Well that was an easy dash cam install.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by flipnidaho, Feb 1, 2020.
  1. May 6, 2020 at 9:56 AM
    #341
    judgefudge72
    judgefudge72 Well-Known Member
    PNW
    CARMAX HAS MY TACO NOW
    This was my main concern with a suction cup mount. I went with the 3m pad that came with my dash cam so we will see how long that holds. There are lots of mirror mount kits on Amazon depending on which dash cam you have. They can be awkward to initially set up because of the limited space you have to work with up there but once they are installed it should last damn near forever.
  2. May 6, 2020 at 9:57 AM
    #342
    mrtonyd
    mrtonyd Well-Known Member
    Tony
    Colorado
    2019 TRD OR DCSB cement
    yea why not. the new style adapter provides a bit more current than the old one. shouldnt be an issue. i think 1amp is standard for most wall plug to usb. the fast chargers that have been coming out provice like 2.1amp. it may not charge the gopro super fast, but will keep it on when the truck is on
  3. May 6, 2020 at 9:59 AM
    #343
    Taco yum
    Taco yum Well-Known Member
    2011 prerunner
    Yeah it sucks haha. But I’ll check out Amazon for sure. Thx for the suggestion.
  4. May 6, 2020 at 9:59 AM
    #344
    crunchytaco13
    crunchytaco13 Well-Known Member
    ‘17 PRO MT Cement
    TRD CAT
    Curious about the same thing. I've already got the mount on my '17 and the go pro. Just need a power source and have it turn on and off with the truck somehow
  5. May 6, 2020 at 10:00 AM
    #345
    crunchytaco13
    ‘17 PRO MT Cement
    TRD CAT
    Have you done this with a gopro? Do you know if iti’ll power on the gopro and start recording when the truck turns on? Any experience with settings to configure the gopro this way?
  6. May 6, 2020 at 10:04 AM
    #346
    mrtonyd
    Tony
    Colorado
    its been a long time, but i thought the hero3 had some settings to auto record when its powered on. ive come across some guides online, but never tried it myself. i'm not sure about the new versions
  7. May 6, 2020 at 10:20 AM
    #347
    Rottencotton
    Rottencotton Well-Known Member
    Stinkin Rincon
    Superwhite 2019 Tacoma SR 4x4
    I've tried several kinds / brands of double sided tape and they all suck. Even a couple that were recommended here. On the other hand, double sided tape that comes with most dashcams seem to work the best by far. In my experience, the spongy type tape is the worst. Pure garbage. Doesn't even hold for a day.
  8. May 6, 2020 at 10:22 AM
    #348
    Taco yum
    2011 prerunner
    I hear ya, I’m looking at Amazon right now, I’m gonna try and look for a screw mount one with some kind of adapter.
    Rottencotton[QUOTED] likes this.
  9. May 6, 2020 at 1:21 PM
    #349
    Loaded NightraiN
    Loaded NightraiN Well-Known Member
    17 TRD Off Road
    What about auto off?
  10. May 6, 2020 at 2:22 PM
    #350
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    So, I have a Hero 7 Black and have been checking settings. It's not really setup well for dashcam purposes.
    - It does not appear to be able to power on automatically when power is applied, but you can enable voice commands and tell it to start recording when you start driving. But, it's always listening then and the battery may drain down.
    - It does not charge while recording, just runs off the external power. It starts charging again when not recording. So, if you always use it while driving, it will never really charge.
    - You can set it to turn off after 5 minutes of idle time. But you have to remember to tell it to stop recording when you stop driving or it won't be idle, just sitting there recording away until the battery dies.
    - It does support looping, but only saves the footage if you tell it to. If you get in a wreck, you better be able to hit the button if you want the footage.
    That's about the worst setup for using as a dash cam that I can think of. And Hypersmooth sucks balls for mountain biking (it jumps all over as it tried to find an anchor point in the video) and gets the camera really hot.
    Don't get me wrong, I do like it and it does take some good video, it's just not as cool as I thought it would be. You'd think they could just add a simple "dashcam mode" that works like a real dashcam. You are better off getting a real dashcam.
    Grumpylicous and DES2009 like this.
  11. May 6, 2020 at 6:03 PM
    #351
    ClassyTacos
    ClassyTacos National Treasure 3, Times a ticking Nickolas
    Papalote
    Florida
    2017 TRD Sport 4x4
    Stockish
    tjara03, TA-5650, pokey1416 and 3 others like this.
  12. May 7, 2020 at 2:05 AM
    #352
    playdixie
    playdixie Miss'ippi fella
    Mississippi
    2016 Blazing Blue TRD Sport DCSB 4x4
    I recently bought the same camera and was wondering if it was charging while on. Good to know it doesn't.
    I had it plugged in, but noticed after driving around a bit the battery was lower than when I started.
    Again, thanks for the heads up!
    DES2009 likes this.
  13. May 7, 2020 at 2:18 AM
    #353
    FishnTx
    South East Texas
    ‘17 OR
    I’ll be installing mine this coming week :bananadance: Polarize lens came in too
    DES2009 likes this.
  14. May 7, 2020 at 5:25 AM
    #354
    EchoDeltaSierra
    EchoDeltaSierra Well-Known Member
    Georgetown, TX
    2020 TRD Off-Road
    Nitro 4.88 gears OME suspension ST/Maxx 255/85R16s
    Super easy and an old Beats earbud charging cable I had lying around fit perfectly.
  15. May 7, 2020 at 7:51 AM
    #355
    Dustin.K96
    Dustin.K96 Well-Known Member
    Dustin
    2019 White Tacoma TRD OR
    Are you guys still getting the error message on the Garmins with the new adapter? I have version 1 of their dongle and I always get that popup every time with my dash cam saying it can't be charged with the cable connected, but the battery has never gone down. I was thinking of purchasing the new dongle if it gets rid of that error, or is it more of the fact that Garmin doesn't like it when we don't use the OEM cable with the dash cam even though it's perfectly fine?
  16. May 7, 2020 at 7:54 AM
    #356
    mrtonyd
    Tony
    Colorado
    im using a garmin mini with the v2 dongle. the lights on the garmin are red all the time, but it still seems to be recording through the app.
    Dustin.K96[QUOTED] likes this.
  17. May 7, 2020 at 10:36 AM
    #357
    Loaded NightraiN
    17 TRD Off Road
    Thanks. I've never owned a go pro, but always wondered about this
  18. May 7, 2020 at 11:08 AM
    #358
    rberumen2
    rberumen2 Well-Known Member
    Ralph
    California
    2017 White Tacoma TRD Sport 4x4 DCSB
    Does this adapter work for dash cams that are on even when the vehicle is off? My dash cam records movement and if your car gets hit while parked, so it’s constantly on.
  19. May 7, 2020 at 11:16 AM
    #359
    DES2009
    DES2009 Minister of Truth
    Southeast Louisiana
    2017 MGM Limited
    I'm a Millionaire! One Million Posts!!
    No. The power it gets from the rearview mirror is only "on" when the ignition is on.
    FishnTx likes this.
  20. May 7, 2020 at 11:17 AM
    #360
    DES2009
    Southeast Louisiana
    2017 MGM Limited
    Which Garmin? I have a Garmin 56 and the rev-1 dongar device and I've never seen an error message. Have you tried updating the Garmin firmware?
