Weird Clunking Sound
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Esteban 15, Sep 17, 2020.
  1. Sep 17, 2020 at 6:36 AM
    Esteban 15
    Esteban 15 [OP] Member
    Stephen
    Bentonville, AR
    2011 Black DblCab 4x4 TRD Sport
    Typically when I drive off after the truck has sat for a few hours, I will get an audible "CLUNK" when I brake for the first time. It doesn't happen every time I brake but definitely the first time after sitting. I thought it was in the transmission but it happens when I touch the brake pedal.
    Thoughts?
  2. Sep 17, 2020 at 6:40 AM
    BINK05TRD
    BINK05TRD Well-Known Member
    Massachusetts
    TRD OR AC SILVERSKY 15
    Caliper slide pins click as they wear.
  3. Sep 17, 2020 at 9:35 AM
    nasaengr
    nasaengr Well-Known Member
    Red15 DC OR
    Brake pads shifting fore and aft against the calipers. Most noticeable on my truck when backing out of the garage.
  4. Sep 17, 2020 at 10:37 AM
    mabepossibly
    mabepossibly I know enough to make an ass of myself
    Andrew
    Albany, NY
    2021 TRD OR Manual
    Skids, Sliders, Lights
    3rd vote for the brake pads.
    there is also not much to be done about it. Just part of the design. Just ignore it and realize nothing is broken.
    BINK05TRD likes this.
  5. Sep 17, 2020 at 3:14 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Same here.
    Most people refer to it as pad slap.
    I almost considered it “normal” on these trucks. It can be even worse if you use cheap pads. The dimensions of the pad and slide pins can play a big role in the sound.
  6. Sep 17, 2020 at 4:04 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    Ok, this may sound like a funny question but it is a clack that you hear, or a clunk that you feel?
