Wedge or TC Drop
Discussion in '1st Gen. Tacomas (1995-2004)' started by Cheesycook, Jan 9, 2011.
What driveline angle fix should I use with a 2.5 inch lift on a 2004 DC 4x4 TRD?
Poll closed Feb 8, 2011.
  1. TC Drop
    1 vote(s)
    50.0%
  2. Leaf pack shim
    0 vote(s)
    0.0%
  3. Nothing needed
    1 vote(s)
    50.0%
  1. Jan 9, 2011 at 9:30 PM
    Cheesycook
    Cheesycook [OP] Geek with a gun
    Hermiston, OR
    01 4x4 DC Tacoma V6
    I am getting ready to do a lift. Going for 5100's, OME 2.5 inch lift rear leaf packs and Toytec upper control arms. My issue is that I don't like having to pull things apart twice as I work an insane amount of hours and am lucky to get one day off a week. I want to take one day away from the family and get it all done asap. I have done lifts on Jeeps in the past but larger than this. I am concerned about vibrations, whether I can feel them or not.
    Can anyone recommend using a leaf spring shim or a Transfer case drop?
  2. Jan 9, 2011 at 9:41 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Not sure why you would want to do a transfer case drop. If you still have the stock two piece drive shaft, tc drop wont have the effect you want anyway.
    You might consider lowering the carrier bearing if you have vibes after lifting.
