Weird noise
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ecotecin, Sep 15, 2016.
  1. Sep 15, 2016 at 9:27 AM
    ecotecin
    ecotecin [OP] Wait, whut........
    WV
    2014 DCSB sold (2020 Chevy Silverado Crew Cab)
    ok first lry me say that i have a 2014 4.0V6 with around 26,000 miles on it. Now with that being said, if i let my truck set for three or four days, when i start it up,i get this really weird like loud clangy noise.
    It only does it after i let my truck set for a couple days, and it only does it on the first start. I can shut the truck off, and immediatly start it back up and the noise does not happen again. It is only after is has set for three or four days. I know the vacuum noise, but this is completely different. The vacuum noise takes about 4 seconds before it happens, but this noise happens within a second or so of start up, then the vacuum noise happens after this noise.
    I have not lost any power or fuel economy, theres no noise whenits running, its just at that first startup. I will try and record it the next time i let it set a couple of days, ive been driving it everyday this week, but sometimes i drive my spare car for a week to keep it in working condition.
    I was just wondering if there was anyone else that was having or hearing this, and what it possibly could be. Its not like and engine clang either, its just a weird like plastic clanging together and not metal. Ive inly noticed it a handful of times.
    If by chance this is in the wrong section, admins please move it to the correct section.
  2. Sep 15, 2016 at 11:48 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    What type of oil filter are you using?
    Some cheap filters will allow the oil in the filter to flow back into the crankcase over time ( anti drain back valve is not present or leaking inside the oil filter ). Fram Filters are notorious for this.
    I think what you hear is the valve train and timing gears before it gets lubrication flowing again.
  3. Sep 15, 2016 at 11:49 AM
    ecotecin
    WV
    I take it to my dealer and get it done. Its factory parts. And its not really a metal clanking noise. Its more like a plastic type noise.
  4. Sep 15, 2016 at 11:56 AM
    DriverSound
    DriverSound Señor Member
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    You're still under warranty, have Toyota figure it out.
  5. Sep 15, 2016 at 12:09 PM
    ecotecin
    WV
    Thats the bad part. After it does it the first it wont do it again unless it sets for a couple days
  6. Sep 15, 2016 at 12:34 PM
    DriverSound
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    They'll most likely have you leave it overnight. No rental though unless they find something.
  7. Sep 15, 2016 at 4:50 PM
    ecotecin
    WV
    Yea i know. That the even worse part. My closest toyota dealer is about 45 mins away. Thats why i was asking if anyone else had heard it or not
  8. Sep 16, 2016 at 12:43 PM
    DriverSound
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
  9. Sep 16, 2016 at 4:54 PM
    ecotecin
    WV
    Mine could possibly be a lifter but it doesnt last that long, and it only lasts a second or so and then goes away.
  10. Sep 17, 2016 at 9:33 AM
    ecotecin
    WV
    Okay, I did t drive it for a couple days after i posted this and i recorded it. You can hear it just barely, its right before that loud thunk. I think the thunk was the vacuum, but it takes just a couple seconds before it does it and you can hear it. Like i said this inly happens after it has set a couple days. It does not do it everytime i start it. Im in the cab so its not super loud. Next time i will get it under the hood, disnt even think about it, gah
  11. Sep 17, 2016 at 9:34 AM
    ecotecin
    WV
    How you get a video recording on here? Im using my iphone
  12. Sep 17, 2016 at 9:38 AM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    How long does the noise last? Does it occur for 1 or 2 secs about 25 secs after you start a cold engine?
  13. Sep 17, 2016 at 10:10 AM
    ecotecin
    WV
    Its last about a second, if that. Its not the vaccum noise. That still happens. Its a dofferent kind of noise.
  14. Sep 17, 2016 at 10:14 AM
    Lester Lugnut
    Not sure what you mean by vacuum noise? Sure you are not hearing the air pump doing it's check that occurs 20-25 secs after you start a cold engine? Valve clatter noise usually lasts longer than a sec.
  15. Sep 17, 2016 at 4:17 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    If you have a 4.0 Liter V6 you don't have hydraulic lifters.
  16. Sep 17, 2016 at 5:57 PM
    ecotecin
    WV
    No its not 20-25 seconds after it starts. Its about 3-5 seconds after i start it. The vaccum noise is a weird like sucking noise then a thump. This is completely different kinda of a noise.
  17. Sep 19, 2016 at 12:20 PM
    DriverSound
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    My 2015 does the vacuum noise just right after start up and then followed by like a pop which could be the thump you're talking about because it's the valves shutting.
  18. Sep 19, 2016 at 6:57 PM
    ecotecin
    WV
    I havent drove it anymore, so im letting it set, to hopefully catch the noise again. Knowing how my luck goes, it wont do it whil im recording it.
