Weird noise after wheels installed
Discussion in '1st Gen. Tacomas (1995-2004)' started by Alpha Q Up, Oct 26, 2011.
  1. Oct 26, 2011 at 12:43 PM
    Alpha Q Up
    Alpha Q Up [OP] Well-Known Member
    Ruben
    San Jose
    2003 4WD DC Tacoma
    So this past weekend I got my lift installed (saturday) i drove around on the stock wheels and tires all day on Sunday. Everything was fine...breaking felt a bit off but that's about it.
    On Monday i have my new wheels and tires (285/75/16 duratracs) installed. As i'm paying they told me they heard a "clunk" when test driving it. They had the truck all day and i couldn't leave it any longer for them to look at it. So i took it home.
    After driving it around over small pot holes and dips i get an awkward feed back noise. Almost as if some thing was loose and is bouncing around on the bottom.
    I called the tire shop and they said that they can look at it. But if it's NOT related to the wheel install then i have to pay $60 for the labor.
    What can it be? Any ideas or suggestions?
  2. Oct 26, 2011 at 12:59 PM
    4Wheelin4Banger
    4Wheelin4Banger Supercharged Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Supercharged Silver State Edition 245WHP
    3" OME lift 885s & Dakars riding on 33" KM2s
    Tire rub? 285/75/16s will rub for most people up front without cutting & chopping.
  3. Oct 26, 2011 at 1:20 PM
    Alpha Q Up
    Ruben
    San Jose
    2003 4WD DC Tacoma
    No not rub.
    I just took it for another drive. And the best way to describe it is a "Rattle"
  4. Oct 26, 2011 at 1:31 PM
    scocar
    scocar hypotenoper
    Always?
    Straight line?
    Turns?
    Low speed?
    High speed?
    More clues?
    Have you jacked it up and done the wheel shake to see if it tie-rods or ball joints?
    Have the lower ball joints ever been replaced on your truck?
    Also, check the mounting bolts on the the LBJ. Other folsk have had these come loose, hanging on by a thread.
  5. Oct 26, 2011 at 1:32 PM
    ffirg
    ffirg Well-Known Member
    mike
    Anchorage, Alaska
    2002 Tacoma SR5 TRD 4X4
    Maybe your steering rack? Mine makes a bumping/clunking sound when going over bumps/potholes and I've been told I need new rack bushings.
  6. Oct 26, 2011 at 1:39 PM
    Alpha Q Up
    Ruben
    San Jose
    2003 4WD DC Tacoma
    It's at any speed. Mostly when i'm driving straight over some uneven road surface.
    I haven't done a "wheel shake" But i forgot to mention that I did get an alignment with the tire install.
    I doubt any LBJ have been replaced.
  7. Oct 26, 2011 at 1:40 PM
    Alpha Q Up
    Ruben
    San Jose
    2003 4WD DC Tacoma
    Interesting.... Does your steering wheel wobble with the noise though?
    cause mine doesn't.
  8. Oct 26, 2011 at 1:42 PM
    magog45
    magog45 Well-Known Member
    Canada, just south of Santa
    98 tacoma 4x4 extended cab
    5100's all around, 2.75 inch lift, polyurethane body mounts, gibson exhaust, variation of the deckplate mod, intake resonators removed 285-75-16 goodyear AT
    Check your rear shocks, and anything else that may have had to been moved, removed or replaced. If the sound wasn't there when you brought the truck in then its likely related to the lift install, also make sure all the lug nuts are tight.
  9. Oct 26, 2011 at 1:43 PM
    ffirg
    mike
    Anchorage, Alaska
    I don't know if I would say it wobbles, but there is some slop in the wheel. I can make the noise happen when I turn the wheel an inch or two left or right while stopped.
  10. Oct 26, 2011 at 1:48 PM
    Alpha Q Up
    Ruben
    San Jose
    2003 4WD DC Tacoma
    The noise came after the Wheel install. Not the lift.
    I'll check the lug nuts.
  11. Oct 26, 2011 at 1:49 PM
    scocar
    scocar hypotenoper
    First gens had a recall on the LBJ. Check this out. I can be really bad if it fails at speed.
    This is all good common sense before we jump to other conclusions. If the lift was intalled by someone else, check it all. Bolts may not be tight or not torqued to spec.
  12. Oct 26, 2011 at 1:50 PM
    Alpha Q Up
    Ruben
    San Jose
    2003 4WD DC Tacoma
    Yeah i don't think it has to do with my steering then.
