Welding on a 2nd gen Tacoma?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Subtoy, Jul 23, 2017.
  1. Jul 23, 2017 at 11:49 AM
    Subtoy
    Subtoy [OP] New Member
    RI
    SR5 V6 4x4
    Welding on the frame of a 2nd gen Tacoma what needs to be removed besides the positive terminal on the battery, to avoid damaging any of the electronics?
    Thanks in advanced
  2. Jul 23, 2017 at 7:49 PM
    08tacobear
    08tacobear Well-Known Member
    08 taco DCSB pre runner V-6 SR5
    12v accessory plug right rear bed bin,1gallon air compressor setup in left rear bed bin, 3-window bed topper.
    I would completely unhook the battery, notmjust the positive side.
    Torspd likes this.
  3. Jul 23, 2017 at 7:55 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Just weld. I don't even bother. If it makes you feel better, disconnect the negative cable.
  4. Jul 23, 2017 at 9:02 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    What he said. Negative at minimum.
  5. Jul 23, 2017 at 9:11 PM
    paranoid56
    paranoid56 Well-Known Member
    San Diego
    14 double cab taco
    i just weld, the biggest issue is how you ground it. just make sure you ground near the weld and you are good.
  6. Jul 23, 2017 at 9:23 PM
    desertrunner24
    desertrunner24 Well-Known Member
    Jake
    Fresno , CA
    2011 TRD offroad 4x4
    Some
    This is what I do. I used to unplug the computer but that got old. Disconnect the battery and ground close to your welding area
  7. Jul 24, 2017 at 3:28 AM
    TucsonAZ
    TucsonAZ Well-Known Member
    2006 Crew Cab TRD
    ARB Bumper
    Current is going to take the path of least resistance so ground as close as you can. When I welded a nut on my front diff drain plug I actually just held the nut in the ground of the welder until it was tacked in place and had at it so technically the current was only in the plug and nut I welded on.
    ChadsPride likes this.
