Weather Temp gauge
Discussion in '2nd Gen. Tacomas (2005-2015)' started by vijay, Sep 15, 2015.
  1. Sep 15, 2015 at 12:07 PM
    vijay
    vijay [OP] Well-Known Member
    Hello team, What option do we have to get a weather temp installed? I'm confused, my TRD Pro did not come with one. I do not want those stick things...I need something for real world(outside temp).
  2. Sep 15, 2015 at 2:54 PM
    Yoda's TRD
    Yoda's TRD Well-Known Member
    David
    Haslett, MI
    2025 TRD Sport Hybrid
    most people here to upgrade the rear view mirror to a GENTEX version, that can have temp + compass in the corner of the mirror.
    Someone on here sells them, has all the wiring etc you could need
    I'm adding one to my '15 Sport
    T_Bone and Arkie-Marty like this.
  3. Sep 15, 2015 at 2:56 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Look up Bobs Mirrors, you can add a mirror with compass and outside temp and if you are lucky like I was there will be a wired plug up in the headliner.
  4. Sep 15, 2015 at 3:19 PM
    Clearwater Bill
    Billy
    Largo Florida
    The year of your truck matters in terms of how it may, or may not, be prewired.
    My '13 base was fully prewired for all the mirror options, including rear camera display. I picked up an OE mirror from the for sale section here, one with auto dim, temp, compass and rear view display. I then found a camera on ebay. Had everything installed and working in about 45 minutes.
  5. Oct 4, 2015 at 1:04 AM
    Tyson
    Tyson $Mr.T$
    Tyson
    Wyoming
    15' TRD off road, dbl, 6spd, 4.0L
    All-Pro UCA Stage 4 Icon lift redline hood struts interior dome and map LED lights 2 spot led pods (ditch lights) flush mount rear back up flood pods hood and bed LED lights GPS anytime mod RTMR electrical system (relays fuses etc.) weather tech floor mats anytime fog lights bixenon headlights and fogs ABS off switch anytime rear e-locker 30" OSRAM light bar (in grill) ARB CKMTA12 compressor ARB front locker Rock sliders all-pro Apex coming later: Doug Thorley long tube headers Y pipe Exhaust
    how about for a 15' off road.... I have the GPS in mine... nothing with the mirror. but I still really want an outside temp gauge
  6. Oct 4, 2015 at 1:11 PM
    TrackAttack
    TrackAttack Well-Known Member
    Joe
    St. Louis, MO
    15 Supercharged Inferno Red TRD Pro
    The Pro has Homelink built in to the mirror, so replacing the mirror is probably not the best option. The Entune HU has the temp,in the weather app, but if you are not in HD range, you will not get the temp. I'd like to,have an option to have a real temp reading outside of the HU. Any other options outside of the mirror?
    TacoDan723 likes this.
  7. Oct 4, 2015 at 1:42 PM
    HK33
    HK33 Member
    2015 White Sport DCLB TRD
    I installed one on Bob's mirrors, a 453 it has compass, temp, auto dim and garage openers.
    You need to install the temp prob and fish it through the firewall.
    I have a 2015 and all wiring was there except the temp prob wire.
    Tyson likes this.
  8. Oct 4, 2015 at 2:12 PM
    rottenpixies
    rottenpixies Well-Known Member
    New York
    2015 DCLB 4X4
  9. Oct 5, 2015 at 7:03 AM
    HK33
    HK33 Member
  10. Dec 6, 2015 at 5:00 PM
    Harley2
    Harley2 Well-Known Member
    Rick
    Vermont
    15 Super White Double Cab 4x4
    Your 15 has all the wires? Where are the wires located? Thanks
  11. Dec 6, 2015 at 5:54 PM
    shakerhood
    Southern Ohio
    When you pull the overhead console down the plug and wiring is there.
  12. Dec 6, 2015 at 6:42 PM
    HK33
    HK33 Member
    Some 15 have wiring and others don't. As shakerhood said look in the headliner.
  13. Dec 6, 2015 at 6:54 PM
    TacoDan723
    TacoDan723 Well-Known Member
    Dan
    Pacific Northwest
    2015 MGM Tacoma Limited
    I have the 2015 Limited. It has the weather app in the HU but I really don't like it. It sometimes shows the weather 20 miles away! You think it may have all the wiring needed to show the temp in a mirror?
  14. Dec 6, 2015 at 7:02 PM
    shakerhood
    Southern Ohio
    No reason you should not have the wiring. My 2015 has the plug and wires up there, the only wires I had to run were to the temp sensor.
    T_Bone likes this.
  15. Dec 6, 2015 at 7:14 PM
    T_Bone
    T_Bone Mr. T-Bone
    Denver metro
    2014 TRD Silver lockers and towing pkg
    LEDs DRL, inside outside/ Scan guage II/ Cipa mirror with Ram Mount/ Tech Deck/ Head Waters Seat covers (Kryptek) / De Badged / Heated Seats / Bak Flip bed cover / Pop & Lock and hose clamp /
  16. Dec 6, 2015 at 7:21 PM
    pyriteCO
    pyriteCO Well-Known Member
    CO
    15 TRD O/R Pyrite Mica
    Icon 2.5 extended travel front resis with 700lb coils, LR UCAs, Heated Seats, All-Pro rock sliders, snugtop xtr camper, rear OME full Dakar leaf pack, ride rite airbags, Fox factory series 2.0 extended travel remote rear reservoirs, Demello three hoop front bumper.
    I just ordered the CIPA 36400 from Amazon.. $129 shipped to your door. Seems like it'll do the trick..
    T_Bone likes this.
  17. Dec 6, 2015 at 7:25 PM
    shakerhood
    Southern Ohio
    I got so used to having a Compass, Outside Temp Gauge, and Clock in my 08 that I hated not having them in my 15, took care of that with the mirror, only thing left to add now is the digital clock.
    pyriteCO likes this.
  18. Dec 6, 2015 at 7:31 PM
    T_Bone
    T_Bone Mr. T-Bone
    Denver metro
    just a FYI on the temp probe mounting location. I have mine right behind the grill which most of the time is good BUT when doing some wheeling the heat from the radiator will mess with it. SO dont do what I did. Me thinks more in a fender well will work better . . .
    pyriteCO[QUOTED] likes this.
  19. Dec 6, 2015 at 7:34 PM
    pyriteCO
    CO
    Yea I was planning on putting the sensor behind the grill, but I'll look at other options. I appreciate the heads up! Got it in a couple days ago, just haven't had a chance to install it yet.
  20. Dec 6, 2015 at 8:37 PM
    shakerhood
    Southern Ohio
    I mounted mine behind the grille near where what looks to be another sort of temp sensor.
