Weathertech mudflaps
Discussion in '3rd Gen. Tacomas (2016-2023)' started by WTequipped, Dec 21, 2015.
  1. Feb 23, 2016 at 6:35 AM
    #101
    seizuresalad
    seizuresalad Member
    2016 Silver Tacoma TRD OR DCSB 6sp M/T
    I'm new to TW and the amount of ground clearance available. Do mudflaps ever become an issue for clearance - do they scrape/get damaged when clearance is still possible but extremely close to the limit?
  2. Feb 23, 2016 at 6:37 AM
    #102
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    I've had the stiff / molded plastic mud guards like the OEM and Weathertech style get pinched and ripped off. This is why I went with a rubberized floppy flap that does not hang too low. If you don't off road much, drive through deep sand or snow, big potholes, backing over logs or large rocks...then you should be fine with the WTs
    seizuresalad[QUOTED] likes this.
  3. Feb 23, 2016 at 6:41 AM
    #103
    seizuresalad
    seizuresalad Member
    Thanks, this is helpful.
    smitty99[QUOTED] likes this.
  4. Feb 23, 2016 at 11:36 PM
    #104
    MuddyTacos91
    MuddyTacos91 Well-Known Member
    3rd Gen DCSB TRD OR 4x4
    WITH fender flares (stock OEM Off Road Fender Flares)
  5. Mar 1, 2016 at 3:00 PM
    #105
    j102
    j102 Well-Known Member
    2016 Tacoma SR5 4x2 Double Cab Short Bed.
    I installed the WeatherTech (front only) ones today. They fit and look great!
    WTequipped[OP] likes this.
  6. Mar 1, 2016 at 3:27 PM
    #106
    Garyji
    Garyji Well-Known Member
    Gary
    Western North Carolina
    2016 BR SR5 DCSB V6 4WD. TRD Pro 17's, BFG KO2's
    What tires/Wheels are you running?
    G.
  7. Mar 2, 2016 at 10:48 AM
    #107
    whopper
    whopper 2016 MGM 4x4 double cab
    wayne
    north carolina
    2016 tacoma double cab 4x4 MGM
    On going
    I just got the factory one for $69.99 all four
  8. Mar 2, 2016 at 5:43 PM
    #108
    j102
    The Hankook HT 16" tires that came with the truck. I changed the wheels to Tuff wheels. But, my comment was in reference to the look and fit on the trucks without fender flares.
    My Tacoma is the SR5 model without fender flares.
  9. Mar 2, 2016 at 7:03 PM
    #109
    Garyji
    Gary
    Mine too. I put the TRD Pro 17's with BFG KO2 265/70/17, and they rub a little. Not a big deal and certainly not WT's fault.
    G.
  10. Mar 10, 2016 at 6:45 AM
    #110
    psvines
    psvines Well-Known Member
    2016 SR5
    I installed 4 WeatherTech mudflaps today in about 30 minutes. They fit very well. This will meet my needs as most of the use will be on roads.
    This was after 2 failed visits to the dealer to have OEM flaps installed. First visit was "oops, they didn't come in". Second visit was "oops, they don't fit".
    Garyji and WTequipped[OP] like this.
  11. Mar 10, 2016 at 7:13 PM
    #111
    TyFX
    TyFX Well-Known Member
    2016 TRD Sport 4X4 Access Cab - Inferno
    Arrived today. Installed in 15 minutes.
  12. Mar 22, 2016 at 11:45 AM
    #112
    jason_beekeeper
    jason_beekeeper New Member
    16' TRD Sport DCSB
    I have a trd sport, with the flares.
    Weathertech sent a pair of screws for the rear set I have no issue there.
    For the Front Pair: They did not send screws, and in speaking with them, they claim I don't need one. I do not have a screw in the upper inside location, should the factory have included a hex screw here? There is a faint red circle on the location in question.
    Second question, how tight should the screws be? the screws seemed at the bottom, but I still could turn more, very easily. I don't want to strip the material it is threading into.
    Thanks in advance for your comments/advice.
    EDIT: To clarify, Weathertech claimed i should have a screw at the location, and they didn't need to send me a screw.
    smitty99 likes this.
  13. Mar 22, 2016 at 11:56 AM
    #113
    TyFX
    Interesting. They included a pair of screws with my front and rear flaps. They are needed. As far as how tight should they be, you are correct in that you will strip the hole if you keep turning and they turn very easily. I just tightened mine until the flap would not move away from the truck any longer. I have checked them several times and they are staying put.
  14. Mar 22, 2016 at 11:57 AM
    #114
    smitty99
    Scottsdale
    Could add a little loctite for assurance too
    TyFX[QUOTED] likes this.
  15. Mar 22, 2016 at 12:14 PM
    #115
    Garyji
    Gary
    Noooo. Loctite will eat plastic. I got screws with mine for the inside fastener. My fronts also had a fastener behind the flap but Toyota didn't put the female fastener part in the hole in the body. WT sent me those parts. Not sure if the "Flares" version needs that fastener.
    G.
  16. Mar 22, 2016 at 12:29 PM
    #116
    TyFX
    The good news is that you can find those screws just about anywhere. I'd guess that I have a few lying around in the bottom of my toolbox.
    Garyji likes this.
  17. Mar 22, 2016 at 1:37 PM
    #117
    WTequipped
    WTequipped [OP] Active Member
    1)
    110055 - front pair of mudflaps should of included parts kit 48MF552 which is
    (2) #M6.3-1.81x 20mm, 16mm O.D.
    Loose Washer Hex Head Phillips
    Black Finish, Sems Sheet Metal
    Screw
    Sorry the CSR doesn't know what they are saying. Most likely new. Send me your info, and the name of the CSR if you have it, and I can then get a parts kit shipped out to you ASAP.
    2)As for tightness. The torque spec is really light. Not sure on the exact number but the screws are screwing into plastic grommets. Just snug them up enough so they won't come loose. Too tight and they strip the grommets.
  18. Mar 23, 2016 at 8:46 AM
    #118
    Garyji
    Gary
    WTequipped will definitely take care of you.
    G.
  19. Mar 31, 2016 at 12:54 PM
    #119
    Blue Hooligan
    Blue Hooligan Well-Known Member
    Winnipeg
    2017 Black Tacoma TRD Sport
    I was just checking out your website and I can't seem to find any other option other than just the rear set, but I'd like to get a front set too. Are you out of stock or am I missing something?
  20. Apr 1, 2016 at 7:26 AM
    #120
    manofsteele2003
    manofsteele2003 Well-Known Member
    2016 Blazing Blue TRD Sport Double Cab
    17" TRD wheels w/265/70/17 BFG KO2s, Weathertech mud flaps, Gecko LED bed lights, more to come.
    If you're looking for your 07 PreRunner than it doesn't look like they make a front set for it for some reason. They do for the 4x4 version, can't see those being any different and I'd guess they should fit.
