Well that was an easy dash cam install.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by flipnidaho, Feb 1, 2020.
  1. Apr 25, 2020 at 11:06 PM
    #281
    jimmerheck
    jimmerheck Well-Known Member
    Vancouver, WA
    2019 Tacoma Limited in white
    Sorry, I wasnt very clear. Has someone mounted both cameras to the windshield, one facing forward and one facing rearward?
    deusxanime likes this.
  2. Apr 26, 2020 at 5:15 AM
    #282
    pokey1416
    pokey1416 Well-Known Member
    Jeff
    Southwest Michigan
    2019 QS Tacoma TRD Off Road
    ARE Overland Cap Brake controller Cali Raised Lightbar Mounts Strobes N More E66 Bussmann RTMR w/Metri-Pack
    Thanks for catching that. My old eyes are getting worse. :eek:
  3. Apr 26, 2020 at 5:22 AM
    #283
    DES2009
    DES2009 Minister of Truth
    Southeast Louisiana
    2017 MGM Limited
    I'm a Millionaire! One Million Posts!!
    Actually the one that mCat linked may work for you. The picture looks like 14-pin, but Dongar is calling it 7-pin. In any case it looks like it might work.
  4. Apr 26, 2020 at 5:42 AM
    #284
    pokey1416
    Jeff
    Southwest Michigan
    Thanks X2 just ordered it I’ll report back after the install. :thumbsup:
    DES2009[QUOTED] likes this.
  5. Apr 26, 2020 at 6:14 AM
    #285
    ClassyTacos
    ClassyTacos National Treasure 3, Times a ticking Nickolas
    Papalote
    Florida
    2017 TRD Sport 4x4
    Stockish
    I'm very interested in the adaptor set up. But first, in an attempt to clean/ organize this amazing thread, It might be a good idea for anyone posting to
    1. specify if you purchased the 1st or 2nd gen adaptor
    2. what camera/sd card combo you're using
    3. set up pic
    4. any issues you are encountering since install-- camera, sd card, mount, or adaptor issues
    That way we can get into the 2nd gen adaptor. My order is in for the adaptor and mini GARMIN camera.
    I will put close up pics when they come in and will also do an install/ set up and driving video so all can see.
    I'm not trying to take over anyones thread, there is a ton of good information here and this is an easy mod. Thank you all for taking the time to post. It has speeded my decision making process. Once I have the adaptor/camera set up I will follow the post set up outlined above. If you feel anything else should be added to the list please feel free too add on. Again, thank you.
    pokey1416 likes this.
  6. Apr 26, 2020 at 7:23 AM
    #286
    mrtonyd
    mrtonyd Well-Known Member
    Tony
    Colorado
    2019 TRD OR DCSB cement
    I dont think the adapter would provide enough power for 2 cams. You'd be better off getting one cam that does front and back
  7. Apr 27, 2020 at 11:31 AM
    #287
    TA-5650
    TA-5650 Well-Known Member
    Wilmington, DE
    2017 TRD OR DCSB, Blazing Blue Pearl
    Any overheating on the Rev 2 cable?
  8. Apr 27, 2020 at 11:55 AM
    #288
    304_Taco
    304_Taco Well-Known Member
    Curtis
    Morgantown, WV
    16 TRD Sport DCSB MT
    I haven't had any issues with the v2 cable in the 10ish days I've had it
  9. Apr 27, 2020 at 12:13 PM
    #289
    Rottencotton
    Rottencotton Well-Known Member
    Stinkin Rincon
    Superwhite 2019 Tacoma SR 4x4
    Does anyone know how to get behind the center console in the headliner? Don't see any screws but afraid to test if it snaps into place. Be just my luck there's a hidden screw or 2.
  10. Apr 27, 2020 at 12:17 PM
    #290
    304_Taco
    Curtis
    Morgantown, WV
    It supposedly snaps into place so just get a corner and pull it out. I haven't ever tried it though
    Rottencotton[QUOTED] likes this.
  11. Apr 27, 2020 at 12:19 PM
    #291
    mrtonyd
    Tony
    Colorado
    https://ogfab.com/products/og-tacoma-3gen-command-center
    The only accessory I've come across with some instructions on how to get behind there.
  12. Apr 27, 2020 at 12:31 PM
    #292
    Rottencotton
    Stinkin Rincon
    Are they calling the console the map light?
    "1. Remove the front map light by pulling on the corner till it pops out."
  13. Apr 27, 2020 at 12:50 PM
    #293
    Nomad26
    Nomad26 Well-Known Member
    Escondido, CA
    '16 MGM OR Access Cab, ‘16 MGM RAV4 Hybrid
    When I installed my Meso map lights I popped it out, no screws. The whole console.
  14. Apr 27, 2020 at 12:56 PM
    #294
    Rottencotton
    Stinkin Rincon
    Thanks. :thumbsup:
  15. Apr 27, 2020 at 1:19 PM
    #295
    Onetime27
    Onetime27 Well-Known Member
    Joe
    Columbia Gorge, OR
    ‘20 OR DC
    275/70/16 AT3Ws
    Amazon has the Garmin Mini for $83 right now. The seller is Garmin on there as well. On their website they’re selling for $130.
    Garmin Dash Cam Mini, Car Key-Sized Dash Cam, 140-Degree Wide-Angle Lens, Captures 1080P HD Footage, Very Compact with Automatic Incident Detection and Recording https://www.amazon.com/dp/B07R638L8N/ref=cm_sw_r_cp_api_i_43ZPEb9KS34D7
  16. Apr 27, 2020 at 5:27 PM
    #296
    Choco_Taco
    Choco_Taco Sarcastic AF
    Tim
    Fredericksburg, VA
    2024 Blue Crush TRDOR 4x4
    Did you have to buy anything to go from the camera to the rear view mirror adapter? Looking at it, I cant tell if the camera comes with the needed hardware.
  17. Apr 27, 2020 at 5:58 PM
    #297
    304_Taco
    Curtis
    Morgantown, WV
    The Garmin mini comes with two micro usb cords that are both entirely too long to be used with the mirror adapter. I bought a 6 inch right angle micro usb cable from Amazon when I ordered the camera. It worked perfectly
    Choco_Taco[QUOTED] likes this.
  18. Apr 27, 2020 at 8:48 PM
    #298
    deusxanime
    deusxanime Well-Known Member
    MN
    2020 Cement OR DCSB V6 6MT 4x4 Prem+AdvTech+LED
    Do you have a link to the USB cable you used on the front one? Hard to figure out which right angle needed on each side and such, would be nice to just know what works. It looks great on yours!
  19. Apr 28, 2020 at 2:26 AM
    #299
    Capt Tacoma
    Capt Tacoma Well-Known Member
    2017 TRD Sport DCSB
    Do you think a 3.5" micro usb cable would be long enough?
  20. Apr 28, 2020 at 3:22 AM
    #300
    304_Taco
    Curtis
    Morgantown, WV
    It would be tight, but I'm sure you could make it work if you mounted the camera closer to the adapter. If nothing else you could try it and see what happens. Then order a cable if it isn't long enough. I used one of these and it worked perfectly for how I set it up
    FishnTx and pokey1416 like this.
