Weird No Start Thing....
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Bryan07sport, Oct 28, 2009.
  1. Oct 28, 2009 at 12:30 PM
    Bryan07sport
    Bryan07sport [OP] Well-Known Member
    Bryan
    Smyrna, Delaware
    '22 TRD off-road.
    Bilstein 6112/5100. Icon progressive AAL. Overland Torque Tune. Toyota roof rack. Toyota bed extender. Gator trifold tonneau. Bora .75" wheel spacers. 265/75r16 tires.
    truck's got 28k miles TRD sport, MT. Let me start by saying that i'm used to my 4runner which had the feature where you bump the key to start and let go, and it will automatically keep turning the motor over till it starts.... so with that said, i've maybe done this half a dozen times w the taco, particularly when going back and forth between vehicles. Twice now, after bumping it, but it not starting, and then turning and holding the key, it just turns and turns. Doesn't sputter, hickup. Nothing. Give it a minute, try again, nothing.. 2 minutes try again still just turning... Now both times i've just gone inside and given in 20 mins or so, and it started right up like nothing was wrong. Please lend me some of that sweet TW wisdom and shed some light on my little issue here.
  2. Oct 28, 2009 at 1:08 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Turn the key, and hold it until it starts. 'bout the only thing I can tell ya.
  3. Oct 28, 2009 at 1:11 PM
    Afwrestler1986
    Afwrestler1986 Well-Known Member
    Johnstown, NY
    01 trd 4X4 ex cab manual
    Gray wire, Some lights in the bed area, and some character marks throughout.
    Probably dumb question, but you are using the master key right? and not a copy made at like lowes or something?
  4. Oct 28, 2009 at 1:13 PM
    Coreyjon
    Coreyjon Northern Alliance: Airlift Div
    Upstate, Ny
    08 DCab 4X4 SR5 TRD Sport
    iPod Adapter, Bilstein 5100's @ 1.75" front, Wheelers 3-leaf 1.5" + overload rear (2"), custom carrier bearing drop spacers.
    can anybody but the dealer even make a copy? I didnt think they could due to the immobilizer?
  5. Oct 28, 2009 at 1:29 PM
    Afwrestler1986
    Johnstown, NY
    They (lowes or other) can make a door key, but it won't turn the motor over. Another thing is my parents had a camry and a t-100 and both keys turned the ignition, they both cranked, but would not start either motor.
  6. Oct 28, 2009 at 1:30 PM
    Coreyjon
    Upstate, Ny
    good to know. thnx.
  7. Oct 28, 2009 at 1:33 PM
    wmflyfisher
    wmflyfisher Well-Known Member
    Wes
    PCB, FL
    2010 Sport 4x4
    I have the 6spd as well and mine does something similar at times. I turn the key and it just keeps turning over and over. Never starts. I release the key, hit it again and it fires right up. I keep thinking that I don't have my foot pressed all the way to the floor with the clutch. I don't think that's the problem though. Not really sure what it is...
  8. Oct 28, 2009 at 1:51 PM
    Amo-cat3
    Amo-cat3 Wizard Sleeve Master
    Maui, Hawaii
    07 TRD Blown dubcab
    TRD Supercharged 4.0 w/ 2.5" Quick change Pulley, UCON EMS, URD 7th injector, AFE Stage II intake, DT Longtubes, MBRP 2.5" dual exhaust w/ Vibrant Ultra resonator, URD Y-pipe w/ vibrant v-bands (Cat free), Walboro 255 fuel pump, SS Oil catch can, Aeroforce gauges, Icon CDC 2.5 coilover set at 3", 1.5" Wleelers Progressive aal, Light racing uca, 17x8.5 Fuel Anza 4.5" backspace/-6 mm offset, Kelly Safari a/t 265/70/17, scanguage 2, AMP electric steps, bed extender, Low-pro tonneau cover, 20% tinted windows/headlights/taillights, tacoma seat covers, Image dynamic sound system w/ Pinoneer avh3200 head, assrtd stickers................
    I think there was a TSB out for 05+ tacoma's that had a starter problem, something with the fuel pump/fuel delivery. Not exactly sure where i saw this, but i think it was an independent auto site i found when looking at used car/truck prices.
  9. Oct 28, 2009 at 2:53 PM
    Bryan07sport
    Bryan
    Smyrna, Delaware
    '22 TRD off-road.
    Thanks everyone for your input. Yes I use the same key every time, motor wont turn at all without the clutch switch engaged, and hold it till it fires up would burn up the starter.... I held it for a lot longer than i though the starter should prolly crank.... and even gave it a min and tried again. Its like something in the ECU or other computer stuff is shutting off fuel or ignition for some reason..... and after it sits for 20 mins something resets and fires right up.... Anybody else have any ideas??
  10. Oct 28, 2009 at 2:56 PM
    Bryan07sport
    Bryan
    Smyrna, Delaware
    '22 TRD off-road.
    I'm assuming that whatever you're experiencing is the same thing.... My truck always fires right up after just a couple rotations. Except for these times when nothing... my only problem is when it has happened, letting go of the key and trying again yeilds no results... i have to let it sit for awhile. hmmmm......
  11. Oct 28, 2009 at 3:13 PM
    Afwrestler1986
    Johnstown, NY
    Oh, one more thing to maybe check is the pressure switch where the clutch pedal comes down on. Sometimes the floor mat rides up and i can't push the pedal far enough,and once the switch actually came loose from the back of it's bracket.:confused:
  12. Oct 28, 2009 at 3:25 PM
    Bryan07sport
    Bryan
    Smyrna, Delaware
    '22 TRD off-road.
    thanks, but the motor wont turn over at all unless the switch is engaged.....
  13. Oct 28, 2009 at 3:32 PM
    Afwrestler1986
    Johnstown, NY
    Hmmmmmmmmm:notsure: I got nothing then. Good luck guys
  14. Oct 28, 2009 at 3:38 PM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    I have an auto 05 DC and I experience the same problem occasionally. I just have to let off, try again, and it starts right up! No idea what this is... Mostly because it doesn't happen every time, just once in a while.
  15. Oct 28, 2009 at 5:22 PM
    decrowe
    decrowe Member
    dcinwyo
    casper, wy
    2007 tacoma dblcab long box
    air bags on the rear
    I have a 07 dpuble cab, v6, i have the same problem. It is usually after I have driven it, let it sit for 10-40 minutes. turn the key and it turns over but wont start. I may have to try a time or 2 but it starts right up then.
