Weird clicking noises from Shock or UCA.. Help..
Discussion in 'Suspension' started by RJALLDAY702, Dec 7, 2011.
  1. Dec 7, 2011 at 3:58 PM
    RJALLDAY702
    RJALLDAY702 [OP] U MAD? OH U MAD
    RJ
    Las Vegas
    2014 Toyota 4Runner
    6" Ruff Country DBL
    Getting some kind of weird clicking when suspension goes up, nothing appears to be loose..
    I know the vid drags on. But if anyone could identify anything, that'd be awesome! Shocks are still under warranty.
    Just skip ahead past all the driving and the BS
    http://www.youtube.com/watch?v=NBoMjnCvc3I
  2. Dec 7, 2011 at 4:11 PM
    jandrews
    '09 FourDubDee TRD OR
    Did you relocate the swaybar?
  3. Dec 7, 2011 at 5:17 PM
    RJALLDAY702
    RJ
    Las Vegas
    2014 Toyota 4Runner
    6" Ruff Country DBL
    Yes, theres a spacer
  4. Dec 7, 2011 at 5:26 PM
    RJALLDAY702
    RJ
    Las Vegas
    2014 Toyota 4Runner
    6" Ruff Country DBL
    If this is what your talking about
  5. Dec 7, 2011 at 5:36 PM
    sir1123
    sir1123 Tacomas FTMFW!!!!
    Charleston
    99 SR5 Prerunner, Black,3.4L
    3"Ebaich with 5100 Bilstiens, K&N cai, 5% 3M Tint, Magnaflow 18", Hella 500s with 35w 3000k hid retro, 33x9.5x15 BFG A/T
    i had a noise like that and the problem was on the bottom of the shock where you put the bolt thru. the casing around that ball joint was rubbing on the lca strut bracket. it would make popping noises when the my wheel would be turned and hit bump....it is easy to notice just look and see if the bottom of the coilove is seated straight in the lca bracket
  6. Dec 8, 2011 at 8:43 AM
    FixedTRD
    FixedTRD Well-Known Member
    Will
    Alhambra, CA
    All pro LT, All pro front bumper,All pro rear fox, 1.5 full leaf and u bolt flip kit. KR sliders, bestop, high lift with custom mount, katskin leather, Hankook MT and atx artillery. DMZ SUA w/FOX triple bypass
    I can't listen to your vid at work, but I had a issue where the sway bar was rubbing against the shock.
  7. Dec 8, 2011 at 8:48 AM
    Gregero
    Gregero TRD: Trail Ready Development
    Greg
    Carson City, NV
    Blue '06 Prerunner TRD Sport
    Debadged Tailgate, TOYOTA logo on Tailgate, Uniden Radio w/ 4' Ant., Removed Sway-Bar, Rear Icon Extended Travel Shocks, 8" King Offroad Shocks, Debadged Doors, 1.25" Rear AllPro Wheel Spacers, 315/70R17 Mickey Thompson Baja MTZs, AllPro Skid Plate, New Car Smell Air Freshener, OMD Ford&Chevy Leaf Pack with Original Main leaf, Engage LT UCAs and LCAs, Engage HD Tie Rod Ends, Kar-Tek Limit Straps, Camber Eliminator Kit, Removed Rear Flares, Blue LED Dome and Map lights, LED License plate lights, Black TRD Sport Rims, 20W PA Speaker, 2 Meter Radio, Demello-like Bed Bar, Harbor Freight Dust Lights, Blacked-out Hood Scoop, Custom Pre-Runner Bumper, JBA Long Tube Headers, MBRP Catback Exhaust, AFE Stage2 CAI, URD MAF Sensor Calibrator
    Matt and I were throwing that idea around as well yesterday.
    RJ, Have you checked the shocks and sway bar for any signs of contact against each other?
  8. Dec 8, 2011 at 8:50 AM
    11TRD
    11TRD MERICA
    Jay
    Everett, WA
    2011 TRD SPORT 4X4 DC
    Cobra 29 WXNWBT, Devil Horns, ARB Bumper, Avid Stepbars, Homer Taco Satoshi thin lip grille, ICON UCA's, ICON EXT Travel up front with King 700# springs, Dakar heavy springs, sumo bump stops, with ICON VS 2.0 shocks in the rear, K&N Drop In, AVS Ventshades and Bugflector, Whelen SPS 660 emergency strobes, Redline Hood struts and tailgate EZdown, Illuminated 4X4 Switch, TRD Floor mats, Flyzeye LED lighting, Kragen 7" HID behind grille, Kragen 4" HID back up lights, Rigid SR Series 10" LEDx2 Elusive elements Lightbar, Firestik antenna, Rear Diff breather mod, Fogs anytime, Hitch Safe, OEM door sill strips, mryo mirror relocate bracket, Prinsu designs roof rack, Tepui Autana RTT, ARB Awning,Engo 10k winch synthetic, Blue seas fuse block and breaker, ARE Topper
    Did you make sure to use an Allen to tighten the sway bar linkage? I had a similar noise last week after installing 5100's and didnt use an allen while tightening the swaybar linkage. Fixed after I took the wheels off and retightened with an allen.
  9. Dec 8, 2011 at 9:26 AM
    nelson18matt
    nelson18matt Well-Known Member
    Goodyear, Arizona
    2004 Long Travel Tacoma
    *SOLD*
