Welder wiring hook up help :)
Discussion in 'Garage / Workshop' started by wolfgang123, Jan 18, 2010.
  1. Jan 18, 2010 at 12:51 PM
    wolfgang123
    wolfgang123 [OP] Well-Known Member
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    So I got a welder finally sooo happy. I need some help, I got the dryer plug from Lowes today (the welder just came with exposed wires, and I will by using the 230 outlet for our dryer to power it) so I have the plug and everything taken care of I just need to make an extension cord now. I need about 25 feet and I am pretty sure I can use this stuff at Lowes, I think it’s called like service wire,? It’s good for 300 volt etc...(It meets specifications for the welder) it should work for an extension cord right? So my plan is to wire the plug (which has a 6 ft cord with little "O" connectors already on the end, 3 of them) to the wires on the service cord (its power cord not communication cord or anything like that) then the other end of the service cord to the exposed welder wires (about 3 feet of wire coming out the back of the welder). So my question is how do I go about connecting all these wires together???i am assuming the simple "twist" method wont work with this kind of voltage.
    P.s. it’s a 230 volt welder working at 25 amps the outlet is 230 volts at 30 amps.
    Also the plugs wires don’t have markings on them or anything for ground and power??? So does it just not matter where I hook up each wire??
    EDIT: also the wires on the plug and this service cord are both 10/3 gauge
  2. Jan 18, 2010 at 12:54 PM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    What's the gauge of the "service" wire?
    White is your common
    Black is your hot
    Red is your hot
    Green is ground
  3. Jan 18, 2010 at 12:56 PM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    Personally, I would hook the "service" wire directly to the welder (remove the 3' it has already) and the plug and eliminate all of the connections all together.
  4. Jan 18, 2010 at 1:28 PM
    wolfgang123
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    ok but how would i go about hooking up the other connections from the plug to the service wire?? i like the "O" connector things. could i just stick a bolt through them (if i added more connectors to the service wire) and clamp them down? then wrap in electrical tape, and add a little tubing around them???
    gauge on the service wire is 10/3 just like the plug.
  5. Jan 18, 2010 at 4:18 PM
    wolfgang123
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    also there are only 3 wires green, white, black no red
  6. Jan 18, 2010 at 4:21 PM
    TacoNut
    TacoNut IgnoringChrisWatchingEdLi veVicariouslyThroughMJP2
    Adam
    Denver, Co
    16 TRD OR DCSB Quicksand
    X1000
    Then what you got is for 110V. You need what you have, but with 4 conductors like 98T said.
  7. Jan 18, 2010 at 4:26 PM
    wolfgang123
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    uhhh???? its a 230 volt welder???? although the wires coming from the welder do say 110 one them???? the plug i bought for the 230 volt also only has 3 wires????whats going on???
  8. Jan 18, 2010 at 4:28 PM
    TacoNut
    Adam
    Denver, Co
    What welder do you have? Brand and model #?
  9. Jan 18, 2010 at 4:31 PM
    wolfgang123
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    its a china welder....i just checked white is hot and black is hot and green is ground. so i guess 110 white (doesnt say volts on it, just 110) and hot black (doesnt say volts on it, just 110) make 220 volts and then green being the ground. does that all sound right?
  10. Jan 18, 2010 at 4:32 PM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    230V normally has three wires, Black, White and red.
  11. Jan 18, 2010 at 4:34 PM
    wolfgang123
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
  12. Jan 18, 2010 at 4:35 PM
    TacoNut
    Adam
    Denver, Co
    This set up, would translate to:
    Hot:Black
    Hot:White
    White:Green
    Ground:????????????????
    X2
  13. Jan 18, 2010 at 4:35 PM
    wolfgang123
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    yea 3 wires but instead of red theres a green which is ground and the other 2 are hot.
  14. Jan 18, 2010 at 4:36 PM
    wolfgang123
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    Hot:Black
    Hot:White
    Ground: Green
  15. Jan 18, 2010 at 4:37 PM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    Whats the plug look like? Can you take a picture?
  16. Jan 18, 2010 at 4:39 PM
    wolfgang123
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
  17. Jan 18, 2010 at 4:43 PM
    JDMcQ
    JDMcQ Well-Known Member
    The Mushroom Capital of the World
    2006 Toyota 4Runner SR5 V8
    Buy a fire extinguisher
  18. Jan 18, 2010 at 4:44 PM
    wolfgang123
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
  19. Jan 18, 2010 at 4:44 PM
    wolfgang123
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    im not an electrician and i have no idea either.
  20. Jan 18, 2010 at 4:57 PM
    wolfgang123
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
