Wear Gouges on Spare Tire? Check Yours.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacomtn, Apr 22, 2012.
  1. Apr 22, 2012 at 10:12 PM
    tacomtn
    tacomtn [OP] Well-Known Member
    TRD OR,OME,Deaver AAL
    Whilst checking my spare tire for presssure as I occassionally do, I noticed there are areas of wear right where the tire contacts the steel portions under the bed. There are four patches and it seems to be just from constant rubbing while the truck is in motion. I'd say it's about 1/8" deep, enough be concerned that eventually it will wear through the casing and render the spare unsafe to use.
    My truck only has 12k miles and there's only so much tension you can put on this with the cable and pulley system on the spare. I need to show the dealer for them to correct this before it gets worse.
    Anyone seen this problem?
  2. Apr 22, 2012 at 10:25 PM
    myth01
    myth01 Well-Known Member
    south sf, ca.
    08 taco Trd sport
    eclipse nav.-w/ Bluetooth & iPod 3'' revtech add a leaf lift kit snug top ss truck cap dive tank racks in back Aux fuse box Aux back up lights, w/ interior fj cruiser stock switch Back up cam Turn signal cams Interior inverter -switched Aux audio/video inputs -RCA (including iPhone cable)w/ 4 input switch Mag light mount Tyredog stand alone tpms Spare tire extension hose Avid off road light bar(powder coated)
    You need to tighten your spare tire carrier. Mine was bouncing around once
  3. Apr 22, 2012 at 11:08 PM
    tacomtn
    It has always been tight. There's only so much tension you can put on there with the poorly designed pulley system these have.
  4. Apr 22, 2012 at 11:10 PM
    SnowroxKT
    SnowroxKT Well-Known Member
    Kyle
    Anchorage Alaska
    2008 TRD OR
    I have seen it on other cars as well, maybe put something in between the tire and the support?
    Or get a tire carrier or swingout on a bumper! (safety first :cool: )
    Rick111 and T4RFTMFW like this.
  5. Apr 22, 2012 at 11:13 PM
    S.B.
    S.B. Well-Known Member
    Sean
    San Diego
    15 Taco
    LT, Glass, CBI Front bumper, NWTI Rear bumper, 35s
    tighten the dang thing.
  6. Apr 22, 2012 at 11:22 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    Toyota has been using the same setup forever.
    Put some barrier between the tire and metal if you don't like it.
    Rick111 likes this.
  7. Apr 23, 2012 at 8:57 AM
    spithead051
    spithead051 Well-Known Member
    Patrick
    Fairfax, VA
    09 AC 4x4 OR S/C'ed!
    Supercharger, ICON 2.5VS w/ CDC, TRD T/X Pro Wheels, 255/85/R16 BFG MT KM2's, APEX three hoop bumper, Smittybilt X20 Comp Gen 2, Allpro IFS skid, All-Pro Sliders, Dynomax exhaust, aFe Stage 2 si, URD 2.85 stealth pulley, Oil pressure, oil temperature, boost, A/F ratio gauges, Devil horns, WO seat covers
    I put some 3M caulk strips on the steel bars mine rubs against. I noticed the wear and just put that there to stop it. Overall, I'm not too concerned with it
  8. Apr 23, 2012 at 9:06 AM
    81shark
    81shark Well-Known Member
    tighten it up a little. mine is fine
  9. Apr 23, 2012 at 9:13 AM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Bethel Park, PA. Burb of da Burgh.
    2010 MGM Mostly Stock Off-Road 4x4
    TRD Cat-back Exhaust. Semi-Debadged. Trimmed down stock Antenna. Weathertech vent visors. TRD FJ Cruiser Center Cap Wheel Mod. 265/75/16 Firestone Destination A/T,s . Inverter tapped into for outlet in cab. Tacomaworld sticker which adds 5 hp.
    I don't have wear marks so to speak on mine, I have like, indentations on mine. OP, that shouldn't be moving around, so maybe the dealer can tighten something up so thats not moving around.
  10. Oct 11, 2012 at 4:40 PM
    Blackghost
    Blackghost Member
    Jim
    Scarborough, ME
    Black 2010 Doublecab TRD Offroad
    Interested in this post! I just dropped my spare tire on my 2010 Tacoma... and notice the gouges... six bars that had worn right into the rubber sidewall. I brought it back to my dealer, and after some discussions with the area rep, the tire was replaced. Poor design of the spare tire holder!
  11. Dec 12, 2012 at 1:14 PM
    tahoe_babbs
    tahoe_babbs Well-Known Member
    Sacramento CA (Folsom)
    08 trd taco
    As needed, and some not.
    I just pulled my spare out for the first time in four years that I've owned the truck (bought new) and experience the same thing. I've been to the dealership multiples times for other things and they have always put air back in it to turn off my light. I don't think the marks are becuase it's loose. It fits snug up against the bars (not loose) but wiggles a bit side to side due to lack of lateral stability. There are, infact, indentations from being up tight against the bars. Also, the spare sits with the outside of the rim up so road debri shouldn't be a problem with an OR rim (non steelie).
  12. Dec 12, 2012 at 1:21 PM
    spiralout462
    spiralout462 Well-Known Member
    Eastern Shore VA
    2015 4x4 dclb
    Icon suspension '15 toyota nav TRD FJ SE anthracite wheels Weathertechs Trd pro pieces
    My boss told me she heard there was a recall for the spare. I didn't think much of it since I haven't heard anything personally. Plus she doesn't know the difference between a Taco, Frontier, Tundra etc.... But maybe shes not so far off after all. hmmmm?
  13. Dec 12, 2012 at 1:21 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I have 80k miles on my 2007 and I only have small indentations from the spare being held tight against the steel. No gouging whatsoever.
  14. Dec 12, 2012 at 1:23 PM
    BostonBilly
    BostonBilly Well-Known Member
    Easton
    2018 Jeep Wrangler JL Rubicon
    OP any pics
  15. Dec 12, 2012 at 2:15 PM
    BUZZCUT
    BUZZCUT Well-Known Member
    Georgia
    2021 TRD OFFROAD 4x4
    Same here :confused:
    Dropped the spare on my 03 Tahoe for the first time last summer. Looked great for riding up there for 9+ years. It also had indentation from where it was held against the frame.
    Rick111 likes this.
  16. Dec 12, 2012 at 2:26 PM
    6spdtaco
    6spdtaco Well-Known Member
    VT
    Taco
  17. Dec 12, 2012 at 2:29 PM
    BUZZCUT
    Georgia
  18. Dec 12, 2012 at 2:29 PM
    OffroadToy
    OffroadToy kokanee smoker
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    To fix that problem just mount the spare with the indentations facing down and flip it every year or two. :rolleyes:
  19. Dec 12, 2012 at 2:34 PM
    monkeyface
    monkeyface Douchebag, or just douche if we're friends
    Colorado
    '90,'97,'12,'05 Tundra 4.7,'07 T4R 4.7,'08 T4R 4.7
    ^^^This.
  20. Dec 13, 2012 at 5:52 AM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    I might just take a look at this with my truck- I have never seen this issue with any one my trucks of the past or even heard of excessive wear on the spare to this mounting option? :confused:
