Well it happened
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Ddaughen15, Dec 19, 2020.
  1. Dec 19, 2020 at 2:51 PM
    Ddaughen15
    Ddaughen15 [OP] Well-Known Member
    Dylan
    New York
    15’ Tacoma SR5
    Driving my truck during one of these beautiful NNY freezing days and i see the Trac off and engine light pop on. Happy days, I start off positive call the dealership “check your gas cap” surely it can’t be that easy, I was due for an oil change and tire rotation so I asked them to look at the codes while they’re at it. My air pump and switching valve set went, that’ll be a cool 3 grand give or take days the dealership. I know there are threads on threads about this but I’m faced with fixing the truck out of pocket as my truck no longer has warranty (only has a power train warranty) or trading in my truck for a newer tacoma ( they have a sweet 2021 manual there and it’s tempting) if I go with the fixing my truck out of pocket can it be guaranteed that this issue won’t come up? By what I’ve seen it’s a design flaw by Toyota and they’re just gonna put another faulty part on it. Or do I go with the brand new Tacoma route and start over??
    Update 12-21-20: Got in touch with another shop and they quoted me at 1000 to fix with parts and labor, know this guarantees that it doesn’t happen again I still haven’t made up my mind to trade in and start over or bite the bullet. I took apart the air pump to check the foam filter and it is still fully intact. The light hasn’t popped back on is there a chance that nothing is actually wrong with my truck and I can chalk it up to me not tightening my gas cap all the way? Or could I not get that lucky?
  2. Dec 19, 2020 at 2:55 PM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    Only the '12s had the issue as a whole. The '13+ have the revised air dumb at shut off that blows the reed valves dry.
    I'm your case it was just the luck of the draw...not so much a bad design. That said...the valves can be purchased. If you can do an oil change or spark plug change, you could probably handle replacing them
    MattCowsmasher likes this.
  3. Dec 19, 2020 at 3:06 PM
    PoweredBySoy
    PoweredBySoy Well-Known Member
    Jesse
    Minnesota
    2013 DCSB SR5
    davidstacoma and Kolter45 like this.
  4. Dec 19, 2020 at 3:21 PM
    Kolter45
    Kolter45 Well-Known Member
    Denver, CO
    2013 TRD Sport, 2015 Inferno 4Runner
    Toytec Boss Leer/Rhino Rack TRD Wheels/Falkens
    Shit breaks - sorry man! I say fix it & then think about trading your truck in. You can't jump to a new vehicle in this market. My AC Compressor blew this past summer. The AC Shop wanted more $$ then the damn dealer. I got it fixed & it wasn't cheap.
  5. Dec 19, 2020 at 3:22 PM
    Ddaughen15
    Dylan
    New York
    15’ Tacoma SR5
    Codes were P2441 and P2442
  6. Dec 19, 2020 at 3:38 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
  7. Dec 19, 2020 at 4:37 PM
    Soylent Green2012
    Soylent Green2012 RestoRides MotorSports
    jake
    Apopka, Florida
    2012 Tacoma Pre runner SR5 V6 Limited Edition
    chrome bull bar, 20" vision wheels, LED lighting, Custom grill.
    If anybody on here thinks it CANT BE THE GAS CAP Better check again.
    It has happened to me and my 2012. In fact the first time was my fault
    I went to get gas and the pump would not take my card went home but forgot
    to tighten the cap to the click. check engine light and codes 2440 and 2442
    were present. Got gas the next day Saw the gas cap was loose and tightened
    it up snug. Next day cold start- all normal. no CEL.
    Several days ago happened again. Same codes. I thought no way.
    But I had replaced the stock gas cap with a locking version. People on here said
    it was a problem. Turns out it is. Put the stock cap back on And codes went bye bye
    again. Have not returned since.
    davidstacoma and TnShooter like this.
  8. Dec 19, 2020 at 4:42 PM
    T-yoda
    T-yoda Well-Known Member
    Dave
    Eastern pa
    17 TRDORDCLB mgm
    265-75-16 BFG AT, firestone riderites
    Not sure how friendly you are with your dealership but take a moment and ask for assistance... call Toyota’s hotline number. Ask the service manager and maybe they can guide you in the right direction also for assistance....
  9. Dec 19, 2020 at 4:46 PM
    308savage
    308savage Well-Known Member
    Adam
    East Tennessee
    2012 Tacoma TRD Sport DCSB
    Leveling kit, roll bar
    Mine is a 2012, SAIS has been replaced twice already. Once due to failure (at 25,000 miles), the other due to recall (at 46,000 miles). I’d like to get a newer Tacoma but the wife gets the next new vehicle.
  10. Dec 19, 2020 at 4:48 PM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    Or just reset the codes and see what happens next. Never assume immediately that it is an expensive fix
    davidstacoma likes this.
  11. Dec 19, 2020 at 4:49 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Check the vacuum line that comes off the switching valve and runs up to the intake is not dry rotted and/or replace
  12. Dec 19, 2020 at 4:50 PM
    TnShooter
    Deogee
    STOCK
    That is a bit ridiculous.
    Those codes for a gas cap? Wow.....
    Did it go in Limp Mode too?
  13. Dec 19, 2020 at 5:29 PM
    Soylent Green2012
    jake
    Apopka, Florida
    Yes it did, Both times. And it reset on it's own.
    I checked on the switching valve and the gaskets and the total with shipping to me would have been $535
    And thats without being installed.
    So yes a gas cap loose or damaged can Mimic the same symptoms of a leak in the SAIS system. Anything to do with
    the fumes being vented to air and not burned = some sort of codes.
    The fact that you can be mistaken on a $500 repair or more is a damn shame.
    My gas cap even states that if not tightened to the click can result in the check engine light coming on.
  14. Dec 19, 2020 at 5:34 PM
    Soylent Green2012
    jake
    Apopka, Florida
    Yes this is another area you must look into before $$$ spent on the big ticket items.
  15. Dec 19, 2020 at 6:01 PM
    Hugh Morron
    Hugh Morron Manic Mechanic
    Bill
    Schuylkill County, PA
    12 DCLB SR5 4X4 Barcelona Red Metallic
    ARE Cap, AVS Bugdeflector II, AVS Ventshades, DTRL delete, ABS/VSC/TRAC disable, Toyota LSD with clutchpacks, N-Fab Lightbar, Hella 700ff lights
    I believe the 3rd gen Tacomas have the same SAIS system.
  16. Dec 19, 2020 at 6:42 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    The 4-cyl does. The V6 has the exhaust manifold cast into the head, so the cats warm up fast enough after startup to avoid needing the SAIS system.
  17. Dec 19, 2020 at 6:46 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    Since you're out of warranty, stop drinking the dealer koolaid. Go to an indie shop and get it diagnosed properly. If it's indeed the pump, a replacement Chinese pump is only $100 on Amazon, e.g. https://www.amazon.com/Secondary-2011-2015-Toyota-Tacoma-17610-0W020/dp/B08169BHS7/
  18. Dec 21, 2020 at 9:30 AM
    Ddaughen15
    Dylan
    New York
    15’ Tacoma SR5
  19. Dec 21, 2020 at 9:34 AM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    :gossip: psst: HP Tuners can program that thing to not function... Of course, that would be only for an off-road vehicle only. ;)
  20. Dec 21, 2020 at 9:42 AM
    ABA180
    East Bridgewater MA
    Reset the light, tighten your cap, and drive for a few days to see what it does.
    Kolter45 and SR-71A like this.
