Weird Whistling sound
Discussion in '2nd Gen. Tacomas (2005-2015)' started by UnitedStatesTacomaCorps, Dec 16, 2018.
  1. Dec 16, 2018 at 5:13 PM
    UnitedStatesTacomaCorps [OP] Member
    Kendall
    2015 Pre-Runner Extended Cab
    3 inch front lift 1 inch rear lift
    Whenever I drive in windy weather there is this super load and annoying whistling sound that comes from the passenger side. It is so god damn load it drives me crazy sometimes. Anyone else have this problem or know how to fix it?
    tcjacado likes this.
  2. Dec 16, 2018 at 5:17 PM
    tcjacado
    tcjacado Well-Known Member
    Door seals, windshield seal, lower control arms.
    I had a noise like that in my 07 that came through the dash/ air system I think. Only on windy days and around 75 mph. I never found it before it was stolen.
    Good luck.
  3. Dec 16, 2018 at 5:23 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
  4. Dec 16, 2018 at 6:26 PM
    retirementtoy
    retirementtoy Member
    Denton, Md
    2007 Tacoma 4x4 TRD
    Stock
    My 2007 did the same thing the dealer replaced the windshield twice and finally put extra sealant around it and it stopped.
  5. Dec 16, 2018 at 6:28 PM
    Possum Fat
    Possum Fat You gonna eat your cornbread?
    Southeast OK
    Caucasion 2010 DC LB 4WD; Magnetic Grey 2015 DCLB TRD Sport
    Look around on here and you'll find that some guys put 1/4" tubing in the door seal gap. It cures it. I used about 2ft worth I think.
  6. Dec 16, 2018 at 10:35 PM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Door seals... I had that issue with my 05 and 2014.
  7. Dec 17, 2018 at 8:07 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    if its a kazoo sound its a door seal issue. They have a TSB seal that implemented the same fix i came up with years ago. Get yourself some 1/4in dripper pipe and run it in the folds of the seal to stiffen the seal up. Kazoo noise will stop.
  8. Dec 17, 2018 at 8:51 AM
    BizzyB726
    BizzyB726 Well-Known Member
    Brandon
    New Jersey
    2012 Black Tx Baja
  9. Dec 17, 2018 at 8:59 AM
    Just Dandee
    Just Dandee Well-Known Member
    Dan
    Southwest Idaho
    2015 TRD OR
    Supercharged-2.5 lift-255/85/16
    Did this, I was on a roadtrip and it drove me nutz. pulled into a true value and got some foam cord and worked into the door seal-mucho better
    Possum Fat[QUOTED] and BizzyB726 like this.
  10. Dec 18, 2018 at 8:57 AM
    Possum Fat
    Southeast OK
    I'll try the foam cord if it ever starts up again. I have unlimited supply of surgical tubing so I just used it. So far it works great
