Wax for scratches?
Discussion in 'Detailing' started by Joel Fox, Sep 25, 2007.
  1. Sep 25, 2007 at 3:49 PM
    Joel Fox
    Joel Fox [OP] Member
    What is the best wax to cover scratches? My color is impulse red, pearlized??
  2. Sep 25, 2007 at 11:37 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    How deep are they? Any pics?
  3. Sep 26, 2007 at 5:16 AM
    Joel Fox
    No pic's yet... the scratches are from my belt buckle. I would say they are very light minor scratches.
  4. Sep 26, 2007 at 10:23 AM
    humanoid
    humanoid bite me
    Sunny SoCal
    Any sort of polish will work. You should then follow that up with wax as well to protect it.
  5. Sep 26, 2007 at 1:55 PM
    Joel Fox
    Thanks....:)
  6. Sep 26, 2007 at 9:03 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    Don't get cleaning compound or anything with harsh abrasives, that would be bad!
  7. Sep 27, 2007 at 5:00 AM
    Joel Fox
    I was thinking of using a wax that had colorant in it already. I just didn't know if the color in the wax would make the scratches stand out or disappear? Because the paint is pearled.:confused:
  8. Sep 27, 2007 at 11:44 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    That should be fine, but I would still use a polish and then a wax first.
  9. Sep 29, 2007 at 10:31 AM
    Joel Fox
    I used a Meguiar's quick wax. It only minimized the very smallest scratches. Worked good as a wax though. I'll try the colored on next.
  10. Sep 29, 2007 at 11:08 AM
    tigerdongal
    tigerdongal Well-Known Member
    TRD SPORT
    Memphis PR Amp, Memphis 10" Sub, Custom Sub-box, Undcover tonneau, Pioneer DEH-P7900BT, USB Adaptor, Steering Column Adapter, Crossfire Car Audio XP2402 on the speakers. Now with dB Platinums and also custom tweeter mounts!
    Have a go with Meguires NXT, it is expensive but the results are outstanding. I can do my whole truck in about 30 minutes, Wax on, wax off without the arm ache.
  11. Sep 29, 2007 at 3:32 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    try some scratch x.....i believe meguiars has it, then polish and wax, then you should be good to go!!
  12. Nov 29, 2007 at 2:16 AM
    vivafire
    vivafire Well-Known Member
    Galveston,Texas
    2024 TRD 4X4 OFF ROAD
    Just Amber LED turn signal lights for now
    This is what I use to do with my wife's old suv and it did the trick,as long its for minor scratchs.
  13. Apr 25, 2008 at 9:18 AM
    BLOCKADE
    BLOCKADE Well-Known Member
    TRD Off Road
    Weather Tech Floor Liners, Front Bed D-Rings...
    Has anyone ever used nufinish? I would assume it's the same as scratch x but since nufinish doesn't have meguiars name on it I would think it would be a little cheaper.
  14. Apr 25, 2008 at 10:01 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    i think nufinish is more of a polish than a scratch remover.
  15. Apr 25, 2008 at 10:06 AM
    BLOCKADE
    TRD Off Road
  16. Apr 25, 2008 at 10:23 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
  17. Apr 25, 2008 at 11:39 AM
    hail-bop Command
    hail-bop Command Well-Known Member
    I Don't Crawl I Haul A$$!
    Yess its true Daniel Sun....
  18. Apr 25, 2008 at 8:19 PM
    ChibbMD
    ChibbMD Well-Known Member
    Dallas, TX
    08 PreRunner Double Cab
    I always felt that Meguiar's Cleaner Wax removed swirls and minor scratches as well as Scratch-X.
  19. Apr 26, 2008 at 5:44 PM
    4x4x4trd
    4x4x4trd My other ride weighs 200 tons
    North Texas
    08 White Access Cab TRD OR, Debadged
    AFE oil free drop in, Secondary removed, tint, front D-rings, Toyota bed mat, Undercover tonneau, TRD seat covers and floor mats, Pioneer speakers, Westin Platinum bars, Fumoto oil valve, short antena, Nifty Xtreme's, TSB leaf springs, Bilstein 5100's set at .85" in the front
    If small and not clear through the paint. McGuiars' Scratch X, and Harley Davidsons' swirl & scratch treatment works real well $5 for 8 oz.. Shouldn't hurt the clear coat with either. Us harley rider are a picky lot I might add. ;)
  20. Apr 26, 2008 at 8:46 PM
    it's in coma
    it's in coma Well-Known Member
    in the desert
    06 trd off road
    intake and exhaust
    what about the scratches behind the door handles.
