Well that Sucks..........
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Oldewing1800, Nov 24, 2022.
  1. Nov 24, 2022 at 7:01 AM
    Oldewing1800
    Oldewing1800 [OP] Well-Known Member
    2006 Double Cab
    Dog hair, lost happy meal parts from Grandkids....
    Had my truck at the coin car wash, not for it, but cleaning folding tables for Thanksgiving.
    Notice the inside of the passenger front tire had grease on it. Upon further inspection, found the sway bar link had given up and broke. And on it's way it sliced the CV boot.
    Dang CV are under 40K old, just done when they did the frame.
    Hence my post, anyone used one of the "boot repair" kits that are out there?
    Oh, and Happy Thanksgiving to you and yours.
    Ricardo13x, Taco 422 and TnShooter like this.
  2. Nov 24, 2022 at 7:04 AM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    Sorry dude…I don’t know if there made like a Honda,but if they are take the axle out,remove the inner joint and slide it on…
  3. Nov 24, 2022 at 7:51 AM
    Longtech
    Longtech Well-Known Member
    Long
    SoCal
    15' OR converted 4WD
    Just get it rebooted. No biggie. Enjoy your turkey
    Ricardo13x likes this.
  4. Nov 24, 2022 at 7:56 AM
    Wesmonster
    Wesmonster Member
    Wes
    2915 access cab
    I used a zipper boot repair kit on an 8 year old Civic that tore a boot on some yard branches. Had the car for two years after that before selling it, boot was still holding at the time.
    Normally my advise is just replace it but it's a good short term fix. But keep tabs on it, a torn boot will ruin a joint pretty quickly.
    That's assuming your just keeping to the streets. If you're off roading, all bets off...
  5. Nov 24, 2022 at 8:04 AM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Maybe look into getting some heavier end links... these are Overland Custom Design.
    TnShooter and HondaGM like this.
  6. Nov 24, 2022 at 8:21 AM
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
    Them some heavy duty ones and adjustable to:thumbsup:
  7. Nov 24, 2022 at 11:03 AM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    Show off...
  8. Nov 24, 2022 at 11:24 AM
    OffroadToy
    I've read elsewhere about the sway bar end links breaking and going through the cv boot and was just sharing what i did to try to avoid it from happening.
    whatstcp likes this.
  9. Nov 24, 2022 at 3:13 PM
    winkel
    Corydon, IN
    I was saying "show off" because your set up looks FANTASTIC. I'm jealous.
    OffroadToy[QUOTED] likes this.
  10. Nov 30, 2022 at 10:48 AM
    Oldewing1800
    2006 Double Cab
    Fixed, got out lucky, sway bar was broke, r and r real easy. Boot was not ripped, but the bar caught the buckle on the outer boot and snapped it off so the clamp was loose. So, ran to NAPA got a new clamp for 3.54 and we are golden. I did repack the joint before putting the new clamp on.
    Under 30 bucks all in, another win for a older beast,
  11. Nov 30, 2022 at 8:53 PM
    tyjoja
    tyjoja Well-Known Member
    Oregon
    2008 off road trd, Rugged Trail
    lift
    keep an eye on that new clamp... I had trouble with it holding when i did mine and ended up using a special radiator type clamp made for those boots to get mine to hold.... have fun
  12. Dec 5, 2022 at 1:10 PM
    Oldewing1800
    2006 Double Cab
    Thanks, been checking and it still looks good. Made sure I got it in the groove fully upon clamping,,
