Welding / bending metal question...
Discussion in 'Technical Chat' started by MadeInMaine, Jun 30, 2011.
  1. Jun 30, 2011 at 2:27 PM
    MadeInMaine
    MadeInMaine [OP] MadeInMaine
    Owen
    Biloxi, MS
    2014 4Runner
    Hey Fellas,
    so my buddy dropped my motorcycle the other day (he is ok), but he bent the shifter petal, where the rubber piece is to grab on your boot.
    Does anybody know if I can just heat it a bunch, then bend it back, will it snap?
    Do I have to buy another shifter pedal?
    Thoughts, advice, knowledge?
    Thanks guys
  2. Jun 30, 2011 at 2:29 PM
    BFA
    BFA Nuttier than squirrel shit.
    Brian
    Phoenix, AZ
    2003 3.4 4x4 5spd
    Its most likely a cast alloy.. I don't really know but that type of item is better to replace
  3. Jun 30, 2011 at 2:30 PM
    BradleyScottETC
    BradleyScottETC Class IV Category 8 Elite VIP Member (Only)
    Bradley
    Lake County, FL
    10 4.0 AC 4x4
    I would definitely try it before buying one. All it could do is not work, in which case you'd have to buy one anyway, but it probably won't snap.
  4. Jun 30, 2011 at 2:32 PM
    Paul's TRD
    Paul's TRD I'm Not Your F***ing Brother
    TX
    2011 Z71 4x4 5.3L V8
    depends how much it is bent. If it has a pretty good pinch then heating up will be the only option to avoid it stressing out and pretty much breaking off. It won't snap, but it will just start to tear off. we have on occassion bent one back with no heat and it was fine. Do you have a picture? I could for sure tell you.
  5. Jun 30, 2011 at 4:51 PM
    BRP27
    BRP27 When I grow up I want to be just like Me
    So far south in Texas my feet are in salt water
    04 4X4 Tacoma SR5
    3 in Ultimate ToyTec, set @ 2.5 in. AAL PINCH Weld Mod ( beat the pinch weld over inside the fender) Painted the pinch weld on bottom of cab Black Hi Lift Knock off
    If it is not bent bad you can slowly bend it back cold, if it is bent bad heat it up and bend it back. I have bent a couple back cold.
  6. Jul 1, 2011 at 5:17 AM
    angrysam
    angrysam Huh?
    Sam
    Somebody's Shit List
    2.9 Gen- Not a cunt.
    Fleshlight and an old Farrah Fawcett poster.
    Depends on what it's made of and how bad it's bent. If it's cast you probably won't have much luck.
  7. Jul 1, 2011 at 5:24 AM
    98tacoma27
    Ben
    Not Beech Creek
    If it were cast iron, it probably would have snapped when it was layed down.
    You can bend cast iron back but it must be cherry red and it has to be done slowly. It may crack regardless though. And DO NOT QUENCH IT. Let it air cool.
    If it's just a regular mild steel alloy (probably chrome plated) you can bend it back after heating with relative ease. Do it slowly or it will also crack. And the finish (chrome plating) will probably be destroyed.
    If it's aluminum, fat chance. Get a new pedal.
