS, LED solutions maps/license! 886 back up light mod,
    way to tackle this yourself! i have found that trying to do it yourself is very rewarding and getting to know your truck better. props to ya man.
  5. Oct 3, 2011 at 6:37 PM
    wlmuncy
    wlmuncy Well-Known Member
    William
    Knoxville, TN
    2007 Double Cab Manual 4*4
    You should be fine with the antifreeze.
    http://www.valvoline.com/products/brands/zerex/antifreeze/105
