Welder suggestions
Discussion in 'Technical Chat' started by 6spdtaco, Aug 14, 2010.
  1. Aug 14, 2010 at 8:35 AM
    6spdtaco
    6spdtaco [OP] Well-Known Member
    Nate
    East Wallingford, VT
    Taco
    Tom Woods driveshaft. TRD short throw shift kit. TRD exhaust. AFE Stage II intake. CBI Bumpers front and rear. Warn 8000i winch/ synthetic line. OME 3" lift w/ dakar springs and 886 coils. ATO Front skid. ARE MX cap. Trail Team FJ wheels. Cooper Discoverer ST 265/75-16 C tires. Diff breather relocation mod.
    Looking for a welder. I've got a 72 scout II stripped all the way down, frame sitting on jackstands. Next step is to weld.
    Planning on welding mostly steel, but would like to be able to weld aluminum too in the future.
    Anyone have suggestions?
    Price is a factor. I am not looking for a professional lever setup.
    Thanks!
  2. Aug 14, 2010 at 8:47 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    I have Hobart 140, 110V I bought from Northern tools on sale. Very good unit. A lot of people will say that 110V is not very good but few guys with small welders in my club did testing and turns out that if you can run welder out of the power generator 110V welder runs as good as comparable 220V
    Plus it can be use with out generator on thin steel with out issues. :D
    For me it was great buy. Plus with Hobart there is access to spare parts as this is rebranded Miller. Hope that helps.
  3. Aug 14, 2010 at 1:37 PM
    Rocketball
    Rocketball If The World Didn't Suck, We'd All Fall Off
    Scott
    Westminster, MD
    08 Speedway Blue DC Sport 4x4
    Pioneer head unit, PAC steering wheel control modual, Hard wired Sirius radio, Hard wired radar detector, Hella Supertone horns, Blacked out badges, Smoked Tails, BHLM (color matched Speedway Blue), T-Rex Eyelids, Black Powder Coated Billet Grill, Color Matched Engine Cover, Lund in channel vent visors, FJ Cruiser wheels, Leer 100XQ shell, OEM bed mat, Piezo beeper for locking doors, Tinted front side windows, Black Westin bull bar, Aires tube steps, Mini Maglite Mod, D-Cell Maglite Mod, Weathertech Digifit Floor Mats
    If you want to have the flexibility to weld aluminum, you'll need either MIG, or TIG. Old school stick welders will not do aluminum. TIG is good, but hard to learn and master. If you watch American Chopper, most of the welding they do is with a TIG system.
    IMO I would recomend going with a MIG system. They are very flexible in what you can do and are very portable and affodable.
    I don't know enough about the product lines of the various manufacturers, but I thought I'd throw out my opinion on what type of welder you should be looking for.
  4. Aug 14, 2010 at 6:13 PM
    6spdtaco
    Nate
    Taco
  5. Aug 14, 2010 at 6:21 PM
    BlueT
    NorthEast
    Looks decent, but I dotn know this one. make sure you have easy access to spare parts as things like wire, rolls tips do use so you going have to buy them throughout the life of welder.
  6. Aug 15, 2010 at 10:15 AM
    piercedtiger
    piercedtiger Devout Atheist
    Jon
    Southern Tier, NY
    2015 F150 3.5EB SCEW 6.5ft
    I have a ~$300 Cambell Hausfield from Lowes. I've had it about 4 years and love it. It's a 110v wire-feed flux core one. I've welded sheet metal to replace a radiator support in a Corolla lots of 1/8" angle iron (from bed frames), and whatever shopping carts are made of (chromoly? :notsure: ). Also lots of exhaust work. It's nice having 110v since I can toss it in the truck and take it to a friend's house as needed and not worry about not having a 220 hook up. It's definitely more efficient with a short distance from the breaker box, but I routinely run in my barn off a 100ft extension cord. And the barn is hooked up via a 100ft single 120v line from the house (yes, I need to rewire the barn with a dedicated 220v circuit, but it does the job).
    The only thing I regret is not having the gas option. Flux core is better (apparently) for welding outside since shielding gas can blow away and affect the weld. Since I weld outside or with the barn door open that's better for me, but the option to do aluminum would be nice.
    One thing I recommend is buying 10lb spools if you go wire fed. I used to use the 2lb ones figuring "well, I don't weld *that* much...." But those damn things cost $20 unless you find a 2-for-1 or 2 pack special whereas the 10lb ones are typically under $50. So you could save $50 buying the 10lb versus 5 2lb ones over time. (not to mention nothing sucks worse than getting halfway through a project, run out of wire, and realize it's Sunday so no one that sells welding wire is open! :frusty: )
  7. Aug 15, 2010 at 10:18 AM
    piercedtiger
    Jon
    Southern Tier, NY
    Oh, and hit up Northerntool.com! I got a auto-darkening helmet for $40 from them, and I think the price dropped a couple weeks later. :facepalm:
  8. Aug 17, 2010 at 6:18 PM
    mojochili
    mojochili Member
    Albuquerque
    White Taco SR5 4.0L V6 4x4 TRD Off-Road
    Astro Hi-Top Camper Shell, Drop in K&N air filter
    I have a little lincoln mig unit like that a buddy just gave to me. I think he bought it from Home Depot originally for about $400. Works great for smaller gauge material. I bought the gas kit for it for $100 bucks. You can score a little bottle of 75/25 mix for about $100 bucks. I think you can even plug a one of lincoln's tiny spoolguns into it, then you can mig your aluminum. If you like the appearance of really really nice beads and can tig well, then score a tig welder. The little miller dynasty welders are really cool; they're about $900. I'm wondering if anybody on here has ever tried a brand of welders called Everlast. They have a portable inverter tig unit that has a built in plasma cutter. You can change weld setting like crazy and cut various materials. They are asking about $1700 for the biggest combo unit and it has the same warranty as a Miller or Lincoln. They also have some decent priced smaller units you may be interested in.
    everlastgenerators.com
