Weird smell in truck with AC fan on
Discussion in '3rd Gen. Tacomas (2016-2023)' started by uploadadventure, Jun 7, 2019.
  1. Jun 7, 2019 at 11:47 AM
    uploadadventure
    uploadadventure [OP] It’s all @ColoradoTJ’s fault
    Dixon, Mo
    2019 Cavalry Blue Tacoma TRD OR (sold) 05 Duramax
    Was wondering if anyone else has issues with their truck blowing weird smelling air in their truck with the windows up and ac fan on?
    Best way to describe it is it smells like fart...
    DouglasEverdeen and StayinStock like this.
  2. Jun 7, 2019 at 11:51 AM
    Old Swamper
    Old Swamper Tacoma World Poor
    Will
    Northern WI.
    2012 Black Tacoma TRD OR
    5100 & OME 884 AAL
    Pull your cab filter and see if something died in there.
  3. Jun 7, 2019 at 11:52 AM
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    Change cabin air filter, then spray a bunch of lysol in the duct in front of the windshield. I deal with this pretty often getting water off the street into the duct cuz I mob through a certain deep puddle every time it rains.
    Also, if you run the AC on recirc, it creates moisture in the system and gets musty. Turn recirc off a few mins before you get to your destination and you are G2G
  4. Jun 7, 2019 at 11:53 AM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    was it made in Texas or Mexico? Mine came from Mexico and smells like a taco. But Gunshot is right, you have moisture in the system.
    cricketfire46 and Taco_Coma like this.
  5. Jun 7, 2019 at 11:53 AM
    Norilsk
    Norilsk Well-Known Member
    Eugene
    J100 (Bougie) & UZN215 (Spartan)
    1. stop farting in the truck
    2. turn off air cycling
    3. profit
    but yeah, check the filter or consult with the dealer
  6. Jun 7, 2019 at 11:53 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Might be mildew, I usually turn the AC off about a mile or so from home to let the airflow dry out the system.
  7. Jun 7, 2019 at 11:54 AM
    Dustin.K96
    Dustin.K96 Well-Known Member
    Dustin
    2019 White Tacoma TRD OR
    Over time, you could have mildew growing in the AC vents due to the condensation in the system. One thing you can try doing is spraying Lysol in your interior vents, and turning your AC on without the recirculation while spraying Lysol into the intake vents under your windshield.
    Gunshot-6A likes this.
  8. Jun 7, 2019 at 11:55 AM
    SLICKYINC
    SLICKYINC Well-Known Member
    West Tennessee
    2017 QUICKSAND TRDOR LB
  9. Jun 7, 2019 at 11:55 AM
    Shellshock
    Iowa
    Need more air fresheners!
  10. Jun 7, 2019 at 11:59 AM
    MikefromCT
    MikefromCT Well-Known Member
    CT
    2013 TRD OR DCSB
    OME Bp-51; Relentless Armor
    This happens to me after chipotle. Thank god for chipotlaway.
    cricketfire46, SRH, stun gun and 3 others like this.
  11. Jun 7, 2019 at 12:01 PM
    Gunshot-6A
    Conner
    Everett, WA
    These guys know:
    SRH and uploadadventure[OP] like this.
  12. Jun 7, 2019 at 1:02 PM
    ICU1
    ICU1 Well-Known Member
    Check under your seat for that partially eaten double crunch TACO.
  13. Jun 7, 2019 at 5:55 PM
    Arries289
    Arries289 Yo!
    Franklin TN
    2018 TRDOR DCSB BBP 6MT Tech & Prem
    BigWhiteTRD likes this.
  14. Jun 7, 2019 at 6:07 PM
    awwbugman
    awwbugman Well-Known Member
    Kings/Deavers/SPCs 35x10.5 Kendas, LRA FuelTank, WARN Zeon10s SDHQ mount, Switch Pro, LightForce rock lights, reverse light & Lightbar, Baja Design Squadron Pro fogs, CaliRaised Sliders, RLD Canopy, Odyssey group 31, Dometic CFX3-55IM
    I have a fairly new truck (11,000 miles) and have had this issue intermittently since early on. The smell I get is sweet though, however i don't see any coolant leaks or overflow...
  15. Jun 7, 2019 at 6:13 PM
    GrievousAngel
    GrievousAngel Well-Known Member
    2019 Tacoma SR 4x4 V6 DCSB Super White
    I think it's mildew. Turn your compressor (CA) off before your destination, allowing the system to "warm up" slightly before you stop. Less condensation, less moisture, less mildew.
    It's a balancing act. You don't want to roast. But you don't want it to stink either.
  16. Jun 7, 2019 at 6:42 PM
    iShiFT559
    iShiFT559 Well-Known Member
    2018 Tacoma OFF Road 4x4 6-SPEEDd
    Upgrade Mishimoto Weighted shift knob
    Open your Windows when you spray the Lysol with the AC on.
  17. Jun 7, 2019 at 6:55 PM
    uploadadventure
    Dixon, Mo
    It’s fart. I’ve been farting in my truck.
  18. Jun 7, 2019 at 6:58 PM
    SRH
    SRH My horns hold up my halo
    Shauna
    2018 Sport
    Mystery solved huh? Good job, Sherlock :thumbsup::D
  19. Jun 7, 2019 at 7:03 PM
    uploadadventure
    Dixon, Mo
    That’s Mr Holmes to you young lady :D
    Gritto and SRH[QUOTED] like this.
  20. Jun 7, 2019 at 7:12 PM
    CusterFan
    CusterFan Well-Known Member
    Southeastern Illinois
    Silver Sky 2019 Tacoma SR, AC, 4X2, 2.7
    I tried that on the '16 SR5 I traded off. I could not get the hose past the firewall via the a/c drain tube.
