weird sound after front 5100s
Discussion in 'Suspension' started by dmcnealy22, Dec 15, 2011.
  1. Dec 15, 2011 at 10:54 AM
    dmcnealy22
    dmcnealy22 [OP] Well-Known Member
    Indiana
    07 4x4 bsp
    Front 5100's @ .85
    I just installed 5100's on the front of my 07 4x4 access cab base model yesterday. Before the install I measured all my fender heights and the rear was sitting about 2 in above the front. Therefore I set the billies at 1.75. After I was done and driving I noticed that starting at about 20 mph on up I get a roaring noise from the front.... almost sounds like I have boggers on the front of the truck. Anyone have any ideas?
    Btw The truck now sits pretty much level and I am pretty sure I dont have the tsb rear or at least from what I know (just bought the truck 2 weeks ago) I checked the cv angles and they look alright and the rear drive shaft looks fine.... the only thing I notice is that my tires are cambered significantly and the tires are pretty much shot. I am getting them replaced and aligned tom. but I didnt know If anyone had had any similar things happen.
  2. Dec 15, 2011 at 10:59 AM
    berg2065
    berg2065 Well-Known Member
    Phoenix
    11 reg cab 4x4
    5100's set at .85,eibachs, LR uca's, toytec 1.5" aal, ride rite bags, receiver hitch, ARE cap with bedrug, Thule rack, wet-okole cover, ultragauge, kenwood dnx5180 navi/receiver, ss rubi404 running factory doors and JL8
  3. Dec 15, 2011 at 11:57 AM
    dmcnealy22
    Indiana
    07 4x4 bsp
    Front 5100's @ .85
    I just tested it in 4wd.... It seems as if it less apparent even though it is really faint to begin with .... I think I may go take the 5100's off and back them down to .85 and see if makes the noise go away with less of a cv angle... it just blows that I didnt have this problem yesterday before the lift and now i sure do
    Figures 3 weeks into owning the truck I already have conflicting issues
  4. Dec 16, 2011 at 9:51 PM
    dmcnealy22
    Indiana
    07 4x4 bsp
    Front 5100's @ .85
    Update: I got the new 265/75/16 cooper at3's on and alignment/balancing done and it helped some but not much. The 1.75 setting ended up sitting me at a little over 2 inches ?? so to try and solve my vibes im going to try and take it down to .85 tom
  5. Dec 16, 2011 at 9:51 PM
    dmcnealy22
    Indiana
    07 4x4 bsp
    Front 5100's @ .85
    Too bad... it looked so good :(
  6. Dec 19, 2011 at 9:22 PM
    dmcnealy22
    Indiana
    07 4x4 bsp
    Front 5100's @ .85
    Set at .85 and ended up just over an inch of lift..... front sits 1 in lower than rear and now the only sound I hear are my new tires and no more excessive vibrations
